  3. Help Debug st=fail
Help Debug st=fail
14 Posts 5 Posters 4.4k Views 4 Watching
  • T
    tomkxy
    I think you have a problem with your radio. The st=fail means that the message could not be delivered.
    • mfalkviddM
      Is your gateway working?
      st=fail often means power issues. How are you powering the radio and are you using a capacitor?
      https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help contains more information about troubleshooting and how to read the debug output.
        tcontrada
        @mfalkvidd The gateway works fine as other sensors are being received.
        Since I am using battery power on the Sensebender Micro, there is no capacitor as that would drain the battery.
        What else could be the issue?
        • sundberg84S
          sundberg84S
          A working capacitor does not drain batterypower once charged. Is there one built in the sensebender? If not you should use one.
          It's a range or power issue. Try moving it closer or further away from the gw. If it's the range you might need a repeater.
          • sundberg84S sundberg84
            tcontrada
            @sundberg84 The Sensebender does not have a capacitor, other than bypass.
            Not a range issue either, close or further away does not make a difference.
            It's pretty consistent with the st=fail debug output.
            • mfalkviddM
              What was the result when you added a capacitor?
              • T
                tomkxy
                @tcontrada Do you use signing? What is the range of distances you tried. A couple of weeks ago I had to realize that if put my nodes to near to each other I received transmission failures.
                  tcontrada
                  @mfalkvidd The bypass caps are already installed on the PCB.
                  The SenseBender Micro runs off 2 AA batteries and there is no extra cap on it (that was the design).
                  • T tomkxy
                    tcontrada
                    @tomkxy No signing on my modules...
                    Distance from a few feet to 20, 50, 100 ft. All yield the same result.
                    • T
                      tomkxy
                      Did you try different radios? Anyway, I would try to solder a cap on the radio.
                      • mfalkviddM
                        Yes, the built-in capacitor on the sensebender should be sufficient. Sorry.
                        Have you tried switching the radio with one you know works?
                        • martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          I had a lot of fails on the Sensebender I've installed, and I noticed that I got better transmission when holding the pcb. I then tested to put some aluminium foil with plastic wrap for insulation between the backside of the pcb radio antenna and the Sensbender pcb. This was a winner.
                          There's been a lot of discussion about possible interference from the FTDI 6 pin metal header. I haven't tested my setup without the header or with the header positioned differently, but that's one suspect on my list of culprits.
                            tcontrada
                            @martinhjelmare I think you might be on to something, as I have noticed that other microcontroller modules point the antenna away from the PCB, where as the Sensebender and RF module are overlapping.
                            I will investigate by adding jumper wires from the SenseBender and the RF module to add some separation.
                            Thanks...
