  3. Cobine working DHT22 and LDR with a RelayWithButtonActuator
dht22 ldr relay
36 Posts 4 Posters 8.4k Views 5 Watching
    I think you'll find https://forum.mysensors.org/topic/2597/combining-mysensors-examples and https://forum.mysensors.org/topic/888/combining-sketches useful.
    DickD
    DickD
    Dick
    @mfalkvidd
    Thankt you for the reply, I used the instructions already but After 1 week of testing all solutions and nothing worked, I ask for help. I know, I lerned a lot by experimenting but Now I want a solution so I can try to understand what went wrong, ha ha.
    • DickD
      DickD
      Dick
      is somebody interested in challanging my problem?
      BartEB 1 Reply Last reply
      • DickD Dick
        BartEB
        BartEB
        BartE
        @Dick please note: i did not test it on an actual node but this combination should work
        #define CHILD_ID_HUM1 0
        #define CHILD_ID_HUM2 1
        #define CHILD_ID_TEMP1 3
        #define CHILD_ID_TEMP2 4
        // RelayWithActuator stuff
        #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
        #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
        #define CHILD_ID 5   // Id of the sensor child
        #define RELAY_ON 1
        #define RELAY_OFF 0
        Bounce debouncer = Bounce();
        bool state;
        #define HEARTBEAT       10
        unsigned int     timer = 0;
        // Sleep time between reads (in milliseconds)
        #define SLEEP_TIME      3000
        DHT* dht[2];
        byte sensorPin[2] = {3, 4};
        float lastTemp[2] = {0.0, 0.0};
        float lastHum[2] = {0.0, 0.0};
        boolean metric = true;
        //MyMessage msgHum(CHILD_ID_HUM1, V_HUM);
        //MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP);
          for (int i = 0; i < 2; i++)
            dht[i] = new DHT;
            dht[i]->setup(sensorPin[i]);
          gw.sendSketchInfo("HumidityAndRelay", "1.0");
          gw.present(CHILD_ID_HUM1, S_HUM);
          gw.present(CHILD_ID_HUM2, S_HUM);
          gw.present(CHILD_ID_TEMP1, S_TEMP);
           // Setup the button and Activate internal pull-up
          pinMode(BUTTON_PIN,INPUT_PULLUP);
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
          gw.present(CHILD_ID, S_LIGHT);
          pinMode(RELAY_PIN, OUTPUT);
          state = gw.loadState(CHILD_ID);
          timer = 0;
          timer++;
          if (timer > (SLEEP_TIME / HEARTBEAT))
            // Reset timer again and for the next timed loop
            timer = 0;
              delay(dht[i]->getMinimumSamplingPeriod());
              float temperature = dht[i]->getTemperature();
              if (isnan(temperature))
                Serial.print(F("Failed reading temperature from DHT"));
                Serial.println(i);
              else if (temperature != lastTemp[i])
                lastTemp[i] = temperature;
                if (!metric)
                  temperature = dht[i]->toFahrenheit(temperature);
                //gw.send(msgTemp.set(temperature, i));
                Serial.print(F("T"));
                Serial.print(i);
                Serial.print(F("= "));
              float humidity = dht[i]->getHumidity();
              if (isnan(humidity))
                Serial.print("Failed reading humidity from DHT");
                Serial.println(i);
              else if (humidity != lastHum[i])
                lastHum[i] = humidity;
                //gw.send(msgHum.set(humidity, 1));
                Serial.print(F("H"));
                Serial.print(i);
                Serial.println(humidity);
          // Get the button update state (true if a change was detected)
          if (debouncer.update() && debouncer.read() == 0) {
              gw.send(msg.set(state?false:true), true); // Send new state and request ack back
          gw.wait(HEARTBEAT); //sleep a bit
          if (message.isAck()) {
             // Change relay state
             state = message.getBool();
             // Store state in eeprom
             gw.saveState(CHILD_ID, state);
        DickD 1 Reply Last reply
        • BartEB BartE
          #define RELAY_ON 1
          #define RELAY_OFF 0
          bool state;
          DHT* dht[2];
              dht[i] = new DHT;
            timer = 0;
            timer++;
              timer = 0;
                  Serial.println(i);
                  if (!metric)
                  Serial.print(i);
                  Serial.println(i);
                  Serial.print(i);
          DickD
          DickD
          Dick
          @BartE
          It works fine but the relay does not stay ON after changing the status from "0" to "1".
          Another thing is that the light messuring part is missing, it was the the script I posted. I will try to get it implemented in yours. So If you know how to change the behaviour of the relay, I should appreciate it.
          • DickD Dick
            @BartE
            BartEB
            BartEB
            BartE
            wrote on last edited by BartE
            @Dick how does relay exactly response to the button?
            If you press the button (and keep it down) is the relay turned on?
            or is it switched on when you release the button again?
