  3. Cobine working DHT22 and LDR with a RelayWithButtonActuator
dht22 ldr relay
36 Posts 4 Posters 8.4k Views 5 Watching
  • DickD
    DickD
    Dick
    is somebody interested in challanging my problem?
    BartEB 1 Reply Last reply
    • DickD Dick
      BartEB
      BartEB
      BartE
      @Dick please note: i did not test it on an actual node but this combination should work
      #define CHILD_ID_HUM1 0
      #define CHILD_ID_HUM2 1
      #define CHILD_ID_TEMP1 3
      #define CHILD_ID_TEMP2 4
      // RelayWithActuator stuff
      #define RELAY_PIN  4  // Arduino Digital I/O pin number for relay
      #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
      #define CHILD_ID 5   // Id of the sensor child
      #define RELAY_ON 1
      #define RELAY_OFF 0
      Bounce debouncer = Bounce();
      bool state;
      #define HEARTBEAT       10
      unsigned int     timer = 0;
      // Sleep time between reads (in milliseconds)
      #define SLEEP_TIME      3000
      DHT* dht[2];
      byte sensorPin[2] = {3, 4};
      float lastTemp[2] = {0.0, 0.0};
      float lastHum[2] = {0.0, 0.0};
      boolean metric = true;
      //MyMessage msgHum(CHILD_ID_HUM1, V_HUM);
      //MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP);
        for (int i = 0; i < 2; i++)
          dht[i] = new DHT;
          dht[i]->setup(sensorPin[i]);
        gw.sendSketchInfo("HumidityAndRelay", "1.0");
        gw.present(CHILD_ID_HUM1, S_HUM);
        gw.present(CHILD_ID_HUM2, S_HUM);
        gw.present(CHILD_ID_TEMP1, S_TEMP);
         // Setup the button and Activate internal pull-up
        pinMode(BUTTON_PIN,INPUT_PULLUP);
        debouncer.attach(BUTTON_PIN);
        debouncer.interval(5);
        gw.present(CHILD_ID, S_LIGHT);
        pinMode(RELAY_PIN, OUTPUT);
        state = gw.loadState(CHILD_ID);
        timer = 0;
        timer++;
        if (timer > (SLEEP_TIME / HEARTBEAT))
          // Reset timer again and for the next timed loop
          timer = 0;
            delay(dht[i]->getMinimumSamplingPeriod());
            float temperature = dht[i]->getTemperature();
            if (isnan(temperature))
              Serial.print(F("Failed reading temperature from DHT"));
              Serial.println(i);
            else if (temperature != lastTemp[i])
              lastTemp[i] = temperature;
              if (!metric)
                temperature = dht[i]->toFahrenheit(temperature);
              //gw.send(msgTemp.set(temperature, i));
              Serial.print(F("T"));
              Serial.print(i);
              Serial.print(F("= "));
            float humidity = dht[i]->getHumidity();
            if (isnan(humidity))
              Serial.print("Failed reading humidity from DHT");
              Serial.println(i);
            else if (humidity != lastHum[i])
              lastHum[i] = humidity;
              //gw.send(msgHum.set(humidity, 1));
              Serial.print(F("H"));
              Serial.print(i);
              Serial.println(humidity);
        // Get the button update state (true if a change was detected)
        if (debouncer.update() && debouncer.read() == 0) {
            gw.send(msg.set(state?false:true), true); // Send new state and request ack back
        gw.wait(HEARTBEAT); //sleep a bit
        if (message.isAck()) {
           // Change relay state
           state = message.getBool();
           // Store state in eeprom
           gw.saveState(CHILD_ID, state);
      DickD 1 Reply Last reply
      • BartEB BartE
        #define RELAY_ON 1
        #define RELAY_OFF 0
        bool state;
        DHT* dht[2];
            dht[i] = new DHT;
          timer = 0;
          timer++;
            timer = 0;
                Serial.println(i);
                if (!metric)
                Serial.print(i);
                Serial.println(i);
                Serial.print(i);
        DickD
        DickD
        Dick
        @BartE
        It works fine but the relay does not stay ON after changing the status from "0" to "1".
        Another thing is that the light messuring part is missing, it was the the script I posted. I will try to get it implemented in yours. So If you know how to change the behaviour of the relay, I should appreciate it.
        • DickD Dick
          @BartE
          BartEB
          BartEB
          BartE
          wrote on last edited by BartE
          @Dick how does relay exactly response to the button?
          If you press the button (and keep it down) is the relay turned on?
          or is it switched on when you release the button again?
          The button can be "reversed" connected (on = off and off - on)
          You can play a bit with this line
          if (debouncer.update() && debouncer.read() == HIGH) {
          or
          if (debouncer.update() && debouncer.read() == LOW) {
          and how is the button wired? Does is connect to ground or to Vcc (5 volt) ?
