  3. Reporting Battery Level
23 Posts 6 Posters 12.8k Views 8 Watching
  • Fat FlyF Fat Fly
    This is better. I need cut off Arduino voltage regulator and power led ?
    AWIA
    AWIA
    AWI
    @Fat-Fly To save power you can... but not needed for the Vcc library to work if you power your pro-mini from the vcc pin ;-)
    • Fat FlyF
      Fat FlyF
      Fat Fly
      Ok. I try to write sketch.
      • Fat FlyF
        Fat FlyF
        Fat Fly
        wrote on last edited by AWI
         * Simple binary switch example
         * Connect button or door/window reed switch between
         * digitial I/O pin 3 (BUTTON_PIN below) and GND.
         * http://www.mysensors.org/build/binary
        #include <Vcc.h>
        #define CHILD_ID 3
        #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
        Bounce debouncer = Bounce();
        int oldValue=-1;
        //battery voltage
        const float VccExpected   = 3.0;
        const float VccCorrection = 2.860/2.92;  // Measured Vcc by multimeter divided by reported Vcc
        Vcc vcc(VccCorrection);
        static int oldBatteryPcnt = 0;
          gw.begin();
         // Setup the button
          pinMode(BUTTON_PIN,INPUT);
          // Activate internal pull-up
          debouncer.attach(BUTTON_PIN);
          debouncer.interval(5);
          gw.present(CHILD_ID, S_DOOR);
          debouncer.update();
          // Get the update value
          int value = debouncer.read();
          if (value != oldValue) {
             // Send in the new value
             oldValue = value;
            int batteryPcnt = (int)vcc.Read_Perc(VccExpected);
            if (oldBatteryPcnt != batteryPcnt)
                oldBatteryPcnt = batteryPcnt;
        • Fat FlyF
          Fat FlyF
          Fat Fly
          Verification successful says codebender. I do not know working this or not. I can't try. Only in home after working day.
          • Fat FlyF
            Fat FlyF
            Fat Fly
            https://codebender.cc/sketch:337094 This is modified electricity meter sketch with battery level .
            NuubiN 1 Reply Last reply
            • Fat FlyF Fat Fly
              NuubiN
              NuubiN
              Nuubi
              @Fat-Fly Nice, interested to try this also.
              Any idea how long the batteries will last? Electricity meters tend to blink quite often, so not that much sleep..
              • Fat FlyF
                Fat FlyF
                Fat Fly
                wrote on last edited by Fat Fly
                At the moment i try this with 2xAA recargeable batteryes but no luck. Gnd and vcc pin. Not working , not reported. if i find batterys.... I search. All remotes is AAA :( 2.68volts from recargeable AA's. where is the fish ?
                • Fat FlyF
                  Fat FlyF
                  Fat Fly
                  From recargeable 2x AA and 2,68V not working.
                  • Fat FlyF
                    Fat FlyF
                    Fat Fly
                    I bought 2AA batteries. Working.Domoticz devices page report battery level 3. How to see battery level graph ?
                    AWIA 1 Reply Last reply
                    • Fat FlyF Fat Fly
                      AWIA
                      AWIA
                      AWI
                      @Fat-Fly to report battery voltage you have to create a S_MULTIMETER sensor and send the voltage with V_VOLTAGE.
                      Sendbatterylevel only changes the battery level in Domoticz in % and can not be shown separate.
                      Tot use your arduino with low voltages you need to change the fuse settings (BOD) with an ISP programmer.
                      • Fat FlyF
                        Fat FlyF
                        Fat Fly
                        How to i do this ?
                        • Fat FlyF Fat Fly
                          How to i do this ?
                          AWIA
                          AWIA
                          AWI
                          @Fat-Fly I will post some code later when I get to a pc. :eyes:
                          Fat FlyF 1 Reply Last reply
                          • AWIA AWI
                            Fat FlyF
                            Fat FlyF
                            Fat Fly
                            This is great. I do not find from google search. My mother tongue is Estonian :)
                            • Fat FlyF Fat Fly
                              AWIA
                              AWIA
                              AWI
                              @Fat-Fly "Estonia: Between East, West and the World" ;-)
                              These are the lines of code which should do the trick... you need to put them in the right spot yourself
                              #define VOLTAGE_CHILD_ID 		5
                              MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);	// Node voltage
                              gw.present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery " );
                              float voltage = vcc.Read_Volts() ;
                              gw.send(voltageMsg.set(voltage,2));				//send battery in Volt
                              • Fat FlyF
                                Fat FlyF
                                Fat Fly
                                Estonia between world and russia. :)
                                • alexsh1A
                                  alexsh1A
                                  alexsh1
                                  @Fat-Fly I am not sure how you intend to arrange your electricity pulse meter reading, but in my case I had to wire Pro Mini 5V to mains or otherwise recharge a battery every 5-7 days. I think you can do the total kWh and putting Pro Mini to sleep, but you cannot have total consumption kWh and current consumption kW with sleeping.
                                  • Fat FlyF
                                    Fat FlyF
                                    Fat Fly
                                    Yesterday this not working. KW reader is too away from gateway.My house is lenght is 22m. Electricity meter is one end of house and gateway is center house. can i use repeater on something other. I use for this nrf with antenna.
                                    • Fat FlyF Fat Fly
                                      @Fat-Fly check the "range issues" troubleshooting flowchart at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help
