  3. Error while compiling the Ethernet Gateway
ethernet gateway
6 Posts 3 Posters 1.8k Views 3 Watching
  • alexsh1A
    alexsh1A
    alexsh1
    I tried to change a few options and now I cannot compile the gateway with "#define WITH_LEDS_BLINKING" in MyConfig.h:
    del:109: error: no matching function for call to 'MySensor::MySensor(MyTransportNRF24&, MyHwATMega328&, int, int, int)'
     MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
    If I disable it, it complies fine. Any idea what the problem may be? I am using Arduino 1.6.7 on Windows
    • ausbremenA
      ausbremenA
      ausbremen
      I have almost the same error when compiling ValloxSensor:
      ValloxSensor:351: error: no matching function for call to 'MySensor::MySensor(int, int)'
      MySensor gw(CE_PIN, CS_PIN);
      Propably the library has changed?
      • alexsh1A
        alexsh1A
        alexsh1
        This only happens when #define WITH_LEDS_BLINKING" in MyConfig.h is set.
        Maybe @hek can help?
        ausbremenA 1 Reply Last reply
          I doubt we'll do any patches in 1.5 now.
          I suggest you make the jump to the development branch. It's soon ready for release.
          • alexsh1A alexsh1
            ausbremenA
            ausbremenA
            ausbremen
            @alexsh1
            in MyConfig.h #define WITH_LEDS_BLINKING" is commented out :(
            • Information LEDs blinking
              // disabled in the gateway.
            // #define WITH_LEDS_BLINKING
            // off when blinking
            • alexsh1A
              alexsh1A
              alexsh1
              In this case I do not understand.
              Perhaps, @hek is right. I have updated a few nodes to v2, but the GW was still v1.5.2
              The problem is that I do want signing and with all debug options, I just cannot get 36Kb compiled on my Arduino Uno (GW).
