  3. 12v Solar battery monitor
59 Posts 8 Posters 43.9k Views 15 Watching
  • Boots33B
    Boots33B
    Boots33
    wrote on last edited by Boots33
    Hi
    I have installed a node to monitor our 12v auxiliary supply for our home. The power system consists of a 200w panel on the roof and a 105AH battery located in our server cabinet. When we built our home I ran a 12v Backbone as well so we can access the low voltage power all over . To date it has been used to run a system of night lights and reading lamps but now that I have found Mysensors I hope it will soon be powering a lot more :) .
    Ok this node has been running for a few weeks now so thought i would share it with others. it monitors battery voltage, Charge current, Dis-charge current, Ambient temp and battery Temp. I have included the temperature monitors after a friend had his battery develop an internal short and melt in his caravan, not a pretty sight.
    My notes are based on my breadboard version which was built around an Arduino nano, In the final I used a Pro Mini.
    Parts List:
    1 x Arduino I have used a Nano but other types or OK too
    1 x ACS712 Current sensing Module. These are available in 5A, 20A and 30A. Choose whichever current fills your needs. Only one line of code needs to be modified to suit your selected device.
    2 x DS18b20 Temperature sensors
    1 x Voltage sensing module or 2 x resistors to be used as a voltage divider. I have used a module that has a maximum reading of 25v. That means when the module sees 25v on its input the output of the module will be 5v.
    1 x nRF24L01+ 2.4ghz Transceiver
    1 x LM2596 regulator module or some other regulator able to supply 5v
    1x 330 ohm resistor
    1x 4.7 k ohm resistor
    1x LED
    1x push button
    When using the analog inputs of the Arduino it is very important that you have a very stable 5v supply voltage. The 20A ACS712 shows a change of only 100mv for every 1A so you can see even small fluctuations can cause sizable errors in your readings. During construction I found powering the circuit from the usb port to give unreliable results and opted for a dedicated 5v supply instead.
    Construction:
    Wire the devices as shown below.
    The Sketch:
     /*Sketch for a MySensor node to monitor a 12v battery with a solar panel for charging
     * The node monitors battery voltage,current into and out of the battery, ambient temperature and battery temperature.
     * 2 x DS18b20 dallas temperature ic's their data pins connected to arduino digital pin 3
     * 1 x ACS712 current sensor module connected to  arduino analog pin A4
     * 1 x 25v voltage sensor module connected to arduino analog pin A0
     * 1 x nRF24L01+  2.4ghz tranceiver connected as per the MySensors web site.
     * 1 x LED connected via a 330 ohm resistor to pin 6
     * 1 x push button connected to pin 5
    #include <OneWire.h>
    #define ONE_WIRE_BUS 3                       // Ds18b20 data wire is connected to digital pin 3 on the Arduino
    #define ID_S_TEMPA 0                         // First temp device
    #define ID_S_TEMPB 1                         // second temp device
    #define ID_S_MULTIMETERV 3                   // Multimeter device for voltage measurement
    #define ID_S_MULTIMETERC 4                   // Multimeter device for positive current measurement
    #define ID_S_MULTIMETERC1 5                  // Multimeter device for negative current measurement
    #define NUM_SAMPLES 10                       // number of analog voltage samples to take per reading
    int ledPin = 6;                               // the pin for the LED
    int buttonPin = 5;                            // the input pin for offset pushbutton
    int buttonState = 0;                          // variable for reading the pin status
    unsigned long SLEEP_TIME = 30000;            // Sleep time between reads (in milliseconds)
    int lastmilli = 25000;                       // set to an arbitary number outside of expected current sensor range to ensure a change when first run
    float sensitivity = 100 ;                    //change this to 185 for ACS712-5 or to 100 for ACS712-20A or to 66 for ACS712-30A
    int VQ = 0;                                  //Placeholder for quiescent voltage calculations
    int ACSPin = A4;                             // Analog pin number the ACS712 data pin connects to
    float lastTemperature[2];                    //Array to hold the last temp readings sent to gateway, only send new data if different
    int sum = 0;                                 // sum of voltage samples taken
    unsigned char sample_count = 0;              // current sample number
    int lastVoltage = 30000;                     // set to an arbitary number outside of expected voltage sensor range to ensure a change when first run
    int voltagePin = A0;                         // analog pin voltage sensor or voltage divider is connected to
    int voltSenseMax = 25000;                    // set to the maximum input voltage in millivolts of your voltage divider input
    OneWire oneWire(ONE_WIRE_BUS);               // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
    DallasTemperature sensors(&oneWire);         // Pass our oneWire reference to Dallas Temperature.
