  3. NRF24L01+: bad range of few meters
10 Posts 3 Posters 5.3k Views 4 Watching
  • vgaV
    vgaV
    vga
    Hi everyone,
    i´m using the following setup:
    Controller:
    Raspberry Pi 2 B, powered with an USB- Power-Supply Max. 2A
    Serial Gateway (v1.5):
    Arduino Nano 5V directly connected via USB,
    NRF24L01+ with SMA Antenna direct soldered to the Arduino, capacitor 0,47uF between GND and Vin
    Sensor-Node (v1.5):
    Arduino Pro Mini 3,3V, powered with new a battery: (one "SAFT" AA-Format cell, 3,6V 2000mAh)
    NRF24L01+ without external Antenna (and also tried the mod with soldered 83,3mm wire antenna), capacitor 0,47uF between GND and Vin
    Environment:
    Controller and gateway indoor directly behind a window (double shielded), sensor outside:
    5m away from window: connection OK.
    7m away from window: connection FAIL.
    What can i do, for better range:?
    • Is there a better way for powering the gateway or the battery sensor (but sensor needs to by battery powered, and power efficient)?
    • Any other hardware mods?
    • I´ve read in another post something about NRF24-library settings:
      radio.setPALevel(RF24_PA_MAX);
      radio.setDataRate(RF24_250KBPS);
      radio.setPayloadSize(4);
      radio.setChannel(2);
      radio.setRetries(15, 15);
    Is there a way to set these parameters via MySensors Library?
    • vgaV vga
      Hi everyone,
      Controller:
      Sensor-Node (v1.5):
      Environment:
      This channel could possibly overlap with WiFi channels. Better use high channel numbers, like default 76.
      • vgaV
        vgaV
        vga
        thanks, i would take channel 76, but how can i set these parameters, also the other ones?
        in MyConfig.h i see the following:
        #define MY_RF24_CHANNEL	76
        ...but what about the PayloadSize? can i set this too?
        • vgaV vga
          @vga if you don't change the channel it will default to 76.
          Why are you configuring the nRF directly by calling the driver methods? Are you using the mysensors library at all?
          vgaV 1 Reply Last reply
          • YveauxY Yveaux
            vgaV
            vgaV
            vga
            do you mean the radio.set lines?
            this is only a quote from another post. i don't do it this way.
            i´m using My Sensors library v2.0 beta.
            I´ve found 3 parameters in the MyConfig.h, and they all set by default, as i see.
            But ni can´t find the payload size. Can i set it anywhere, or see what value it is set to?
            • vgaV vga
              @vga when using the library you should not have to call any of the radio.xxx methods. The #defines are sufficient.
              The size of the payload is automatically determined by the library, and depends on what you transmit in the message.
              • vgaV
                vgaV
                vga
                sure, as i said, i don´t use the radio.set methods.
                So are there any other hardware tipps?
                • NickBuilderN
                  NickBuilderN
                  NickBuilder
                  Hi @vga!
                  This thread presents a lot of hardware considerations related to the nrf24l01 module.
                  The nrf24 should then perhaps be supplied separately instead of through a Pi or Arduino supply pin. I will go for this approach myself. Even though your USB supply provides 2A the 3V pin is of course limited to perhaps 50 mA?!
                  • vgaV
                    vgaV
                    vga
                    i´ve got the solution!
                    in MyConfig.h i have set:
                    #define RF24_PA_LEVEL_GW   RF24_PA_MAX
                    befor it it was LOW! :smirk:
                    • NickBuilderN
                      NickBuilderN
                      NickBuilder
                      Ok, so you see an improvement?
                      In the referenced thread Korttoma actually mentioned that one could expect a lower range if you set the power to max as the Arduino is not able to supply enough power.
                      Good to know, learning by doing. 😊
