  3. One Arduino with multiple functions
17 Posts 9 Posters 11.7k Views 2 Watching
  • DvbitD
    DvbitD
    Dvbit
    I am a total newbie in arduino but I would guess that the only common pin among different attached sensors could be the ground one.
    The other pins transport sensor specific tensions levels (related to event for that specific sensor) so I uses you should use other pins and modify your sketch accordingly to monitor each pin for each function. All of that in the same main arduino polling loop.
    Experts please correct me if I am wrong .
    • DvbitD Dvbit
      BulldogLowellB
      BulldogLowellB
      BulldogLowell
      @Dvbit
      Thanks for the reply. From what I understand,these two pins are special, and are capable of serial communication via I2C. That protocol does allow for communications with multiple devices, but everything I have read are examples of like devices (e.g. multiple barometers) an they solve the problem of communication with some switch or multiplexing. This is because the master cannot talk to multiple devices, just one at a time.
      Since the barometer is an input device and the display is an output device, I would think I could connect them both without getting into complicated circuitry because the barometer will ignore the output from the Arduino and the LCD will not be transmitting back to the Arduino, just handshaking. But I really don't know...
      • greglG
        greglG
        gregl
        Im in no way an expert.....;-) but...
        I dont think its got anything to do with input/output of an i2c device...its that each device will have an address on the bus.
        eg: my LCD uses a "byvac" 12c board... it has an address 0x21
        I have another LCD board with the address 0x27
        There is a sketch to show the addresses. (also some good info on i2c)
        http://playground.arduino.cc/Main/I2cScanner
        connect one device at a time and run the scannner... should show you each address.
        IIRC i can through some "out of my league commands" change the address of one of my LCD's ...never needed too though.
        I gotta ask ...why would you need to connect multiple barometers? one inside and one outside??
        • greglG gregl
          BulldogLowellB
          BulldogLowellB
          BulldogLowell
          @gregl
          thanks. I think I'm on your page.
          i am using the barometer and want to add the LCD. They both use I2C. I hadn't thought about scanning the barometer, I did already scan the LCD (I had to to get it to display).
          Let me try that!
          • T
            tjay4x4
            Hi everyone,
            Thanks Hek for very interesting project!
            Could anybody write combined sketch for double "Pulse water meter" on one Arduino for hot and cold water meter?
            marceltrapmanM hekH 2 Replies Last reply
            • T tjay4x4
              Hi everyone,
              marceltrapmanM
              marceltrapmanM
              marceltrapman
              Why not try it yourself?
              Fulltime Servoy Developer
              • T tjay4x4
                Hi everyone,
                @tjay4x4
                I suggest you don't use sleep-mode and try to create the sketch yourself by looking at the provided example. You will need to attach and use one of the other digitail input pins for the "extra" pulse sensor and duplicate some code (for presentation and reading of your new pin).
                • T
                  tjay4x4
                  Couse I think many interested people could be beginers with arduino like me, and needs some examples to understand how to combine diferent sketchs on one Arduino. Of course if nobody answer I find "how to..."
                    wrote on last edited by hek
                    Guess it is much easier if you try yourself and if you bump into problems you ask specific questions on what you find hard understand or can't solve yourself ;)
                    There are some good books on the basics of Arduino and programming. I linked a couple of them here:
                    http://www.mysensors.org/build/sensor_api#buying-guide
                    • T tjay4x4
                      marceltrapmanM
                      marceltrapmanM
                      marceltrapman
                      wrote on last edited by marceltrapman
                      @tjay4x4 I completely understand.
                      Until about 3-4 weeks ago I did not even know what an Arduino was.
                      Yet, here I am creating a plugin for Indigo (I did not know about Indigo until about 8 weeks ago) and creating/testing very basic sensors.
                      Today I started creating my first 'home-grown' sensor and guess what: You have to try it to understand it :)
                      I know from experience that you can ask just about anything when you get stuck...
