  3. 2.0b gateway - do I have to upgrade sensors/controller also?
5 Posts 2 Posters 1.8k Views 1 Watching
  • signal15S Offline
    signal15S Offline
    signal15
    I have an ESP8266 gateway running 1.5. And everything else runs 1.5. I'm having a problem that upgrading to 2.0b will apparently fix on the gateway. Will I also have to upgrade my sensors to 2.0b? What about the 1.5 plugin on my Vera?
    • signal15S Offline
      signal15S Offline
      signal15
      So, the answer appears to be that all is compatible. I upgraded the gateway to 2.0b, but sensors and Vera are still on 1.5. It all seems to work just fine.
      • T Offline
        T Offline
        tbowmo
        Signing is not backwards compatible, and we are adding new features to 2.0, that isn't available in 1.5.
        So things will break soon..
        signal15S 1 Reply Last reply
        • T tbowmo
          signal15S Offline
          signal15S Offline
          signal15
          @tbowmo
          Wouldn't there still be a way for the 2.0 gateway to identify messages coming from 1.5 sensors and still handle them appropriately, rather than breaking things? I have one sensor that is VERY difficult to get physical access to, and I'm sure some others have similar situations. It would be nice to not have to switch everything over at once.
          • T Offline
            T Offline
            tbowmo
            @signal15
            It's a new major release, that means that we could break compatibility with 1.x. It might work, but it also might not..