    // ------ Initialize  messages -------
    MyMessage msg(0,V_TEMP);
    MyMessage msg_S_MULTIMETERv(ID_S_MULTIMETERV,V_VOLTAGE);
    MyMessage msg_S_MULTIMETERc(ID_S_MULTIMETERC,V_CURRENT);
    MyMessage msg_S_MULTIMETERc1(ID_S_MULTIMETERC1,V_CURRENT);
    sensors.begin();                                    // Start up the onewire library
    gw.begin();                                         // Startup and initialize MySensors library. Set callback for incoming messages.
    gw.sendSketchInfo("Battery Status Sensor", "1");    // Send the sketch version information to the gateway and Controller
    // ------ Present all sensors to controller ------
    gw.present(ID_S_TEMPA, S_TEMP);
    gw.present(ID_S_TEMPB, S_TEMP);
    gw.present(ID_S_MULTIMETERV,V_VOLTAGE);
    gw.present(ID_S_MULTIMETERC,V_CURRENT);
    gw.present(ID_S_MULTIMETERC1,V_CURRENT);
    pinMode(buttonPin, INPUT_PULLUP);                     // Set buttonPin as input and turn on internal pull up resistor
    pinMode(ledPin, OUTPUT);                              // Set ledPin as output
    digitalWrite(ledPin, LOW);                            // Make sure ledPin is off
    // ------ load offset for current sensor
    int validCheck = gw.loadState(0);
    if (validCheck == 120){                          // check to see if valid data exists
      VQ = gw.loadState(1);                               // Load count offset into VQ
    //  Serial.print(" positive VQ offset loaded..."); Serial.println(VQ);
     else if (validCheck == 125) {
      VQ = -abs(gw.loadState(1));
    //  Serial.print(" negative VQ offset loaded..."); Serial.println(VQ);
    else {
    // Serial.println("VQ offset not set");
    delay(500);
    buttonState = digitalRead(buttonPin);
    //Serial.print("buttonstate..."); Serial.println(buttonState);
     if (buttonState == LOW) {
        VQ = determineVQ(ACSPin);                           //Returns the offset count needed to show zero with no load
      if (VQ >= 0 && VQ < 255) {                              //check for valid data. VQ is positive number
        gw.saveState(0, 120);                               // Store 120 value  in eeprom position 0. use this to check for valid data at boot
        gw.saveState(1, VQ);                                // Store offset count in eeprom. in case of re-boot
      else if (VQ < 0 && VQ > -255) {                              // VQ is a negative number. negatives cannot be stored in eeprom
        gw.saveState(0, 125);                               // Store 125 value  in eeprom position 0. use this to check for valid data at boot
        gw.saveState(1, abs(VQ));                                // convert VQ to positive and  Store offset count in eeprom. in case of re-boot
    // ------------------ Start voltage readings --------------------
     sample_count = 0;
     sum = 0;
     while (sample_count < NUM_SAMPLES) {                                   // take a number of voltage samples
      sum += analogRead(voltagePin);
      sample_count++;
      delay(10);
    //Serial.print("sum count..."); Serial.println((sum / NUM_SAMPLES));      // print the count result. will be between 0 and 1023
    int voltageI = map(sum/NUM_SAMPLES,0,1023,0,voltSenseMax);              // map the reading and get our result in millivolts
    //Serial.print("mapped volts..."); Serial.println(voltageI / 1000.0, 1);  // convert millivolts back to volts and print. the 1 at the end determines how many decimal places to show
    if ( voltageI != lastVoltage) {                                         // check if we have a new value. only send data if it is different
     gw.send(msg_S_MULTIMETERv.set(voltageI / 1000.0, 1));                  // voltagel is in millivolts so we divide by 1000 to convert back to volts and
        // send voltage message to gateway with 1 decimal place
     lastVoltage = voltageI;                                                // copy the current voltage reading for testing on the next loop
    //--------------------Start Current readings---------------------------------
    int milli = readCurrent(ACSPin);                                       // take a reading from the ACS712 and send to the readcurrent function
    //Serial.print("Milliamps..."); Serial.println(milli);                   // print the value (in milliamps) returned