            The button can be "reversed" connected (on = off and off - on)
            You can play a bit with this line
            if (debouncer.update() && debouncer.read() == HIGH) {
            or
            if (debouncer.update() && debouncer.read() == LOW) {
            and how is the button wired? Does is connect to ground or to Vcc (5 volt) ?
            This sketch requires connection to ground (with internal PULL-UP)
            About the light measuring ?? i just did copy your example from the first post and copied the RelayWithSwitch example in it. (Please notice the message part of sending humidity and temperature are still commented out as in the posted sketch)
            The part i did add my self is the timer stuff (so keeping the switched being probed while the DHT sensor is only probed twice a minute)
            Cheers BartE
            • BartEB BartE
              or
              Cheers BartE
              DickD
              DickD
              Dick
              @BartE The button connect to gnd to switch. if connected to gnd the relay switch for a second and than again in rest, also if I keept the switch to gnd so it is momentory.
              Also about the light sensor integration as stated in my last meassage, I was experimenting I only get an error BOLTED in my script "no matching function for call to 'MyMessage::MyMessage(int, mysensor_data, mysensor_data)'"
              #define CHILD_ID_LIGHT 0
              #define RELAY_PIN 5 // Arduino Digital I/O pin number for relay
              #define BUTTON_PIN A1 // Arduino Digital I/O pin number for button
              #define RELAY_ON 1
              #define RELAY_OFF 0
              bool state;
              MyMessage msg(CHILD_ID,V_LIGHT, V_LIGHT_LEVEL);bolded text
              int lastLightLevel;
              DHT* dht[2];
              dht[i] = new DHT;
              timer = 0;
              timer++;
              timer = 0;
              Serial.println(i);
              if (!metric)
              Serial.print(i);
              Serial.println(i);
              Serial.print(i);
              int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
              //Serial.println(lightLevel);
              //gw.send(msg.set(lightLevel));
                //lastLightLevel = lightLevel;
                Serial.print("L=");
              • DickD Dick
                #define RELAY_ON 1
                #define RELAY_OFF 0
                bool state;
                int lastLightLevel;
                DHT* dht[2];
                dht[i] = new DHT;
                timer = 0;
                timer++;
                timer = 0;
                Serial.println(i);
                if (!metric)
                Serial.print(i);
                Serial.println(i);
                Serial.print(i);
                  Serial.print("L=");
                DickD
                DickD
                Dick
                @Dick
                I get some closer but not complete working. Did also some playing met de debounce but no result. here the script till now with the error log
                italicised texttempHumand_relay:24: error: redefinition of 'MyMessage msg'
                tempHumand_relay:23: error: 'MyMessage msg' previously declared here
                E:\Arduino Projects\tempHumand_relay\tempHumand_relay.ino: In function 'void setup()':
                tempHumand_relay:43: error: 'incomingMessage' was not declared in this scope
                E:\Arduino Projects\tempHumand_relay\tempHumand_relay.ino: In function 'void loop()':
                tempHumand_relay:151: error: a function-definition is not allowed here before '{' token
                tempHumand_relay:171: error: expected '}' at end of input
                and now the code till now
                #define RELAY_ON 1
                #define RELAY_OFF 0
                bool state;
                int lastLightLevel;
                DHT* dht[2];
                dht[i] = new DHT;
                timer = 0;
                timer++;
                timer = 0;
                Serial.println(i);
                if (!metric)
                Serial.print(i);
                Serial.println(i);
                Serial.print(i);
                  Serial.print("L=");
                bolded text
                • BartEB
                  BartEB
                  BartE
                  @Dick
                  Couple of remarks
                  This peice of code tries to declare the same variable twice (msg)
                  change to name to msgLight and msgLightLeven
                  MyMessage msgLight(CHILD_ID,V_LIGHT);
                  MyMessage msgLightLevel(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                  You also have to changethis line:
                  to this
                  gw.send(msgLight.set(state?false:true), true); // Send new state and request ack back
                  Also this line
                  needs to be adapted to
                  gw.send(msgLightLevel.set(lightLevel));
                  And i think the last } needs to be removed
                  Oh and please use the code mark up function for posting source code
                  (by using the </> icon)
                  • BartEB BartE
                    @Dick
                    Couple of remarks
                    to this
                    Also this line
                    DickD
                    DickD
                    Dick
                    thank you Bart, I am learning with these adjustment, how things work together aso. I change the code as you mentioned and still getting verifying errors as included. I hope you can help me so I can finish this, for me not so easy project.
                    tempHumand_relay:130: error: 'msgLightLevel' was not declared in this scope
                    tempHumand_relay:145: error: 'msgLight' was not declared in this scope
                    tempHumand_relay:170: error: expected '}' at end of input
                    • DickD Dick
                      DickD
                      DickD
                      Dick
                      does anyone know how to go on with the final part of this project?
                      • DickD Dick
                        DickD
                        DickD
                        Dick
                        Compilation finished without errors.
