  3. Adding second sensor overlapping first?
3 Posts 2 Posters 825 Views 2 Watching
  • Norm DresslerN
    Norm DresslerN
    Norm Dressler
    I have a sensor working - humidity/temp. Very basic. Trying to add a second of the exact same type.
    In my sketch, I've tried to manually add:
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define NODE_ADDRESS 2
    and
    gw.sendSketchInfo("SecondLvl", "2.0");
    I already have a node 1 and it doesn't seem to be taking my node_address? I tried deleting the json file in Home Assistant, restart, add sensor 1. Everything works... try to add the second one and it gets named 1 as well?!
    Jun 20 16:09:47 raspberrypi hass[11575]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=6,pt=1,l=1,sg=0:0
    Jun 20 16:09:47 raspberrypi hass[11575]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:send: 0-0-1-1 s=255,c=3,t=6,pt=0,l=1,sg=0,st=ok:M
    Jun 20 16:09:49 raspberrypi hass[11575]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=11,pt=0,l=9,sg=0:SecondLvl
    Jun 20 16:09:49 raspberrypi hass[11575]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=255,c=3,t=12,pt=0,l=3,sg=0:2.0
    Jun 20 16:09:49 raspberrypi hass[11575]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=0,c=0,t=7,pt=0,l=0,sg=0:
    Jun 20 16:09:50 raspberrypi hass[11575]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=0,t=6,pt=0,l=0,sg=0:
    Jun 20 16:09:50 raspberrypi hass[11575]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=1,c=1,t=0,pt=7,l=5,sg=0:26.0
    Jun 20 16:09:50 raspberrypi hass[11575]: INFO:homeassistant.components.mysensors:Adding new devices: <Entity SecondLvl 1 1: None>
    Jun 20 16:09:50 raspberrypi hass[11575]: INFO:mysensors.mysensors:n:0 c:0 t:3 s:9 p:read: 1-1-0 s=0,c=1,t=1,pt=7,l=5,sg=0:33.0
    Jun 20 16:09:50 raspberrypi hass[11575]: INFO:homeassistant.components.mysensors:Adding new devices: <Entity SecondLvl 1 0: None>
    • Norm DresslerN Norm Dressler
      and
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @Norm-Dressler
      The node id is stored in the eeprom after the first successful connection. If you have previously used the arduino with another node id, you should clear the eeprom before uploading the new sketch. There's an example sketch for clearing the eeprom in the library.
      Also, what is your begin statement, where you try to assign node id 2?
      Looking at the log your node has node id 1, and the sensor is added as "sketch_name_1_0". So everything looks to be working at the HA side.
      • Norm DresslerN
        Norm DresslerN
        Norm Dressler
        Thanks - that's what I needed to point me in the right direction. Issue is resolved now :)
