  3. In wall light switch node - Custom PCB
custompcbinwallnodelight switchswitch
245 Posts 15 Posters 183.6k Views 23 Watching
  • Sefi NinioS
    Sefi NinioS
    Sefi Ninio
    Is that related to the circuit for battery level? Or something else?
    What are the differences between the current rev. and what you are working on now?
    S 1 Reply Last reply
    • Sefi NinioS Sefi Ninio
      Samuel235
      It is concerning the serial upload issues i was having. The current revision doesn't include a bootloader and then therefor we can't upload via serial adapter. This in turn makes it unable to program anything once the radio is soldered directly to the board. I'm currently in discussions with GertSanders to try and figure out the issues with my bootloaders. Once this is sorted i will be able to program and debug the node through the serial interface/monitor.
      The next step will be to include a basic voltage divider method of reading the battery level i think. I did do various tests about a month ago and i will re-evaluate the situation on that. I may be a simple voltage divider solution or i may go for some exotic method. Even though the power consumption is slightly more heavy on the voltage divider method, i think i will go ahead and choose this method because of its simplicity for new users to just solder a couple of resistors on board. We will see.
      I do have another project/module in the design phases and a topic thread located here.
      MySensors 2.1.1
      • Sander TeunissenS
        Sander TeunissenS
        Sander Teunissen
        I have a problem finding the right wall switch. Normally they are all laid out for 230 volts, making them really big and requiring a lot of depth. Does anyone have experience with low voltage switches, which look nice and can be used for such projects ?
        Thanks !
        • Sander TeunissenS Sander Teunissen
          Thanks !
          Samuel235
          @Sander-Teunissen, I have these running on a coin cell battery and the sizes for the overall board are: Height: 16mm, Width: 26mm, Length: 48mm. Please note that these sizes are that of the module without insulation. My current working node has its back covered with some fabric to stop it shorting out on the metal backbox. I need to come up with a solution for this. When i order my 3D Printer i'm hoping to fashion some sort of shielding for the rear.
          MySensors 2.1.1
            Samuel235
            I'm currently waiting on some more components to get this module up and running with thanks to @GertSanders providing the bootloader. All being well we will have it completed in the next month to be running with the radio and allowing ISP and FTDI/Serial uploads with the radio all connected.
            Does anyone have any feature requests for this module other than simple battery monitoring?
            MySensors 2.1.1
            • jeylitesJ
              jeylitesJ
              jeylites
              Just wondering, any of you guys looked into touch switches like below 0_1461627979698_HT1j2QTFGhXXXagOFbXh.jpg
              • jeylitesJ jeylites
                Samuel235
                @jeylites, i was going to make a thread on these exact switches soon to discuss the possibility of interfacing them as they run on RF. Keep your eyes open for the thread asap ;).
                I would like to make my own switch front with pressure capacitance at some point but thats for another day.
                MySensors 2.1.1
                scalzS 1 Reply Last reply
                  Samuel235
                  UPDATE - Feature upgrades
                  I have had the materials arrive to attempt to get the latest fixes sorted for this board. Hopefully this will allow us to serial upload while the radio is soldered permanently onto the board. I will update soon as i have attempted this. Keep you posted!
                  MySensors 2.1.1
                  • S Samuel235
                    #225
                    I didn't read this. interesting..one of my current project in progress is exactly this! Designing a special shield for glass plate etc :) the same for controlling one switch or more ;)
                    I have few Livolo that I have disassembled and looked how it works inside. but I'm not fan of 433mhz radio (or that would need some rflink). I'm actually trying to decidde the best way, if I want to hack it, or if I will do my own switch with glass plate I found. because I would like dimming, rfm69, authentication and my shield...
                    • scalzS scalz
                      Samuel235
                      @scalz, If i'm honest I would like to see both. I love to see hacks being perfected, especially in products with such a clean finish as these but then again i also love seeing brand news products being brought to life. Either one you do, i'll be sure to support your ideas!
                      MySensors 2.1.1
                        Samuel235
                        Having some very intermittent issues regarding uploading to this board using an FTDI adapter, 2 in fact. I have tried two adapters now and neither are giving me solid results. I have checked all solder joints and all seems fine. Time to start troubleshooting further. I'm uploading to this board using fuse settings of Low: E2 and High: DE, with a brownout detection point of 1v8. The error that i get 9/10 times is just that the programmer is out of sync. I will report back with my findings.
                        MySensors 2.1.1
                          Samuel235
                          UPDATE
                          We have a working node. We're now able to serial upload and monitor the module with thanks to @GertSanders and his bootloader.
                          So the node currently has 2 switch inputs and that would be the maximum for the hardware interrupt, i may do some investigating to get another port for interrupt to enable us to have 3 switches on the one node.
                          MySensors 2.1.1
                          • S Samuel235
                            UPDATE
                            GertSandersG
                            GertSandersG
                            GertSanders
                            @Samuel235
                            Well, lets all thank the lead designer of the Optiboot boot loader: Bill Westfield !
                            Without his code and repository my compilations would not give any results.
                            • GertSandersG GertSanders
                              @Samuel235
                              Samuel235
                              @GertSanders, get him here and lets all buy him cake and beer!
                              MySensors 2.1.1
                              • XanderX
                                XanderX
                                Xander
                                For more than two switches see: http://www.gammon.com.au/forum/?id=11091
                                I would add a hardware debouncing (R/C) to avoid the problems mentioned in the article.
                                S KoreshK 2 Replies Last reply
                                • XanderX Xander
                                  Samuel235
                                  @Xander Thank you. I may try implimenting this into Rev 3
                                  MySensors 2.1.1
                                  • XanderX Xander
                                    KoreshK
                                    KoreshK
                                    Koresh
                                    It's very good trick, but this circuit allows use of only tact switches. If you are interested - check my schematic (https://www.openhardware.io/view/102/Wall-Switch-Insertable-Node). It allows use of on\off switches too. I've drawn it after a little brainstorm :) I'm not sure it is optimal, but it works very nice.
                                    • KoreshK Koresh
                                      Samuel235
                                      @Koresh I had a quick look earlier, i will study it in more depth later. Thank you!
                                      MySensors 2.1.1
                                        Samuel235
                                        @Koresh, thank you for linking me your module, i'm finally getting around to looking into some depth in this. First of all, i would like to ask something regarding the Exclusive-OR Gates;
                                        I know how the gates work, in this case it uses Exclusive-OR (XOR) Gates, in simple terms, if the inputs are different the output will be HIGH, if the inputs are the same it will be LOW. The input you have connected to GND, could you tell me why that has to be connected to VCC with a resistor, could you not just connect that to GND?
                                        I really like your use of the Schmitt Triggers here, makes the signal nice and sharp on the falling edges for the logic gates to work with.
                                        MySensors 2.1.1
                                          Samuel235
                                          We're currently working on locating the issue that we have with the light switch not being synced with OpenHab correctly. It works as intended but you have to double click to get the light on. We have located the issue lying within OpenHab's item configuration issues. Will post the resulting configuration needed to get this node working 100% perfectly.
                                          MySensors 2.1.1
