  3. Vera
  4. Is HTTPS request from LUUP code possible?
6 Posts 3 Posters 5.2k Views 3 Watching
    samppa
    Does anyone know if I can make HTTPS request from luup code with cookie support?
    I would login to my pages on Verisure website and get the alarm status to be used in automation as home/away switch. I can do this successfully with two wget HTTPS calls: 1) login and 2) access status page with cookies that store the session authentication. But no luck so far with luup.
    So can that even be done with lua from a scene with luup code?
      samppa
      @hek Do you know who could know if saving the cookies is possible with https POST request in luup code?
        Hmm.. this thread might give you a hint on how to do ssl requests from lua. Setting cookies is just a matter of setting the cookie header.
        http://forum.micasaverde.com/index.php/topic,17627.0.html
        But it will require some hacking to pick up the cookie response from the login request and forward it.
          samppa
          Thanks @hek
          I got it working with CURL:
          local pw = 'xxx'
          local un = 'xxx'
          --login request
          local url_1 = 'https://mypages.verisure.com/j_spring_security_check?locale=fi_FI'
          local command_1 = "curl -c '/tmp/log/cmh/cookie.txt' -d 'j_username="..un.."&j_password="..pw.." "..url_1
          local f_1 = assert(io.popen(command_1, 'r'))
          local response_1 = assert(f_1:read('*a'))
          f_1:close(f_1)
          luup.log("Verisure login response: "..response_1)
          --armed status request
          local url_2 = 'https://mypages.verisure.com/remotecontrol?_=14616968783849'
          local command_2 = "curl -k -b '/tmp/log/cmh/cookie.txt' "..url_2
          local f_2 = assert(io.popen(command_2, 'r'))
          local response_2 = assert(f_2:read('*a'))
          f_2:close(f_2)
          luup.log("Verisure status response: "..response_2)
          This returns the alarm status of Verisure system:
          [{"date":"Today 8:47 PM","notAllowedReason":"","name":"Samppa Turunen","changeAllowed":true,"id":1,"label":"Armed stay","type":"ARM_STATE","status":"armedhome"}]
          Now I need to parse the response string into a variable.
          Then I could make a device for it to be used as home / away switch.
          What would be the easiest example to start packaging the code into a device file for Vera? This would be my very first handmade device.. :-)
          F 1 Reply Last reply
            I would have a look at one of the existing plugins to get some inspiration... that's how I learned the device file format and "normal" structure of Vera plugins.
            • S samppa
              Thanks @hek
              local pw = 'xxx'
              local un = 'xxx'
              --login request
              f_1:close(f_1)
              f_2:close(f_2)
              F
              F
              fillefilur
              @samppa This is very interesting, did you Manage to get this to work? Could you please share?
