  3. In wall - PCB, (AC to DC 5v)
pcbinwall
89 Posts 14 Posters 78.5k Views 24 Watching
  • sundberg84S
    sundberg84S
    @samuel235 You are right - the only problem is size.
    If you find a removable fuse as small as this axial fuse please let me know!
    Most are 2x20mm and the holder are bigger.
    S 1 Reply Last reply
    • sundberg84S
      sundberg84S
      #79
      So today I have been testing temperatures inside a closed compartment with my PCB.
      I drilled a hole in a metal cap to a glass bottle, put AC main through the metal cap and wrapped everything up inside. I then found some insulation material and wrapped the glas bottle up.
      • First test was only minimum components and sleep for two minutes.
      • Second test was the same but i added a LCD screen on maximum background lights and also a relay which switched on and off every 2 minutes sleep cycle.
      • Third test was to remove the sleep and used wait instead so the node was powered all the time.
      No problems so far, max temp during last test was 34,8 dgr C. Here is my numbers:
      Any other ideas or components i can use to try - write a post!
      -- Next
      So... there are some (important) questions ahead i dont know how to answer though...
      • Reliability, when will it fail? (compared to a commersial product?)
      • How will it fail? What is it weakest point?
      • Will my safety components be enough and prevail damage... ?
      • What will happen when it fails?
      Anyone having thoughts... let me know.
      • sundberg84S sundberg84
        Samuel235
        Ahh okay, indeed you're right. However, what is going on the front of the in wall box? Is it still being mounted inside of a wall box, or are you have it concealed away behind the wall where you can't really get to it easily? It isn't behind a light switch/socket?
        MySensors 2.1.1
        • sundberg84S
          sundberg84S
          #81
          @samuel235 depend on what you wants to do with it - its dynamic since you have the pins. If you want to add a relay and button you can hide it in the wallbox and still have the physical button or in the ceiling if you dont need that.
            Samuel235
            @sundberg84 - So It Is essentially a 'multi-use backboard' kind of application. So what I was trying to get to - In the UK we have something called a fused switch (link to image below). Now, you see that little rectangle to the side of the switch, its a fuse inside of a holder. I'm wondering if a possible model for a switch plate like that or any front plate to suit the needs (screen, switch, motion sensor, etc) could be maybe 3d printed, with that fuse holder incorporated into the front late with the board that you have made attached to the back of the front plate in such a manor that you can swap the fuse out without dismantling the whole socket or even soldering. Just a suggestion, well a huge suggestion at that i suppose.
            Fused Switch Image
            MySensors 2.1.1
            • sundberg84S
              sundberg84S
              Im getting quite bad radio performance when i seal this inside some boxes... works much better if I dont have the lid on.
              Does anyone know if the HLK can interfere with the radio (magnetic fields or anything)? EMF?
              Power supply to radio has both 0.1 and 10 caps so I dont hope its spikes or power to radio thats bad.
              Maybe I should move the radio away from AC side?
              m26872M 1 Reply Last reply
                m26872M
                m26872M
                m26872
                @sundberg84 Connect a battery supply instead of the LE33 and see if it helps?
                • sundberg84S
                  sundberg84S
                  #85
                  @m26872 Yea, could try that one - nice thinking.
                  Made a testnode to see some performance on my PCB.
                  Combined temp, hum (DHT), motion and light sensor.
                  Sometimes i forget to think before i build though... not smart to measure temp and put it besides a power supply that generates heat, doh!
                  • sundberg84S
                    sundberg84S
                    Trying to take this to the next level:
                    3d design - first try (ever!).
                    I guess it wont meet any standard since its not completley sealed up - but I want to be able to reach the MYSX connector. Might be OK if I use a female pin header to MysX connector, then it wont be possible to put your finger inside.
                    • sundberg84S
                      sundberg84S
                      So, just a small update - im waiting for new PCB and parts (going to SMD components), almost everything has arrived but some nessecary things still missing.
                      I will leave this project here but not develop this version any more.
                      Instead I will create a new thread with the new SMD version!
                      • DdawmeD
                        DdawmeD
                        Ddawme
                        Hi all. I have been searching for a way to power nodes and stumbled across this project. My question is is this a viable and safe solution if I just recreate the ac-dc portion on perf board? In essence I want to create a good 5v power supply that can be hardwired into my home inside of an electrical box. Not necessarily in the wall but in less accessible places like attics and such.
                        • DdawmeD Ddawme
                          sundberg84S
                          sundberg84S
                          @Ddawme - Hi!
                          I suggest you read all the links in the project for example:
                          http://forum.mysensors.org/topic/1607/safe-in-wall-ac-to-dc-transformers
                          https://forum.mysensors.org/topic/4175/clearance-creepage-and-other-safety-aspects-in-mysensors-pcbs
                          12.5k
