  3. One Arduino with multiple functions
17 Posts 9 Posters 11.7k Views 2 Watching
  • T
    twisted
    Just be careful and check each additional sensor as you add it. I wasted a lot of time fault finding something I would have found easily if I had tested one at a time. FYI I so far have combined quite a few different things successfully, but still struggle with the humidity and relays together for some reason.
    • ? A Former User
      Sounds good, just what I wanted to hear actually.
      jkaJ
      jkaJ
      jka
      • BulldogLowellB
        BulldogLowellB
        BulldogLowell
        Hi everyone,
        I am trying to add an LCD display to a (working with my Vera) multi-Sensor with both a hygrometer and barometer. The barometer uses pins 4 & 5 of my nano and the LCD needs those two pins too. It is possible to just simply wire both of the devices to the I2C bus on pins 4 & 5? Do I need any andy specific additions to my sketch?
        • DvbitD
          DvbitD
          Dvbit
          I am a total newbie in arduino but I would guess that the only common pin among different attached sensors could be the ground one.
          The other pins transport sensor specific tensions levels (related to event for that specific sensor) so I uses you should use other pins and modify your sketch accordingly to monitor each pin for each function. All of that in the same main arduino polling loop.
          Experts please correct me if I am wrong .
          • DvbitD Dvbit
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @Dvbit
            Thanks for the reply. From what I understand,these two pins are special, and are capable of serial communication via I2C. That protocol does allow for communications with multiple devices, but everything I have read are examples of like devices (e.g. multiple barometers) an they solve the problem of communication with some switch or multiplexing. This is because the master cannot talk to multiple devices, just one at a time.
            Since the barometer is an input device and the display is an output device, I would think I could connect them both without getting into complicated circuitry because the barometer will ignore the output from the Arduino and the LCD will not be transmitting back to the Arduino, just handshaking. But I really don't know...
            • greglG
              greglG
              gregl
              Im in no way an expert.....;-) but...
              I dont think its got anything to do with input/output of an i2c device...its that each device will have an address on the bus.
              eg: my LCD uses a "byvac" 12c board... it has an address 0x21
              I have another LCD board with the address 0x27
              There is a sketch to show the addresses. (also some good info on i2c)
              http://playground.arduino.cc/Main/I2cScanner
              connect one device at a time and run the scannner... should show you each address.
              IIRC i can through some "out of my league commands" change the address of one of my LCD's ...never needed too though.
              I gotta ask ...why would you need to connect multiple barometers? one inside and one outside??
              • greglG gregl
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                @gregl
                thanks. I think I'm on your page.
                i am using the barometer and want to add the LCD. They both use I2C. I hadn't thought about scanning the barometer, I did already scan the LCD (I had to to get it to display).
                Let me try that!
                • T
                  tjay4x4
                  Hi everyone,
                  Thanks Hek for very interesting project!
                  Could anybody write combined sketch for double "Pulse water meter" on one Arduino for hot and cold water meter?
                  marceltrapmanM hekH 2 Replies Last reply
                  • T tjay4x4
                    Hi everyone,
                    marceltrapmanM
                    marceltrapmanM
                    marceltrapman
                    Why not try it yourself?
                    Fulltime Servoy Developer
                    • T tjay4x4
                      Hi everyone,
                      @tjay4x4
                      I suggest you don't use sleep-mode and try to create the sketch yourself by looking at the provided example. You will need to attach and use one of the other digitail input pins for the "extra" pulse sensor and duplicate some code (for presentation and reading of your new pin).
                      • T
                        tjay4x4
                        Couse I think many interested people could be beginers with arduino like me, and needs some examples to understand how to combine diferent sketchs on one Arduino. Of course if nobody answer I find "how to..."
                          wrote on last edited by hek
                          Guess it is much easier if you try yourself and if you bump into problems you ask specific questions on what you find hard understand or can't solve yourself ;)
                          There are some good books on the basics of Arduino and programming. I linked a couple of them here:
                          http://www.mysensors.org/build/sensor_api#buying-guide
                          • T tjay4x4
                            marceltrapmanM
                            marceltrapmanM
                            marceltrapman
                            wrote on last edited by marceltrapman
                            @tjay4x4 I completely understand.
                            Until about 3-4 weeks ago I did not even know what an Arduino was.
                            Yet, here I am creating a plugin for Indigo (I did not know about Indigo until about 8 weeks ago) and creating/testing very basic sensors.
                            Today I started creating my first 'home-grown' sensor and guess what: You have to try it to understand it :)
                            I know from experience that you can ask just about anything when you get stuck...
