  3. Reporting Battery Level
23 Posts 6 Posters 12.8k Views 8 Watching
  • Fat FlyF
    Fat FlyF
    Fat Fly
    Okay. I understand but how to add this piece from software to each sketch? Each what arduino powerted from batteryes.
    • Fat FlyF Fat Fly
      How to add to sketch this feature? I use Domoticz controller and serial gateway. Nodes is Arduino mini pro 3,3V with batteries. Today i use door open/close sensor, elecricity meter, moisture sensor.
      AWIA
      AWIA
      AWI
      @Fat-Fly Easiest way is to use the Vcc library by @Yveaux
      • Fat FlyF
        Fat FlyF
        Fat Fly
        This is better. I need cut off Arduino voltage regulator and power led ?
        AWIA 1 Reply Last reply
        • Fat FlyF Fat Fly
          AWIA
          AWIA
          AWI
          @Fat-Fly To save power you can... but not needed for the Vcc library to work if you power your pro-mini from the vcc pin ;-)
          • Fat FlyF
            Fat FlyF
            Fat Fly
            Ok. I try to write sketch.
            • Fat FlyF
              Fat FlyF
              Fat Fly
              wrote on last edited by AWI
               * Simple binary switch example
               * Connect button or door/window reed switch between
               * digitial I/O pin 3 (BUTTON_PIN below) and GND.
               * http://www.mysensors.org/build/binary
              #include <Vcc.h>
              #define CHILD_ID 3
              #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
              Bounce debouncer = Bounce();
              int oldValue=-1;
              //battery voltage
              const float VccExpected   = 3.0;
              const float VccCorrection = 2.860/2.92;  // Measured Vcc by multimeter divided by reported Vcc
              Vcc vcc(VccCorrection);
              static int oldBatteryPcnt = 0;
                gw.begin();
               // Setup the button
                pinMode(BUTTON_PIN,INPUT);
                // Activate internal pull-up
                debouncer.attach(BUTTON_PIN);
                debouncer.interval(5);
                gw.present(CHILD_ID, S_DOOR);
                debouncer.update();
                // Get the update value
                int value = debouncer.read();
                if (value != oldValue) {
                   // Send in the new value
                   oldValue = value;
                  int batteryPcnt = (int)vcc.Read_Perc(VccExpected);
                  if (oldBatteryPcnt != batteryPcnt)
                      oldBatteryPcnt = batteryPcnt;
              • Fat FlyF
                Fat FlyF
                Fat Fly
                Verification successful says codebender. I do not know working this or not. I can't try. Only in home after working day.
                • Fat FlyF
                  Fat FlyF
                  Fat Fly
                  https://codebender.cc/sketch:337094 This is modified electricity meter sketch with battery level .
                  NuubiN 1 Reply Last reply
                  • Fat FlyF Fat Fly
                    NuubiN
                    NuubiN
                    Nuubi
                    @Fat-Fly Nice, interested to try this also.
                    Any idea how long the batteries will last? Electricity meters tend to blink quite often, so not that much sleep..
                    • Fat FlyF
                      Fat FlyF
                      Fat Fly
                      wrote on last edited by Fat Fly
                      At the moment i try this with 2xAA recargeable batteryes but no luck. Gnd and vcc pin. Not working , not reported. if i find batterys.... I search. All remotes is AAA :( 2.68volts from recargeable AA's. where is the fish ?
                      • Fat FlyF
                        Fat FlyF
                        Fat Fly
                        From recargeable 2x AA and 2,68V not working.
                        • Fat FlyF
                          Fat FlyF
                          Fat Fly
                          I bought 2AA batteries. Working.Domoticz devices page report battery level 3. How to see battery level graph ?
                          • Fat FlyF Fat Fly
                            AWIA
                            AWIA
                            AWI
                            @Fat-Fly to report battery voltage you have to create a S_MULTIMETER sensor and send the voltage with V_VOLTAGE.
                            Sendbatterylevel only changes the battery level in Domoticz in % and can not be shown separate.
                            Tot use your arduino with low voltages you need to change the fuse settings (BOD) with an ISP programmer.
                            • Fat FlyF
                              Fat FlyF
                              Fat Fly
                              How to i do this ?
                              • Fat FlyF Fat Fly
                                How to i do this ?
                                AWIA
                                AWIA
                                AWI
                                @Fat-Fly I will post some code later when I get to a pc. :eyes:
                                Fat FlyF 1 Reply Last reply
                                • AWIA AWI
                                  Fat FlyF
                                  Fat FlyF
                                  Fat Fly
                                  This is great. I do not find from google search. My mother tongue is Estonian :)
                                  • Fat FlyF Fat Fly
                                    AWIA
                                    AWIA
                                    AWI
                                    @Fat-Fly "Estonia: Between East, West and the World" ;-)
                                    These are the lines of code which should do the trick... you need to put them in the right spot yourself
                                    #define VOLTAGE_CHILD_ID 		5
                                    MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);	// Node voltage
                                    gw.present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery " );
                                    float voltage = vcc.Read_Volts() ;
                                    gw.send(voltageMsg.set(voltage,2));				//send battery in Volt
                                    • Fat FlyF
                                      Fat FlyF
                                      Fat Fly
                                      Estonia between world and russia. :)
                                      • alexsh1A
                                        alexsh1A
                                        alexsh1
                                        @Fat-Fly I am not sure how you intend to arrange your electricity pulse meter reading, but in my case I had to wire Pro Mini 5V to mains or otherwise recharge a battery every 5-7 days. I think you can do the total kWh and putting Pro Mini to sleep, but you cannot have total consumption kWh and current consumption kW with sleeping.
                                        • Fat FlyF
                                          Fat FlyF
                                          Fat Fly
                                          Yesterday this not working. KW reader is too away from gateway.My house is lenght is 22m. Electricity meter is one end of house and gateway is center house. can i use repeater on something other. I use for this nrf with antenna.