                        but I sea nothing on my serial monitor. What could be the issue?The script is now
                        #define RELAY_ON 1
                        #define RELAY_OFF 0
                        bool state;
                        MyMessage msgLight(CHILD_ID,V_LIGHT); MyMessage msgLightLevel(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                        int lastLightLevel;
                        DHT* dht[2];
                        //gw.begin(incomingMessage, AUTO, true);
                        dht[i] = new DHT;
                        timer = 0;
                        timer++;
                        timer = 0;
                        Serial.println(i);
                        if (!metric)
                        //gw.send(msgTemp.set(temperature, );
                        Serial.print(i);
                        Serial.println(i);
                        Serial.print(i);
                          Serial.print("L=");
                        • mfalkviddM
                          Is DEBUG enabled in MyConfig.h? If it isn't, you'll see nothing from MySensors on the serial monitor.
                          If you want your own serial prints to be visible, you need to run
                          Serial.begin(9600);
                          (or whatever speed you want to use in the Serial Monitor) inside setup().
                          You have commented out gw.begin. That means MySensors will not be started. If you don't want to handle incoming messages yet, you can use
                          gw.begin();
                            Serial.begin(9600);
                            gw.begin();
                            DickD
                            DickD
                            Dick
                            debug is enabled and I change gw.begin () and it worked, I see temp and two hum mesurements. But also my relay is uncontroling switching every secunds and the changing is not visible in the monitoring window. has that something to do with the
                            gw.begin(incomming
                            change?
                            • mfalkviddM
                              Try commenting out
                              until you are ready to handle incoming messages.
                                Try commenting out
                                DickD
                                DickD
                                Dick
                                I did what you suggested but no result. Perhaps I have to split-up the project into my initial plan (ldr, and 2x temp/Hum) and make another node for the relay because I do not know to solve the current issue.
                                • alexsh1A
                                  alexsh1A
                                  alexsh1
                                  Try to define BUTTON_PIN to a digital pin and see if it makes a difference.
                                  Change the following in the setup
                                  pinMode(BUTTON_PIN, INPUT);
                                  This is my sketch working on arduino+relay on my corner stand lamp and it is working fine on MySensors 1.5.4
                                  // This code is basically the same as the default RelayWithButtonActuator sketch. The only difference is the pin numbering.
                                  #define RELAY_PIN  3  // Arduino Digital I/O pin number for relay
                                  #define BUTTON_PIN  4  // Arduino Digital I/O pin number for button
                                  #define RELAY_ON 1
                                  #define RELAY_OFF 0
                                  #define NODE_ADDRESS 2
                                  int oldValue=0;
                                  bool state;
                                    gw.begin(incomingMessage, NODE_ADDRESS, true);
                                    gw.sendSketchInfo("Relay & Button", "1.0");
                                   // Setup the button
                                    pinMode(BUTTON_PIN,INPUT);
                                    // Activate internal pull-up
                                  *  Example on how to asynchronously check for new messages from gw
                                    debouncer.update();
                                    // Get the update value
                                    int value = debouncer.read();
                                    if (value != oldValue && value==0) {
                                    oldValue = value;
                                  • alexsh1A alexsh1
                                    #define RELAY_ON 1
                                    #define RELAY_OFF 0
                                    int oldValue=0;
                                    bool state;
                                     // Setup the button
                                      debouncer.update();
                                      oldValue = value;
                                    DickD
                                    DickD
                                    Dick
                                    thank you Alex, it did not work. It is strange, in my topic BartE posted a srcipt what workerd almost perfect. Relay change was good and saw it in the Serial minitor changing from 0 to 1. after adding the LDR stuff it went wrong. So it must be something in the LDR add-on. combining is still not easy for me but I am learning.
                                    alexsh1A 1 Reply Last reply
                                    • DickD Dick
                                      alexsh1A
                                      alexsh1A
                                      alexsh1
                                      @Dick With sketches it is like this sometimes - troubleshooting is time consuming.
                                      I would suggest the following. Try to comment out line by line on the LDR code, upload and see if it works. Try to insert as many Serial.print as you could to print the status of variables to the serial port.
                                      I do not have the LDR so cannot help you much on this one. I have multiple other sketches combined together working just fine.
                                      • alexsh1A alexsh1
                                        DickD
                                        DickD
                                        Dick
                                        @alexsh1
                                        That could I do, thanks for the tip and will do that today. Any idea is welcome :smiley:
                                        • DickD Dick
                                          @alexsh1
                                          BartEB
                                          BartEB
                                          BartE
                                          #22
                                          @Dick I think this issue sits here you use Digital port 0 (which is the serial debug port) i.s.o. Analog port 0 (A0).
                                          Change this line
                                          to
                                           #define LIGHT_SENSOR_ANALOG_PIN A0
                                          And you better also add this line to the setup function
                                          pinMode(LIGHT_SENSOR_ANALOG_PIN, INPUT);
