  3. Cobine working DHT22 and LDR with a RelayWithButtonActuator
dht22 ldr relay
36 Posts 4 Posters 8.4k Views 5 Watching
  • DickD Dick
    @BartE The button connect to gnd to switch. if connected to gnd the relay switch for a second and than again in rest, also if I keept the switch to gnd so it is momentory.
    Also about the light sensor integration as stated in my last meassage, I was experimenting I only get an error BOLTED in my script "no matching function for call to 'MyMessage::MyMessage(int, mysensor_data, mysensor_data)'"
    #define CHILD_ID_HUM1 0
    #define CHILD_ID_HUM2 1
    #define CHILD_ID_TEMP1 3
    #define CHILD_ID_TEMP2 4
    #define CHILD_ID_LIGHT 0
    // RelayWithActuator stuff
    #define RELAY_PIN 5 // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN A1 // Arduino Digital I/O pin number for button
    #define CHILD_ID 5 // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    Bounce debouncer = Bounce();
    bool state;
    MyMessage msg(CHILD_ID,V_LIGHT, V_LIGHT_LEVEL);bolded text
    int lastLightLevel;
    #define HEARTBEAT 10
    unsigned int timer = 0;
    // Sleep time between reads (in milliseconds)
    #define SLEEP_TIME 3000
    DHT* dht[2];
    byte sensorPin[2] = {3, 4};
    float lastTemp[2] = {0.0, 0.0};
    float lastHum[2] = {0.0, 0.0};
    boolean metric = true;
    //MyMessage msgHum(CHILD_ID_HUM1, V_HUM);
    //MyMessage msgTemp(CHILD_ID_TEMP1, V_TEMP);
    for (int i = 0; i < 2; i++)
    dht[i] = new DHT;
    dht[i]->setup(sensorPin[i]);
    gw.sendSketchInfo("HumidityAndRelay", "1.0");
    gw.present(CHILD_ID_HUM1, S_HUM);
    gw.present(CHILD_ID_HUM2, S_HUM);
    gw.present(CHILD_ID_TEMP1, S_TEMP);
    // Setup the button and Activate internal pull-up
    pinMode(BUTTON_PIN,INPUT_PULLUP);
    debouncer.attach(BUTTON_PIN);
    debouncer.interval(5);
    gw.present(CHILD_ID, S_LIGHT);
    pinMode(RELAY_PIN, OUTPUT);
    state = gw.loadState(CHILD_ID);
    timer = 0;
    timer++;
    if (timer > (SLEEP_TIME / HEARTBEAT))
    // Reset timer again and for the next timed loop
    timer = 0;
    delay(dht[i]->getMinimumSamplingPeriod());
    float temperature = dht[i]->getTemperature();
    if (isnan(temperature))
    Serial.print(F("Failed reading temperature from DHT"));
    Serial.println(i);
    else if (temperature != lastTemp[i])
    lastTemp[i] = temperature;
    if (!metric)
    temperature = dht[i]->toFahrenheit(temperature);
    //gw.send(msgTemp.set(temperature, i));
    Serial.print(F("T"));
    Serial.print(i);
    Serial.print(F("= "));
    float humidity = dht[i]->getHumidity();
    if (isnan(humidity))
    Serial.print("Failed reading humidity from DHT");
    Serial.println(i);
    else if (humidity != lastHum[i])
    lastHum[i] = humidity;
    //gw.send(msgHum.set(humidity, 1));
    Serial.print(F("H"));
    Serial.print(i);
    Serial.println(humidity);
    int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
    //Serial.println(lightLevel);
    //gw.send(msg.set(lightLevel));
      //lastLightLevel = lightLevel;
      Serial.print("L=");
    // Get the button update state (true if a change was detected)
    if (debouncer.update() && debouncer.read() == 0) {
    gw.send(msg.set(state?false:true), true); // Send new state and request ack back
    gw.wait(HEARTBEAT); //sleep a bit
    if (message.isAck()) {
    // Change relay state
    state = message.getBool();
    // Store state in eeprom
    gw.saveState(CHILD_ID, state);
    DickD
    DickD
    Dick
    @Dick
    I get some closer but not complete working. Did also some playing met de debounce but no result. here the script till now with the error log
    italicised texttempHumand_relay:24: error: redefinition of 'MyMessage msg'
    tempHumand_relay:23: error: 'MyMessage msg' previously declared here
    E:\Arduino Projects\tempHumand_relay\tempHumand_relay.ino: In function 'void setup()':
    tempHumand_relay:43: error: 'incomingMessage' was not declared in this scope
    E:\Arduino Projects\tempHumand_relay\tempHumand_relay.ino: In function 'void loop()':
    tempHumand_relay:151: error: a function-definition is not allowed here before '{' token
    tempHumand_relay:171: error: expected '}' at end of input
    and now the code till now
    #define RELAY_ON 1
    #define RELAY_OFF 0
    bool state;
    int lastLightLevel;
    DHT* dht[2];
    dht[i] = new DHT;
    timer = 0;
    timer++;
    timer = 0;
    Serial.println(i);
    if (!metric)