    if ( milli != lastmilli)                                               // check if value has changed
     if ( milli > 0)                                                       // Battery is charging
      gw.send(msg_S_MULTIMETERc.set(milli/1000.0, 1));                     // Send new data to charging amp device
      gw.send(msg_S_MULTIMETERc1.set(0));                                  // set the dis-charging amp device to zero
      lastmilli =  milli;
     else if (milli < 0)                                                  // Battery is discharging
      gw.send(msg_S_MULTIMETERc.set(0));                                  // set the charging amp device to zero
      gw.send(msg_S_MULTIMETERc1.set(abs(milli)/1000.0, 1));             //  use abs(milli) to Send a positive number  to dis-charging amp device
      lastmilli =  milli;
    else        // No current flowing, set both to zero
     lastmilli =  milli;
    //----------------------Teperature readings start------------------------
      Serial.println(" Requesting temperatures...");
      sensors.requestTemperatures();                  // call sensors.requestTemperatures() to issue a global temperature request to all devices on the bus
      // ------- query conversion time and sleep until conversion completed ------
      gw.sleep(conversionTime);
     for (int i=0; i<2; i++) {
    //  Serial.print("Temperature for Device: ");Serial.print(i);Serial.print(" is: ");
     // Serial.println(sensors.getTempCByIndex(i)); // Why "byIndex"?
        // You can have more than one IC on the same bus.
        // 0 refers to the first IC on the wire
     float temperature = static_cast<float>(static_cast<int>((sensors.getTempCByIndex(i)) * 10.)) / 10.;  // Fetch and round temperature to one decimal in celcius
    if (lastTemperature[i] != temperature)               // check for a changed temperature reading
       gw.send(msg.setSensor(i).set(temperature,1));     // Send in the new temperature
       lastTemperature[i]=temperature;                   // Save new temperatures for next compare
    gw.sleep(SLEEP_TIME);
    /*-------------- Function to get the offset required for ACS712 to show zero with no current flowing -----------------*/
    int determineVQ(int PIN)
      digitalWrite(ledPin, HIGH);                                      // Turn on LED to indicate offset being calculated
      delay(500);                                                      // Delay to hold LED on
      digitalWrite(ledPin, LOW);                                       // Turn off LED
      delay(150);                                                      // Delay to let readings stabilise
    //  Serial.print("estimating avg. quiscent voltage:");
      long acsCount = 0;
      for (int i=0; i<5000; i++)                                       //read 5000 samples to stabilise value
        acsCount += analogRead(PIN);                                   // read the count value between 0 and 1023 and add it to acsCount
        delay(1);
      acsCount /= 5000;                                                      // acsCount now eaquals the average of the 5000 readings taken
    //  Serial.print(map(acsCount, 0, 1023, 0, 5000));Serial.println(" mV");   //Print the avg in millivolts
    //  Serial.print("acsCount:");Serial.println(acsCount);                               //Print the actual count value
      return int(acsCount - 512);                                            // return the count difference. 512 is the count for 2.5v which is what the reading should be with no current flow
     /*--------------- Function to read current flowing ------------------*/
    int readCurrent(int PIN)
     int count = 0;
     for (int i=0; i<5; i++)                                        //read 5 analog count samples to stabilise value
       count += analogRead(PIN) - VQ;                               //subtract the offset count VQ to improve accuracy
       delay(1);
     //  Serial.print("raw count..."); Serial.println(count);
     /* Notes on the conversion below
      *  .00488 is the volt value per count of the arduino adc. The analog pin measures from 0 to 5 volt and then assigns the result to
      *  a count from 0 to 1023, thats 1024 counts including zero. If we devide 5v by 1024 we get .oo488 volts for each count.
