  3. Signing_Soft in dev branch - How to do?
24 Posts 3 Posters 6.3k Views 4 Watching
  • AndurilA Anduril
    @Anticimex I completely agree with you that this would not garantee a good random number. Thanks for explaining all this to me.
    One point still open to me is the AES key. Is it only used for encryption (which does not give a real security in our case)? I suppose it should be also kind of pre shared key, so same value on all nodes? I don't want to enable encryption at the moment, but might be good to already write keys to all nodes in case I want to use it in future.
    AnticimexA
    AnticimexA
    Anticimex
    @Anduril correct. AES is a symmetric crypto which provide some obfuscation. The same key is needed in all nodes. Signing is a per node configuration while encryption is global. None or all in that case.
    • AndurilA Anduril
      AnticimexA
      AnticimexA
      Anticimex
      @Anduril also, AES key can and should be different from HMAC key.
      • AndurilA
        AndurilA
        Anduril
        @Anticimex of course they should be different. I will use my password safe to create independent and strong keys.
        What length should the keys have? And how to add them in sketch? I tried with a 64 character hex key. But when adding it in as pure string or with 0x01,0x02,... the serial says all to be 0x00.
        AnticimexA 1 Reply Last reply
        • AndurilA Anduril
          AnticimexA
          AnticimexA
          Anticimex
          @Anduril the only sketch you add the keys to is the personalizer. And it should already have examples for how the keys should look. The personalizer will store your keys on the device. Then you reflash it with your sketch.
          • AndurilA
            AndurilA
            Anduril
            @Anticimex yeah first flash the personalizer and afterwards my own sketch. But where in the personalizer.ino to add the key? I tried in line 162, but serial monitor shows only
            EEPROM configuration:
            SOFT_HMAC_KEY | 0000000000000000000000000000000000000000000000000000000000000000
            #define USER_SOFT_KEY 0xDC, 0x59, 0x84, 0xC0, 0x5E, 0xDA, 0xD3, 0x2C, 0x59, 0x12, 0xB0, 0xE3, 0x55, 0x75, 0x7C, 0x51, 0xDC, 0x59, 0x84, 0xC0, 0x5E, 0xDA, 0xD3, 0x2C, 0x59, 0x12, 0xB0, 0xE3, 0x55, 0x75, 0x7C, 0x51
            with this definition (only arbitrary key). Is that correct?
            • AndurilA Anduril
              AnticimexA
              AnticimexA
              Anticimex
              @Anduril No, you cannot add spaces to the definition. It has to look exactly like the example. And you must not rename it. It's called MY_SOFT_HMAC_KEY. not USER_SOFT_KEY.
              • AndurilA
                AndurilA
                Anduril
                OK i found the problem, I misunderstood something. I thought I have to add the keys to the enabling command of USER_SOFT_KEY. but there are the real keys some lines below that with correct example how to look like. Now it works and I personalized my first node. Thanks a lot @Anticimex
                • AndurilA Anduril
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @Anduril :thumbsup:
                  • AndurilA
                    AndurilA
                    Anduril
                    @Anticimex Does this also work with a nodeMCU? I tried to personalize my ESP today and got an error:
                    C:\Dropbox\Projekt-Micha\Arduino Sketch\libraries\sha204\sha204_library.cpp: In constructor 'atsha204Class::atsha204Class(uint8_t)':
                    C:\Dropbox\Projekt-Micha\Arduino Sketch\libraries\sha204\sha204_library.cpp:16:18: error: cannot convert 'volatile uint32_t* {aka volatile unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
                      device_port_DDR = portModeRegister(port);
                    C:\Dropbox\Projekt-Micha\Arduino Sketch\libraries\sha204\sha204_library.cpp:18:18: error: cannot convert 'volatile uint32_t* {aka volatile unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
                      device_port_OUT = portOutputRegister(port);
                    C:\Dropbox\Projekt-Micha\Arduino Sketch\libraries\sha204\sha204_library.cpp:20:17: error: cannot convert 'volatile uint32_t* {aka volatile unsigned int*}' to 'volatile uint8_t* {aka volatile unsigned char*}' in assignment
                      device_port_IN = portInputRegister(port);
                    Bibliothek sha204 im Ordner: C:\Dropbox\Projekt-Micha\Arduino Sketch\libraries\sha204 (legacy) wird verwendet
                    Bibliothek MySensors in Version 2.0.0-beta im Ordner: C:\Dropbox\Projekt-Micha\Arduino Sketch\libraries\MySensors  wird verwendet
                    Bibliothek EEPROM in Version 1.0 im Ordner: C:\Users\Mat\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.1.0\libraries\EEPROM  wird verwendet
                    exit status 1
                    Fehler beim Kompilieren.
                    • AndurilA Anduril
                      exit status 1
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @Anduril that's an error from the atsha driver. It is not adapted for "exotic" architectures. I recommend soft signing (or that you create a or with necessary adjustments that are backwards compatible with the Arduino boards currently in use).
                      • AndurilA
                        AndurilA
                        Anduril
                        @Anticimex I thought to be using only soft signing...
                        #include <sha204_library.h>
                        #include <sha204_lib_return_codes.h>
                        #define MY_CORE_ONLY
                        #if DOXYGEN
                        #define LOCK_CONFIGURATION
                        #define LOCK_DATA
                        #define SKIP_KEY_STORAGE
                        #define USER_KEY
                        #define SKIP_UART_CONFIRMATION
                        #define USE_SOFT_SIGNING
                        #define STORE_SOFT_KEY
                        #define STORE_SOFT_SERIAL
                        #define USER_SOFT_SERIAL
                        #define STORE_AES_KEY
                        #define USER_AES_KEY
                        //#define LOCK_CONFIGURATION
                        //#define LOCK_DATA
                        //#define SKIP_KEY_STORAGE
                        //#define USER_KEY
                        #ifdef USER_KEY
                        #ifdef USER_SOFT_KEY
                        I copied the header of the SecurityPersonalizer (just stripped the comments to make it shorter). Do I have activated atsh somewhere without noticing?
                        • AndurilA Anduril
                          #if DOXYGEN
                          #define LOCK_DATA
                          #define USER_KEY
                          //#define LOCK_DATA
                          //#define USER_KEY
                          #ifdef USER_KEY
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @Anduril try ditching the SHA204 library includes at the top. Not sure if they are required for soft signing. Can't remember if I put them there for a reason.... Long time ago I coded for MySensors :(
                          AndurilA 1 Reply Last reply
                          • AnticimexA Anticimex
                            AndurilA
                            AndurilA
                            Anduril
                            @Anticimex Thank you. Deactivating those sha libs made the code compile and work.
                            • AndurilA Anduril
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @Anduril :thumbsup:
