  3. Problems with first sensors
62 Posts 9 Posters 34.9k Views 11 Watching
  • blebbensB
    blebbensB
    blebbens
    A few days ago I build a serial gateway using an arduino nano clone and a NRF24L01 with antenna. My raspberry pi 3 is running domoticz as controller.
    Domoticz seems to recognize the serial mysensors gateway (USB) and shows version 2.0.
    For testing I build a motion sensor (HC-SR501, arduino nano, NRF24L01) and uploaded a an unmodified mysensors example-sketch. Under setup->hardware->gateway->setup (german translation) I was able to see a child no. 255 (doesn´t the example used child ID 1?), which was named S_ARDUINO_REPEATER_NODE version 1 instead of motion sensor. I was never able to see this in devices.
    Tried to upload the sketch once again with a clean installation of the arduino IDE from arduino.cc. Installed the newest IDE version and mysensors 2.0.
    But, now on compiling a sketch, the IDE tells me:
    In file included from /Users/XX 1/Dropbox/Arduino/MySensors/MotionSensor/MotionSensor.ino:2:0:
    /Users/XX/Documents/Arduino/libraries/MySensors/MySensors.h:287:4: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
    /Users/XX 1/Dropbox/Arduino/MySensors/MotionSensor/MotionSensor.ino:41:22: fatal error: MySensor.h: No such file or directory
    compilation terminated.
    exit status 1
    The sketch:
    #include <MyConfig.h>
     * Version 1.0 - Henrik Ekblad
    // Enable debug prints
    // #define MY_DEBUG
    // Initialize motion message
    void presentation()  {
      present(CHILD_ID, S_MOTION);
      // Read digital motion value
      Serial.println(tripped);
      sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    I am very frustrated. Why don´t I see the sensor in domiticz and why does the IDE not compile the sketch. This error occurs on my mac and my windows pc.
    Little help would be great... thanks.
      Hello.
      I don't think this is an unmodified sketch ;) There are multiple wrong things like the two different Mysensors includes etc.. Here is the right one : https://github.com/mysensors/MySensors/blob/development/examples/MotionSensor/MotionSensor.ino
      And you need to config your sketch. You can read this, it can help you:
      https://www.mysensors.org/about/arduino#installing-the-sensor-libraries
      https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
      • blebbensB
        blebbensB
        blebbens
        Oh, I thought the examples are ready for mysensors library 2.0. So, first step I have to do is to change some lines in the sketch...
        But, I already used the "manage library" function in the IDE and installed mysensors 2.0. So, I am wondering why all these errors still come up.
        • blebbensB
          blebbensB
          blebbens
          Your new code from github for the motion compiled without any problems.
          2 days ago I uploaded the serial gateway sketch from https://www.mysensors.org/build/serial_gateway. This sketch is not compatible to mysensor library 2.0 ?
          I found some new example code on github, but at the moment, I don´t really know how to change the sketch to 2.0 compatibility.
            yes sketch are ready, the sketch from example folder is ok.
            perhaps you didn't paid attention, but imho you have changed something...Look at the top of your sketch, mysensors is two times included and not right. And if you look at the sketch I've linked (which is from example folder), you will see it's done once like this
            #include  <Mysensors.h>
            And you have this in your :
              ah ok. I don't know for these sketch. But those from the arduino example folder should be ok.
              If not, clean your arduino install, and install it again. with the help from the links above, this should be ok.
              I hope it helps.
              • blebbensB
                blebbensB
                blebbens
                Nano seems to be damaged. Trying a new one tomorrow.
                One more question, please: I downloadee mysensors library 20.
                As I am using a serial hateway, I notices the gateway sketch uses the old gw.xxx structure. Do I have to modfiy the sketch on my own for preparing it for library 2.0? (My programming skills are under development). On githib the sketch is very basic, there is missing a lot?!
                  where do you see that gateway use old structure?
                  the serial gw sketch you have in arduino ide should be the same as github. if not, you have not well updated your lib..
                  don't worry, the sketch is very basic but it works. it's because lot of stuff is hidden for easing the lib use.
                  • blebbensB
                    blebbensB
                    blebbens
                    To me as a newbie it is a bit confusing...