      *  The (count/5) just gets us the average of our 5 count samples.
      *  So after the first part of the equation  (.00488 * (count/5) is complete we have converted our count reading into volts.
      *  The ACS712 can measure current flow in both directions so it outputs a voltage of  2.5v as it's center point (when no current is flowing).
      *  To allow for this offset we must subtract the 2.5v to center our voltage reading.
      * Thats what the next part does (.00488 * (count/5)) - 2.5) After this is complete we are left with either a negative or  positive voltage
      * reading or a reading of zero for no current flow.
      * NOTE: While the ACS712 is a 5v device it does not use the full 0 to 5v for it's output. The datasheet shows the 20A version has a sensitivity of
      *  100mv per amp, so if we multiply 100mv by 20 we get 2v.  That means the 20A ACS712 has an output range from .5v to 4.5v.
      * So to convert our reading in volts to a reading in amps we need to add the last part ((.00488 * (count/5)) - 2.5)/(sensitivity/1000).
      * The variable sensitivity is defined at the begining of the sketch and holds the ACS712 sensitvity amount, it is stored in millivolts.
      * That is 66mv for the 30amp,  100mv for the 20amp and 185mv for the 5amp. As sensitivity is in millivolts we need to devide it by 1000
      * to convert it back to volts so we can use it in the equation.
      * Now we have our Amps value stored in the float amps. Integers are much easier to work with when checking for zero so we multiply by 1000
      * to convert it to milliamps and return it as an integer.
    //Serial.print("VQ = ..."); Serial.println(VQ);
    //Serial.print("current count..."); Serial.println(count/5);
    //Serial.print("map  milliamps..."); Serial.println(map((count/5), 102, 922, -20000, 20000));
     float amps = ((.00488 * (count/5)) - 2.5) / (sensitivity/1000);
    // Serial.print("float amps..."); Serial.println(amps, 1);
      return int (amps * 1000);                                         // convert to milliamps and return as an integer
    Voltage Sensor:
    If you are not using a voltage sensor module you will need to construct a voltage divider circuit to measure the battery voltage. The reason for this is the Arduino Nano can only tolerate a maximum of 5v on its analog inputs so if we were to connect the 12v battery directly to the input we would most likely destroy the Arduino. A google search will turn up plenty of online voltage divider calculators to help you decide on the correct resistor values.
    Make sure you choose an input voltage level for your divider that is well over the maximum of the voltage you intend to measure.
    Our 12v system is likely to see voltages as high as 14.5v to 15v when charging and perhaps even higher if something has gone wrong so a divider with an input voltage of 25 to 30 volts would be a good choice. So for example if we were to use a combination of a 30k for R1 and 7.5k for R2 an input of 25v would result in an output of 5v.
    You will need to change the value in the sketch code int voltSenseMax = 25000; to represent the input voltage in millivolts of your divider
    I am using millivolts as I use the map function for the conversion later in the sketch, so integers are required. A typical voltage divider circuit is shown below.
    If you are using the voltage sensor module that I have used you will notice it has three terminals on the output side, the one marked with a + symbol is not used, I am not sure why it is even there.
    DS18b20 Temperature Sensors:
    These devices can be used with just two wires but I have used three as it seems this works best in noisy environments. The big advantage of these “one wire” devices is you can have more than one connected to the same input pin on the Arduino. The only requirement is one 4.7k pull-up resistor connected between VDD and DQ. The code I have used is based on the MySensors Dallas Temperature example.