          This sketch requires connection to ground (with internal PULL-UP)
          About the light measuring ?? i just did copy your example from the first post and copied the RelayWithSwitch example in it. (Please notice the message part of sending humidity and temperature are still commented out as in the posted sketch)
          The part i did add my self is the timer stuff (so keeping the switched being probed while the DHT sensor is only probed twice a minute)
          Cheers BartE
          • BartEB BartE
            or
            Cheers BartE
            DickD
            DickD
            Dick
            @BartE The button connect to gnd to switch. if connected to gnd the relay switch for a second and than again in rest, also if I keept the switch to gnd so it is momentory.
            Also about the light sensor integration as stated in my last meassage, I was experimenting I only get an error BOLTED in my script "no matching function for call to 'MyMessage::MyMessage(int, mysensor_data, mysensor_data)'"
            #define CHILD_ID_LIGHT 0
            #define RELAY_PIN 5 // Arduino Digital I/O pin number for relay
            #define BUTTON_PIN A1 // Arduino Digital I/O pin number for button
            #define RELAY_ON 1
            #define RELAY_OFF 0
            bool state;
            MyMessage msg(CHILD_ID,V_LIGHT, V_LIGHT_LEVEL);bolded text
            int lastLightLevel;
            DHT* dht[2];
            dht[i] = new DHT;
            timer = 0;
            timer++;
            timer = 0;
            Serial.println(i);
            if (!metric)
            Serial.print(i);
            Serial.println(i);
            Serial.print(i);
            int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
            //Serial.println(lightLevel);
            //gw.send(msg.set(lightLevel));
              //lastLightLevel = lightLevel;
              Serial.print("L=");
            • DickD Dick
              #define RELAY_ON 1
              #define RELAY_OFF 0
              bool state;
              int lastLightLevel;
              DHT* dht[2];
              dht[i] = new DHT;
              timer = 0;
              timer++;
              timer = 0;
              Serial.println(i);
              if (!metric)
              Serial.print(i);
              Serial.println(i);
              Serial.print(i);
                Serial.print("L=");
              DickD
              DickD
              Dick
              @Dick
              I get some closer but not complete working. Did also some playing met de debounce but no result. here the script till now with the error log
              italicised texttempHumand_relay:24: error: redefinition of 'MyMessage msg'
              tempHumand_relay:23: error: 'MyMessage msg' previously declared here
              E:\Arduino Projects\tempHumand_relay\tempHumand_relay.ino: In function 'void setup()':
              tempHumand_relay:43: error: 'incomingMessage' was not declared in this scope
              E:\Arduino Projects\tempHumand_relay\tempHumand_relay.ino: In function 'void loop()':
              tempHumand_relay:151: error: a function-definition is not allowed here before '{' token
              tempHumand_relay:171: error: expected '}' at end of input
              and now the code till now
              #define RELAY_ON 1
              #define RELAY_OFF 0
              bool state;
              int lastLightLevel;
              DHT* dht[2];
              dht[i] = new DHT;
              timer = 0;
              timer++;
              timer = 0;
              Serial.println(i);
              if (!metric)
              Serial.print(i);
              Serial.println(i);
              Serial.print(i);
                Serial.print("L=");
              bolded text
              • BartEB
                BartEB
                BartE
                @Dick
                Couple of remarks
                This peice of code tries to declare the same variable twice (msg)
                change to name to msgLight and msgLightLeven
                MyMessage msgLight(CHILD_ID,V_LIGHT);
                MyMessage msgLightLevel(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                You also have to changethis line:
                to this
                gw.send(msgLight.set(state?false:true), true); // Send new state and request ack back
                Also this line
                needs to be adapted to
                gw.send(msgLightLevel.set(lightLevel));
                And i think the last } needs to be removed
                Oh and please use the code mark up function for posting source code
                (by using the </> icon)
                • BartEB BartE
                  @Dick
                  Couple of remarks
                  to this
                  Also this line
                  DickD
                  DickD
                  Dick
                  thank you Bart, I am learning with these adjustment, how things work together aso. I change the code as you mentioned and still getting verifying errors as included. I hope you can help me so I can finish this, for me not so easy project.
                  tempHumand_relay:130: error: 'msgLightLevel' was not declared in this scope
                  tempHumand_relay:145: error: 'msgLight' was not declared in this scope
                  tempHumand_relay:170: error: expected '}' at end of input
                  • DickD Dick
                    DickD
                    DickD
                    Dick
                    does anyone know how to go on with the final part of this project?
                    • DickD Dick
                      DickD
                      DickD
                      Dick
                      Compilation finished without errors.
                      but I sea nothing on my serial monitor. What could be the issue?The script is now
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      bool state;
                      MyMessage msgLight(CHILD_ID,V_LIGHT); MyMessage msgLightLevel(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
                      int lastLightLevel;
                      DHT* dht[2];
                      //gw.begin(incomingMessage, AUTO, true);
                      dht[i] = new DHT;
                      timer = 0;
                      timer++;
                      timer = 0;
                      Serial.println(i);
                      if (!metric)
                      //gw.send(msgTemp.set(temperature, );
                      Serial.print(i);
                      Serial.println(i);
                      Serial.print(i);
                        Serial.print("L=");
                      • mfalkviddM
                        Is DEBUG enabled in MyConfig.h? If it isn't, you'll see nothing from MySensors on the serial monitor.
