  3. Multisensor node using Ceech board
64 Posts 8 Posters 39.6k Views 11 Watching
  • C
    C
    ceech
    Ah, yes. I think i know what the problem is. The LTC4079 has a built-in MPPT power tracking for solar panels and won't charge if the input voltage is below set point. This helps optimizing power extraction from solar panels. If you are using 5V input, then you should adjust the trimmer pot on the board. Like this
    Turn the top round part of the trimmer to the left so that the wiper reaches 5V mark like on the above picture. In other words reduce trimmer resistance to minimum. The other way around is for 18V solar panels.
      MikeF
      @ceech That did it - thanks! :smile:
      Currently charging at c. 90mA:
      Vcc = 3.30V
      Charge current = 89.93mA
      Solar cell voltage = 4.95V
      Battery voltage = 3.62V
      CHRG = 0
      • alexsh1A
        alexsh1A
        alexsh1
        @ceech I have the same problem with the LTC4079 board:
        Running a simplified sketch gives the following:
        Vcc = 3.39V
        Charge current = 2.26mA
        Solar cell voltage = 5.40V
        Battery voltage = 4.11V
        CHRG = 502
        Vcc = 3.42V
        Charge current = 0.25mA
        Solar cell voltage = 5.41V
        CHRG = 500
        Vcc = 3.35V
        Charge current = 0.00mA
        Solar cell voltage = 5.24V
        CHRG = 498
        Vcc = 3.33V
        Solar cell voltage = 5.19V
        Battery voltage = 4.08V
        CHRG = 496
        CHRG is never goes to zero or close and the charging current is low or zero. Shall I try to adjust the same potentiometer as above?
        • C
          C
          ceech
          If the trimmer is in the same position as when new, then yes. Turn it anti-clockwise to reach its minimum value. Either that or raise the input voltage to 11V.
          alexsh1A 1 Reply Last reply
          • C ceech
            alexsh1A
            alexsh1A
            alexsh1
            @ceech I cannot supply more than 6V as this is my solar panel maximum voltage.
            How many turns or degrees shall turn it?
            I did one and a half turn, but it still does not charge the battery. This is the current position.
            • C
              C
              ceech
              wrote on last edited by ceech
              This is a one turn trimmer. Its minimum value is close to 5V mark on one of the above pictures. And its maximum value is next to 18V mark. Since you've turned it more than once, you have to first determine the current wiper position. If you look closely you can see that the turning top is not quite round. One side is a bit flattened. That is the opposite side of the wiper. Now if you take a look at your picture then I think your wiper position is at around 6 or 7V ( to use the same terminology). I would say 20 more degrees to the left and you'll reach 5V.
              You can also measure the trimmer's resistance. Like so
              Find the minimum value between marked points. That is your target resistance value.
              • alexsh1A
                alexsh1A
                alexsh1
                #21
                @ceech - many thanks for above.
                I think I nailed it finally.
                Is the voltage below normal or can that be adjusted somehow?
                Vcc = 3.35V
                Charge current = 34.22mA
                Solar cell voltage = 4.55V
                Battery voltage = 3.80V
                CHRG = 446
                Vcc = 3.39V
                Charge current = 31.87mA
                Solar cell voltage = 4.72V
                Battery voltage = 3.78V
                CHRG = 451
                When does analogue A7 (CHRG) go down to zero or around zero?
                • C
                  C
                  ceech
                  What voltage would you like to adjust?
                  The current is a bit low. What is your panel's maximum available current?
                  The charger is not operating at its full power. Either you are a bit high with the setting on the trimmer or the panel can't supply enough. Charging current should be around 90mA.
                  • alexsh1A
                    alexsh1A
                    alexsh1
                    #23
                    @ceech The solar panal is 6V 4.5W, but right now it is used inside under my table lamp hence a lower voltage (4.7V). I'll to put it in the sun once the weather improves to test it.
                    EDIT: I have not tested the solar panel before in the sun. Obviously, it provides ~4.8V inside and not sure if it will provide closer to 6v in the sun. I purchased it here http://www.ebay.co.uk/itm/281945297221
                    Can I connect 5.5v power supply to the 'solar cell' contacts from a reliable PSU to test the trimmer settings ?
                    • alexsh1A alexsh1
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @ceech
                      Ok, it looks like the trimmer is set to 5.5-6V
                      I am feeding it from 5.5V PSU instead of the solar panal
                      Charge current = 92.28mA
                      Solar cell voltage = 5.54V
                      Battery voltage = 3.82V
                      CHRG = 467
                      • C
                        C
                        ceech
                        #25
                        Sure use your power supply. No problem. If the solar cell is 6V, than leave the trimmer. I think you got it just right.
                        And you were getting 30mA INDOORS? That's great. I'm quite pleased with that information.
                        This means that this sensor board can also be used as Indoors solar harvester.
                        • alexsh1A
                          alexsh1A
                          alexsh1
                          @ceech yes, 30ma indoor, but it is under a direct light. The cut-off voltage is around 4.7V for charging.
                          C 1 Reply Last reply
                          • alexsh1A alexsh1
                            C
                            C
                            ceech
                            @alexsh1 You are at the minimum then. The trimmer was calculated for 4.75V minimum voltage. You might want to raise it a little to get 5.5V-6V MPPT.
                            • C ceech
                              alexsh1A
                              alexsh1A
                              alexsh1
                              @ceech Ok, but what's the tolerance please? I do want the threashhold to be at the minimum level, but meantime I do not want to damage LTC4079.
                              • alexsh1A alexsh1
                                C
                                C
                                ceech
                                @alexsh1 No need to worry about minimum voltage destroying the IC. It is just necessary for the battery to receive full charge that the input voltage is within 4.75V and 20V.
                                • C ceech
                                  alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @ceech Ok so if I have a sunny day and the solar panel is providing 6V, but I have 4.75V MPPT set as a minimum, there is no problem?
                                  • alexsh1A alexsh1
                                    C
                                    C
                                    ceech
                                    @alexsh1 No problem.
                                    • C ceech
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @ceech Thanks for your help!
                                      • alexsh1A alexsh1
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        #33
                                        I am really impressed with this board. On a very grey day outside, I have 4.7V on the solar cell and around 32mA charging current. Cannot wait for the sun to come out to test it.
                                        • rollercontainerR
                                          rollercontainerR
                                          rollercontainer
                                          Hi ceech,
                                          first things first: I have a really small knowledge about charging batteries.
                                          Could you give me a hint how to adopt the floating voltage for a NiCd battery?
                                          By reading the datasheet I only found NiMh with a 3kOhm PROG resistor while yours is 1180Ohm. Do I have to modify him to lower the charge current?
                                          And how about the timer capacitor. I red, that NiCd shouldn't charged too long. You pulled TIMER to ground, so the device will charge forever?
                                          Maybe this problem is solved by the sunset itself?
                                          Again thanks for your contribution!