    ACS712 Current Sensing Module:
    First be aware that the pin out can vary on these modules so check before you connect up. You can see in the picture below that the VCC and GND pins are reversed on these two.
    The ACS712 current sensing module is a 5v device that measures current flow and returns a voltage that can be used to determine the amount of current flowing. It is available in three versions 5A, 20A and 30A .
    Importantly for this application they read current flow in both directions. To do this they output 2.5v when no current is flowing and increase or decrease the voltage depending on which direction the current is flowing.
    None of them use the full 0 to 5v range for their output, the 20A version I have used has a sensitivity value of 100mv per 1A of current flow. As this is a 20A device we can multiply the 100mv by 20 and we get 2000mv or a 2v change for 20amps. We know the ACS712 shows an output of 2.5v when no current is flowing so using the 2v we now have the output range from .5v to 4.5v.
    To use this device then we need a way to convert its voltage output to a measurement in amps.
    Here is the basic equation needed
    amps = ((voltsPerCount * count) – offsetVolts) / sensitivityVolts
    Where
    VoltsPerCount is the volt value per count of the Arduino ADC. The ADC measures the voltage present at the analog pin (0 to 5 volt) and then assigns the result as a count from 0 to 1023, that's 1024 counts including zero. If we divide 5v by 1024 we get .00488 volts for each count. So VoltsPerCount = .00488 Volts
    count is the value our Arduino ADC returns after processing the output from the ACS712.
    So after the first part of the equation (.00488 * (count) is complete we have converted our count reading from the arduino into volts.
    The ACS712 can measure current flow in both directions so it outputs a voltage of 2.5v as it's center point (when no current is flowing). To allow for this offset we must subtract the 2.5v to center a 2.5 voltage reading at zero. So offsetVolts = 2.5 Volts
    That's what the next part does ((.00488 * (count)) - 2.5) After this is complete we are left with a negative or positive voltage for current flowing in either direction or a value of zero for no current flow.
    The sensitivity values for the ACS712 are shown on the datasheet as
    185mv per Amp for the 5A
    100mv per Amp for the 20A
    66mv per Amp for the 30A
    So to convert our value in volts to a value in amps we need to add the last part
    ((.00488 * (count)) – 2.5)/sensitivityVolts
    Where sensitivityVolts equals the sensitivity value in volts for the device you are using. In my case the 20A version 100mv = .1 volts
      amps = ((.00488 * (count)) – 2.5) / .1
    Another way to do this would be to use the Arduino map function
    we worked out earlier that the 20A version would output in the range from .5 to 4.5 volts, to convert that to count values we need to divide by .00488 .
    Which gives us .5 / .00488 = 102 and 4.5 / .00488 = 922. map can only work with integers so it is best to use milliamps instead of amps for the output result.
    The Arduino code for the 20A ACS712 would be:
         milliamps =  map(count, 102, 922, -20000, 20000);
    Both of the above methods give very close results so you could use either. I have used the first method as it is easier to select the version of ACS712 you are using by changing the sensitivity.
    The ACS712 is a hall effect device so it can be affected by stray magnetic fields that are nearby. It is best to locate it as far away as possible from any magnetic source to ensure you are getting a true reading. In use I found this was sometimes hard to achieve so I have added code to zero the reading if required. To do this I have used a push button and LED. If you are getting a constant current reading when no current is flowing simply push and hold the button until the led flashes. The sketch will then work out the offset required and apply that to zero the reading. This offset amount will then be saved to the Arduino EEPROM and will be reloaded and used even if the arduino is reset.
    I am using Domoticz as my controller, here is what the end result looks like.
    • mrc-coreM
      mrc-coreM
      mrc-core
      Looking over the schematic you have connected the 5V from the LM2596 directly to the 5V PIN over the arduino.
      Is this correct ?
