  3. Moisture Sensor example sketch
7 Posts 2 Posters 2.1k Views 2 Watching
  • y4CdW42Ol8Y
    y4CdW42Ol8Y
    y4CdW42Ol8
    Hello, I'm an Arduino newbie.
    This example sketch has the lines:
    #define Digital_Input_Soil_Sensor 3
    #define INTERRUPT DIGITAL_INPUT_SOIL_SENSOR-2
    Looking in the Arduino Reference Help, there is only the interrupts() function.
    I get what the 1st line does.
    What exactly does this 2nd line in code above do? Does it declare Pin 2 as an interrupt (even though nothing is connected to Pin 2 in the Moisture Sensor build example). Does the MySensor library interpret this line?
    Or is it declaring PIN 3 as the interrupt?
    I'm getting confused by the "-2"...
    • y4CdW42Ol8Y
      y4CdW42Ol8Y
      y4CdW42Ol8
      wrote on last edited by y4CdW42Ol8
      Also, since this sketch does not use the Interrputs() and noInterrupts() funtions, does the library take care of handling the interrupt while sleeping? I guess interrupt handling is a bit confusing to me.
      • mfalkviddM
        INTERRUPT is used in the gw.sleep line at the end of the sketch.
        DIGITAL_INPUT_SOIL_SENSOR-2 is an ugly way to change pin number to i terrupt number. In MySensors 2 this has been changed to use digitalPinToInterrupt() instead.
        y4CdW42Ol8Y 1 Reply Last reply
        • y4CdW42Ol8Y
          y4CdW42Ol8Y
          y4CdW42Ol8
          Has MySensors 2 been released? Where can I find it and its documentation?
            y4CdW42Ol8Y
            y4CdW42Ol8Y
            y4CdW42Ol8
            @mfalkvidd
            So in the build example, should the DO pin of the sensor be hooked to D2 of the Arduino?
            • mfalkviddM
              No it has not been released. Looks like the target date is early July. The development version is available at https://github.com/mysensors/Arduino
              • y4CdW42Ol8Y y4CdW42Ol8
                @mfalkvidd
                No, D0 on the moisture sensor is connected to D3 on the Arduino. See the wiring instructions: https://www.mysensors.org/build/moisture#wiring-things-up
