  3. Light sensor with battery level problem
5 Posts 2 Posters 1.7k Views 2 Watching
  • derksuhD
    derksuhD
    derksuh
    Hello all,
    I made a light sensor node and uploaded the example sketch. This is working fine!.
    But the node will be supplies by 2 AA batteries so i would like to see the battery level. I tried it like this but it does not work can anyone help me?
    #define NODE_ID 1
    #define CHILD_ID_LIGHT 0
    int lastLightLevel;
      gw.begin(NULL, NODE_ID, false);
      gw.sendSketchInfo("Light Sensor", "1.0");
      int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
      Serial.println(lightLevel);
          gw.send(msg.set(lightLevel));
          lastLightLevel = lightLevel;
      gw.sleep(SLEEP_TIME);
    #define MIN_V 2700
    #define MAX_V 3200
    int batteryPcnt = min(map(readVcc(), MIN_V, MAX_V, 0, 100), 100); // Convert voltage to percentage
    long readVcc() {
    • B
      B
      boozz
      Hi derksuh,
      The code for the battery level should be in the loop, you've put it somewhere outside, although the sketch compiles....
      I think you should have a look at an specific example that comes with the mysensors library. Look at BatteryPoweredSensor. In that you'll find the code for sending the battery level. Now combine that with your sketch.
      good luck,
      Boozz
      • B
        B
        boozz
        I've made some alterations to your code:
        Haven't tested is, but it compiles....:smirk:
            #define NODE_ID 1
            int BATTERY_SENSE_PIN = A1;  // select the input pin for the battery sense point
            int oldBatteryPcnt = 0;
            int lastLightLevel;
              // get the battery Voltage
              //2AA = approx. 3VDC --> sensorValue: 618  (3/5*1023)
              //sensorValue / 6.18 = 100  (%); rough estimate...
              int batteryPcnt = sensorValue / 6.18;
              if (batteryPcnt != oldBatteryPcnt) {
                  oldBatteryPcnt = batteryPcnt;
        • derksuhD
          derksuhD
          derksuh
          wrote on last edited by derksuh
          @boozz
          I see what you did but that means that have to put a resistor in line with the battery and put that on A1. The sketch i meant measured the voltage supplied on vcv in the atmega 328
          • B
            B
            boozz
            @derksuh
            Ok, but it still needs your code to find a place within the loop if I'm not mistaken?
            I'm not a c-programmer, so now and then I'm somewhat confused by the code of others. I learn by doing, which is now and then a process of copy-paste and at other moments analysing how others did it.
            BR,
            Boozz