      Don't we have to connect it to the VIN PIN??
      • mrc-coreM mrc-core
        Is this correct ?
        @mrc-core from what I understand from https://www.arduino.cc/en/Main/ArduinoBoardNano, VIN wants 6-20V, so 5V should be connected to 5V
        • Boots33B
          Boots33B
          Boots33
          Yes @mrc-core as far as I am aware it is fine to supply 5v directly to this pin. If you have a look at the Nano spec page @mfalkvidd has listed above you will see that under the power heading it says
          "The Arduino Nano can be powered via the Mini-B USB connection, 6-20V unregulated external power supply (pin 30), or 5V regulated external power supply (pin 27)."
          Pin 27 is the 5v pin so all should be ok. Of course you must take care that you only supply 5v or you may damage the arduino.
          While the input voltage for the nano VIN is shown as from 6-20V they recommend keeping within 7-12V , when the solar panel is charging the voltage could at times exceed 14V and from what I have read elsewhere I would expect the nano regulator could get quite warm.
          The Lm2596 module has an input voltage of up to 40V and can deliver 2A so will work very well for this application. They are also very cheap so well worth using i think.
          • Boots33B
            Boots33B
            Boots33
            I have made a change to the Sketch. I was saving my data to the same EEPROM positions that MySensors use for their data. So i have now moved well away from that area.
            Edit: No I wasn't so no changes were needed
            googlyeyzG 1 Reply Last reply
            • Boots33B
              Boots33B
              Boots33
              Here is a picture of the finished board
              I have used the PCB designed by @sundberg84
              • Boots33B Boots33
                googlyeyzG
                googlyeyzG
                googlyeyz
                wrote on last edited by googlyeyz
                Are you're sure, that 514 and 515 are vaild values? API documentation states, that pos parameter in saveState/loadState must be between 0 and 255. AFAIK data stored by saveState are written into a separate section of EEPROM, which doesn't interfere with MySensors own configuration data.
                Boots33B 1 Reply Last reply
                • googlyeyzG googlyeyz
                  Boots33B
                  Boots33B
                  Boots33
                  @googlyeyz thanks for that info. I should have looked closer at the API. I originally used positions. 0 and 1 and thought that would conflict but I will now change back
                  • mrc-coreM
                    mrc-coreM
                    mrc-core
                    Hi.
                    I'm having some troubles trying to use the project.
                    I have the solar pannel that goes directly to the solar regulator. In the solar regulator i have the battery connection and the load connection.
                    In the battery connection i have my 12V battery connected and i have connected the arduinos over the load connection.
                    My problem is that i dont see were to connect the ACS712 module on the solar regulator.
                    At this moment i had connect the ACS712 over the load connection in the solar regulator but the values i'm getting are not correct...
                    Can anyone give me a help to fiz this problem.
                    • Boots33B
                      Boots33B
                      Boots33
                      The correct hookup for that type of regulator should look something like the picture below.
                      Remember in this position the acs712 is reading current to and from the battery only. So if you had a load of 5A and your panel was supplying 3A then your readout would show a discharge of 2A
                      If your reading is showing a discharge when it should be showing a charge then just reverse the connections at the acs712.
                      • mrc-coreM
                        mrc-coreM
                        mrc-core
                        Thanks for the reply, i'm going to make the changes tonight.
                        I'm getting readings from 8A to 18A this is not correct.
                        • Boots33B
                          Boots33B
                          Boots33
                          How much current were you expecting to see
                          mrc-coreM 1 Reply Last reply
                          • Boots33B Boots33
                            mrc-coreM
                            mrc-coreM
                            mrc-core
                            @Boots33 To be honest i just thought the values i was getting were too hight since the battery is 12V 20AH and i only have 4 arduino nano with some sensors using the power from the battery.
                            Today with one day having the changes made like you have said to do, i have value from the battery between hight 8.2A and 6.6A low, but the media value is almost always on 7.4A.
                            On the voltage side i'm getting high value 8.8V and low value 7.8V.