    Serial.print(i);
    Serial.println(i);
    Serial.print(i);
      Serial.print("L=");
    bolded text
    • BartEB
      BartEB
      BartE
      wrote on last edited by BartE
      @Dick
      Couple of remarks
      This peice of code tries to declare the same variable twice (msg)
      change to name to msgLight and msgLightLeven
      MyMessage msgLight(CHILD_ID,V_LIGHT);
      MyMessage msgLightLevel(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
      You also have to changethis line:
      to this
      gw.send(msgLight.set(state?false:true), true); // Send new state and request ack back
      Also this line
      needs to be adapted to
      gw.send(msgLightLevel.set(lightLevel));
      And i think the last } needs to be removed
      Oh and please use the code mark up function for posting source code
      (by using the </> icon)
      DickD 1 Reply Last reply
      • BartEB BartE
        @Dick
        Couple of remarks
        to this
        Also this line
        DickD
        DickD
        Dick
        thank you Bart, I am learning with these adjustment, how things work together aso. I change the code as you mentioned and still getting verifying errors as included. I hope you can help me so I can finish this, for me not so easy project.
        tempHumand_relay:130: error: 'msgLightLevel' was not declared in this scope
        tempHumand_relay:145: error: 'msgLight' was not declared in this scope
        tempHumand_relay:170: error: expected '}' at end of input
        • DickD Dick
          DickD
          DickD
          Dick
          does anyone know how to go on with the final part of this project?
          • DickD Dick
            DickD
            DickD
            Dick
            Compilation finished without errors.
            but I sea nothing on my serial monitor. What could be the issue?The script is now
            #define RELAY_ON 1
            #define RELAY_OFF 0
            bool state;
            MyMessage msgLight(CHILD_ID,V_LIGHT); MyMessage msgLightLevel(CHILD_ID_LIGHT, V_LIGHT_LEVEL);
            int lastLightLevel;
            DHT* dht[2];
            //gw.begin(incomingMessage, AUTO, true);
            dht[i] = new DHT;
            timer = 0;
            timer++;
            timer = 0;
            Serial.println(i);
            if (!metric)
            //gw.send(msgTemp.set(temperature, );
            Serial.print(i);
            Serial.println(i);
            Serial.print(i);
              Serial.print("L=");
            • mfalkviddM
              Is DEBUG enabled in MyConfig.h? If it isn't, you'll see nothing from MySensors on the serial monitor.
              If you want your own serial prints to be visible, you need to run
              Serial.begin(9600);
              (or whatever speed you want to use in the Serial Monitor) inside setup().
              You have commented out gw.begin. That means MySensors will not be started. If you don't want to handle incoming messages yet, you can use
              gw.begin();
                Serial.begin(9600);
                gw.begin();
                DickD
                DickD
                Dick
                debug is enabled and I change gw.begin () and it worked, I see temp and two hum mesurements. But also my relay is uncontroling switching every secunds and the changing is not visible in the monitoring window. has that something to do with the
                gw.begin(incomming
                change?
                • mfalkviddM
                  Try commenting out
                  until you are ready to handle incoming messages.
                    Try commenting out
                    DickD
                    DickD
                    Dick
                    I did what you suggested but no result. Perhaps I have to split-up the project into my initial plan (ldr, and 2x temp/Hum) and make another node for the relay because I do not know to solve the current issue.
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      Try to define BUTTON_PIN to a digital pin and see if it makes a difference.
                      Change the following in the setup
                      pinMode(BUTTON_PIN, INPUT);
                      This is my sketch working on arduino+relay on my corner stand lamp and it is working fine on MySensors 1.5.4
                      // This code is basically the same as the default RelayWithButtonActuator sketch. The only difference is the pin numbering.