                        If you want your own serial prints to be visible, you need to run
                        Serial.begin(9600);
                        (or whatever speed you want to use in the Serial Monitor) inside setup().
                        You have commented out gw.begin. That means MySensors will not be started. If you don't want to handle incoming messages yet, you can use
                        gw.begin();
                          Serial.begin(9600);
                          gw.begin();
                          DickD
                          DickD
                          Dick
                          debug is enabled and I change gw.begin () and it worked, I see temp and two hum mesurements. But also my relay is uncontroling switching every secunds and the changing is not visible in the monitoring window. has that something to do with the
                          gw.begin(incomming
                          change?
                          • mfalkviddM
                            Try commenting out
                            until you are ready to handle incoming messages.
                              Try commenting out
                              DickD
                              DickD
                              Dick
                              I did what you suggested but no result. Perhaps I have to split-up the project into my initial plan (ldr, and 2x temp/Hum) and make another node for the relay because I do not know to solve the current issue.
                              • alexsh1A
                                alexsh1A
                                alexsh1
                                Try to define BUTTON_PIN to a digital pin and see if it makes a difference.
                                Change the following in the setup
                                pinMode(BUTTON_PIN, INPUT);
                                This is my sketch working on arduino+relay on my corner stand lamp and it is working fine on MySensors 1.5.4
                                // This code is basically the same as the default RelayWithButtonActuator sketch. The only difference is the pin numbering.
                                #define RELAY_PIN  3  // Arduino Digital I/O pin number for relay
                                #define BUTTON_PIN  4  // Arduino Digital I/O pin number for button
                                #define RELAY_ON 1
                                #define RELAY_OFF 0
                                #define NODE_ADDRESS 2
                                int oldValue=0;
                                bool state;
                                  gw.begin(incomingMessage, NODE_ADDRESS, true);
                                  gw.sendSketchInfo("Relay & Button", "1.0");
                                 // Setup the button
                                  pinMode(BUTTON_PIN,INPUT);
                                  // Activate internal pull-up
                                *  Example on how to asynchronously check for new messages from gw
                                  debouncer.update();
                                  // Get the update value
                                  int value = debouncer.read();
                                  if (value != oldValue && value==0) {
                                  oldValue = value;
                                • alexsh1A alexsh1
                                  #define RELAY_ON 1
                                  #define RELAY_OFF 0
                                  int oldValue=0;
                                  bool state;
                                   // Setup the button
                                    debouncer.update();
                                    oldValue = value;
                                  DickD
                                  DickD
                                  Dick
                                  thank you Alex, it did not work. It is strange, in my topic BartE posted a srcipt what workerd almost perfect. Relay change was good and saw it in the Serial minitor changing from 0 to 1. after adding the LDR stuff it went wrong. So it must be something in the LDR add-on. combining is still not easy for me but I am learning.
                                  alexsh1A 1 Reply Last reply
                                  • DickD Dick
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    @Dick With sketches it is like this sometimes - troubleshooting is time consuming.
                                    I would suggest the following. Try to comment out line by line on the LDR code, upload and see if it works. Try to insert as many Serial.print as you could to print the status of variables to the serial port.
                                    I do not have the LDR so cannot help you much on this one. I have multiple other sketches combined together working just fine.
                                    • alexsh1A alexsh1
                                      DickD
                                      DickD
                                      Dick
                                      @alexsh1
                                      That could I do, thanks for the tip and will do that today. Any idea is welcome :smiley:
                                      • DickD Dick
                                        @alexsh1
                                        BartEB
                                        BartEB
                                        BartE
                                        #22
                                        @Dick I think this issue sits here you use Digital port 0 (which is the serial debug port) i.s.o. Analog port 0 (A0).
                                        Change this line
                                        to
                                         #define LIGHT_SENSOR_ANALOG_PIN A0
                                        And you better also add this line to the setup function
                                        pinMode(LIGHT_SENSOR_ANALOG_PIN, INPUT);
                                        • BartEB BartE
                                          Change this line
                                          to
                                          DickD
                                          DickD
                                          Dick
                                          have not tried all the given options but started again with all the previous advises of Bart. Noe I still struggle with an error
                                          "gw.begin(incomingMessage, AUTO, true);" in mij script. I checkt the "{ }" over and over again but it must be something else.
                                          can anybody take a look?
                                           #define BUTTON_PIN 6 // Arduino Digital I/O pin number for button
                                           #define RELAY_ON 1
                                           #define RELAY_OFF 0
                                          int oldValue=0;
                                           bool state;
                                           int lastLightLevel;
                                          DHT* dht[2];
                                           dht[i] = new DHT;
                                          timer = 0;
                                           timer++;
                                           timer = 0;
                                           Serial.println(i);
                                           if (!metric)
                                           Serial.print(i);
                                           Serial.println(i);
                                           Serial.print(i);
                                            Serial.print("L=");
                                          debouncer.update();
                                            oldValue = value;