                            Is this good values, correct values for a 12V battery ??
                            • Boots33B
                              Boots33B
                              Boots33
                              I don't think those readings are correct. For a 12v battery it should be around 12.7v when full and not being charged. When it is being charged it should be up near 14v. Around 10.9v is considered fully discharged so your readings are way too low for a 12v battery. Your current readings seem too high as well for just a few arduino boards. Can you take some readings with a multimeter to cross check the data. Also check your 5v supply voltage, it is very important for this to be spot on 5v when taking analogue readings.
                              • Boots33B Boots33
                                mrc-coreM
                                mrc-coreM
                                mrc-core
                                @Boots33 Have check the voltage from the battery and is on 12V at this time is discharging the current i couldn't get but tomorrow i'll make new readings and see the values.
                                The 5V supply voltage is set to 5.02V will have to reduce the 0.02V to get just 5V.
                                Thanks for your help.
                                • Boots33B
                                  Boots33B
                                  Boots33
                                  I should think 5.02v will be close enough. What value resistors are you using for your voltage divider.
                                  • Boots33B
                                    Boots33B
                                    Boots33
                                    We appear to be operating in different time zones so have posted a couple of things to try.
                                    The first thing to do is re-check all your wiring, I know you probably have done that already but best to make sure anyway.
                                    Then you should try and isolate the cause of your problems.
                                    lets start with the voltage readings.
                                    This line of code in the sketch
                                    is where you set the maximum input voltage of your voltage divider. If you are not using the 25v voltage sensor module you will need to change the 25000 to suit your voltage divider, by changing that value up or down you can also make adjustments in the voltage reading to fine tune the output. Your reading seems to be out by a few volts so i think you should take a look at the voltage divider first and see if you can locate the reason.
                                    I will show the way to check the 25v module and you can use the same method to work out the values if you have used a different divider.
                                    Because we are using a voltage divider to alter the 12v battery voltage into a 5 volt representation that the Arduino can use we will need to work out what voltage we are expecting to see at pin A0
                                    the formula we need is
                                    ArduinoIn = (BatVolts/voltsPerCount25)*voltsPerCount5
                                    first we need the voltsPerCount25 for the 25v divider, so that will be 25/1024 which = .02441
                                    then we need the voltsPerCount5 for the Arduino 5v input 5/1024 which = .00488
                                    BatVolts is the actual battery voltage, you will need to measure this with your multimeter.
                                    So as an example
                                    If you measured your battery and it has 11.3v
                                    (11.3/.02441)*.00488 = 2.26v
                                    So if the voltage divider is working ok we would expect to see a voltage of around 2.3v at the arduino input. Which would = a count of (2.3/.00488) around 471
                                    You can also remove the comments from the two Serial.print lines in this part of the sketch to see what the Arduino is producing
                                     sample_count = 0;
                                     sum = 0;
                                      sample_count++;
                                      delay(10);
                                    • Boots33B
                                      Boots33B
                                      Boots33
                                      Here are what my graphs look like. You can see your voltage should be a bit higher if all is well
                                      • mrc-coreM
                                        mrc-coreM
                                        mrc-core
                                        Hi. i have read the post's you have made, one problem i have found its on the voltage sensing module don't now why it's not workin, simply dead, i have already bought 3 other modules and now i'm waiting for them to arrieved hope to get them until friday.
                                        Have seen your graphs and they are really differents from mine.
                                        Once again today with the multimeter i've made some readings from the battery and i got values in 13,2V - 12,9V and this values were measured at 19:00
                                        Once again Thanks for helping me
                                        • mrc-coreM
                                          mrc-coreM
                                          mrc-core
                                          I was going to try to build the voltage sensing but i don't have any 7.5K resistor.... i can put 3 10k Resistors in serie to get the 30k Resistor but i cant make the 7.5K.
                                          Can i use one 10K resistor in the place of the 7.5K, will this work ?? or will the values i'll get be rong??