                      #define RELAY_PIN  3  // Arduino Digital I/O pin number for relay
                      #define BUTTON_PIN  4  // Arduino Digital I/O pin number for button
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      #define NODE_ADDRESS 2
                      int oldValue=0;
                      bool state;
                        gw.begin(incomingMessage, NODE_ADDRESS, true);
                        gw.sendSketchInfo("Relay & Button", "1.0");
                       // Setup the button
                        pinMode(BUTTON_PIN,INPUT);
                        // Activate internal pull-up
                      *  Example on how to asynchronously check for new messages from gw
                        debouncer.update();
                        // Get the update value
                        int value = debouncer.read();
                        if (value != oldValue && value==0) {
                        oldValue = value;
                      • alexsh1A alexsh1
                        #define RELAY_ON 1
                        #define RELAY_OFF 0
                        int oldValue=0;
                        bool state;
                         // Setup the button
                          debouncer.update();
                          oldValue = value;
                        DickD
                        DickD
                        Dick
                        thank you Alex, it did not work. It is strange, in my topic BartE posted a srcipt what workerd almost perfect. Relay change was good and saw it in the Serial minitor changing from 0 to 1. after adding the LDR stuff it went wrong. So it must be something in the LDR add-on. combining is still not easy for me but I am learning.
                        alexsh1A 1 Reply Last reply
                        • DickD Dick
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @Dick With sketches it is like this sometimes - troubleshooting is time consuming.
                          I would suggest the following. Try to comment out line by line on the LDR code, upload and see if it works. Try to insert as many Serial.print as you could to print the status of variables to the serial port.
                          I do not have the LDR so cannot help you much on this one. I have multiple other sketches combined together working just fine.
                          • alexsh1A alexsh1
                            DickD
                            DickD
                            Dick
                            @alexsh1
                            That could I do, thanks for the tip and will do that today. Any idea is welcome :smiley:
                            BartEB 1 Reply Last reply
                            • DickD Dick
                              @alexsh1
                              BartEB
                              BartEB
                              BartE
                              #22
                              @Dick I think this issue sits here you use Digital port 0 (which is the serial debug port) i.s.o. Analog port 0 (A0).
                              Change this line
                              to
                               #define LIGHT_SENSOR_ANALOG_PIN A0
                              And you better also add this line to the setup function
                              pinMode(LIGHT_SENSOR_ANALOG_PIN, INPUT);
                              • BartEB BartE
                                Change this line
                                to
                                DickD
                                DickD
                                Dick
                                have not tried all the given options but started again with all the previous advises of Bart. Noe I still struggle with an error
                                "gw.begin(incomingMessage, AUTO, true);" in mij script. I checkt the "{ }" over and over again but it must be something else.
                                can anybody take a look?
                                 #define BUTTON_PIN 6 // Arduino Digital I/O pin number for button
                                 #define RELAY_ON 1
                                 #define RELAY_OFF 0
                                int oldValue=0;
                                 bool state;
                                 int lastLightLevel;
                                DHT* dht[2];
                                 dht[i] = new DHT;
                                timer = 0;
                                 timer++;
                                 timer = 0;
                                 Serial.println(i);
                                 if (!metric)
                                 Serial.print(i);
                                 Serial.println(i);
                                 Serial.print(i);
                                  Serial.print("L=");
                                debouncer.update();
                                  oldValue = value;
                                • mfalkviddM
                                  #24
                                  The auto-formatting feature in the Arduino IDE is very useful for makin the code easier to read (both for yourself and for us forum readers) and spot mistakes.
                                  What is the error message you are getting?
                                    DickD
                                    DickD
                                    Dick
                                    three errors. hope you can give an advise!
                                    laatste:163: error: 'msg' was not declared in this scope
                                    At global scope:
                                    laatste:172: error: expected declaration before '}' token
                                    laatste:47: error: 'incomingMessage' was not declared in this scope
                                    • DickD Dick
                                      At global scope:
                                      BartEB
                                      BartEB
                                      BartE
                                      #26
                                      @Dick
                                      msg should become msgLight
                                      gw.send(msgLight.set(state ? false : true), true); // Send new state and request ack back
                                      and move one } just below this line
                                      to the very end of you sketch
                                      DickD 3 Replies Last reply
                                      • BartEB BartE
                                        @Dick
                                        DickD
                                        DickD
                                        Dick
                                        no errors anymore. I test the script now and will also put the changes you posted befor.
                                        • BartEB BartE
                                          @Dick
                                          DickD
                                          DickD
                                          Dick
                                          tested and also add the changes of your message (9hrs ago).
                                          What I see on the serial monitor is, temp (2x), hum (2x) and light level but nothing of the relay. it is still clicking but no change in the logging from 1 to 0 etc. I already adjusted the script this morning with the 'RelayWithButtonActuator Example'. so only the relay part is not working and not visible in the serial log. Any idea?
