  3. Homeseer
  4. HomeSeer
HomeSeer
Scheduled Pinned Locked Moved Homeseer
9 Posts 6 Posters 7.6k Views 6 Watching
  • H
    H
    hleidecker
    wrote on last edited by hleidecker
    I've create an HS3 MySensors.org controller plugin.
    http://forums.homeseer.com/showthread.php?t=171425
    Please take the plugin for a spin and let me know how it works. Please note that the plugin is still under development.
    Zip file with a couple of screenshots from the user interface
    Best regards,
    Henrik
    • RJ_MakeR
      RJ_MakeR
      RJ_Make
      Just wanted to bump for all the peeps.. New version released today..
      RJ_Make
      • BrianJB
        BrianJB
        BrianJ
        wrote on last edited by BrianJ
        Hi Henrik,
        Any chance of getting an update to the HS3 plugin? I have built the Irrigation Controller and need the variable support on HS3 to make it functional.
        In your next update will you be able to add support for VAR, example "MyMessage var1valve(CHILD_ID_SPRINKLER, V_VAR1);". This is code from the Irrigation Controller from the MySensor site.
        I really would appreciate the update as I believe others would too.
        Thank you for the plugin!
        Brian
        davros123D 1 Reply Last reply
        • BrianJB BrianJ
          Hi Henrik,
          Brian
          davros123D
          davros123D
          davros123
          Is this dead? It does not appear to be working well with 2.0.
          If so, can the creator please post the source code?
            Mr_sensor
            Hi, I'm a Homeseer user, and I lately discovered the MQTT plugin. Its maintained well and gives you the possibilities you might be looking for. I have seen other users having it in use with there sensors and even switches (sonoff)
            • H
              H
              hleidecker
              I'm still here, but I do not have the time to update the plugin. If some of you would like to help out with the development of the plugin I can grant you access to the git repository?
              Best regards,
              Henrik
              I 1 Reply Last reply
              • H hleidecker
                Best regards,
                Henrik
                I
                I
                iamtheghost
                @hleidecker I would like to see this plug-in continue to be updated. What can I do to help?
                • I iamtheghost
                  davros123D
                  davros123D
                  davros123
                  Hi mate, come over the Homeseer forum thread https://forums.homeseer.com/showthread.php?t=171425&page=21
                  Henrick has provided me access to the source and another member is also requesting access.
                  • davros123D davros123
                    I
                    I
                    iamtheghost
                    @davros123 Hey Davros, I responded to you in the plugin thread over at homeseer.