                    This sketch comes from mysensors.org:
                     * LEDs (OPTIONAL):
                    #define NO_PORTB_PINCHANGES
                    #include <MySigningNone.h>
                    #include <MyTransportRFM69.h>
                    #include <MyTransportNRF24.h>
                    //#include <MyHwATMega328.h>
                    #include <MyParserSerial.h>
                    #include <stdarg.h>
                    #include <PinChangeInt.h>
                    #include "GatewayUtil.h"
                    //MyTransportRFM69 transport;
                    //MySigningNone signer;
                    //MySigningAtsha204 signer;
                    // Hardware profile
                    MyHwATMega328 hw;
                    #ifdef WITH_LEDS_BLINKING
                    MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
                    char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
                    int inputPos = 0;
                    boolean commandComplete = false;  // whether the string is complete
                    void parseAndSend(char *commandBuffer);
                    void output(const char *fmt, ... ) {
                       va_list args;
                       va_start (args, fmt );
                       va_end (args);
                       Serial.print(serialBuffer);
                      // Add interrupt for inclusion button to pin
                      PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
                      // Send startup log message on serial
                      serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
                      checkInclusionFinished();
                      if (commandComplete) {
                        // A command wass issued from serial interface
                        // We will now try to send it to the actuator
                        parseAndSend(gw, inputString);
                        inputPos = 0;
                      SerialEvent occurs whenever a new data comes in the
                     hardware serial RX.  This routine is run between each
                     time loop() runs, so using delay inside loop can delay
                     response.  Multiple bytes of data may be available.
                    void serialEvent() {
                      while (Serial.available()) {
                        // get the new byte:
                        char inChar = (char)Serial.read();
                        // if the incoming character is a newline, set a flag
                        // so the main loop can do something about it:
                        if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
                          if (inChar == '\n') {
                            inputString[inputPos] = 0;
                            commandComplete = true;
                            // add it to the inputString:
                            inputString[inputPos] = inChar;
                            inputPos++;
                            inputPos = 0;
                    Looks like the sketch for mysensors library 1.x.
                    And this one is from github:
                     * LEDs (OPTIONAL):
                     * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
                    // Enable serial gateway
                    #define MY_GATEWAY_SERIAL
                    #if F_CPU == 8000000L
                    #define MY_BAUD_RATE 38400
                    // Flash leds on rx/tx/err
                    // Set blinking period
                    // Enable inclusion mode
                    To me ot looks like this is meant for mysensors.org 2.0, which looks incomplete. Think, they have to be merged ?
                      I know the difference between the two versions. But, as I said, no need to merge.
                      Please note:
                      • The examples you found on mysensors.org are, i guess, not all updated yet. but mysensors team is working hard, it's lot of work ;)
                      • The example from github are compiled for mysensors 2. You think this is incomplete but that's wrong. The stuff you think missing is simply hidden. For easing noob experience.
                      • So only 1.x older user sketch need to be updated to 2.0. If you are starting with mysensors, i don't think you have older sketch to convert, isn't it?
                      • if not already done., use https://www.mysensors.org/about/arduino#installing-the-sensor-libraries to install the latest lib from Arduino software
                      • Then no need to go to mysensors or git to get the latest examples. It's available in Arduino software. File Menu\Examples\Mysensors
                      For discovering Arduino software, or arduino in general, you can have a look at
                      https://www.arduino.cc/en/Guide/HomePage
                      https://www.arduino.cc/en/Tutorial/HomePage
                      https://www.arduino.cc/en/Reference/HomePage
                      • blebbensB
                        blebbensB
                        blebbens
                        Oh, just realized domoticz setup uses a serial gateway baud rate of 115.200, the sketches are using 38.400. Perhaps, this is the big mistake.
                        • blebbensB
                          blebbensB
                          blebbens
                          It is very frustrating...
                          Uploaded the serial gateway sketch from examples ro my serial gateway (not serialgateway485). I just modified the baud rate to 115200. domoticz recognizes the gateway as version 2.0.
                          I also uploaded the motion sketch from examples to a new arduino nano and modified nothing.
                          Domoticz now is able to see the node, but it is named unknown. The child ID 255 (that must be wrong) is named S_ARDUINO_REPEATER_NODE - that is wrong. It has to be S_MOTION. Despite I was using the newest sketch, domoticz calls it version 1.0.
                          Could someone tell me the solution, please?
                          • Tore André RosanderT
                            Tore André Rosander
                            @blebbens
                            The version 1.0 comes from this piece of code and has nothing to do with the mysensors version.
                            It would be nice to see the serial output from your node when you connect it to your gateway.
                            Also try to comment out the sleep function so there is less code that could cause a problem.
                            • blebbensB
                              blebbensB
                              blebbens
                              wrote on last edited by blebbens
                              This is the code for my serial gateway to domoticz (arduino nano, NRF24L01+PA+ANTENNA) I am actually using...
                               * LEDs (OPTIONAL):
                              #define MY_BAUD_RATE 115200
                              And this sketch is for the motion sensor (arduino nano, HC-SR501 and NRF24L01+PA+ANTENNA)...
                              // #define MY_DEBUG
                              Domoticz still recognizes the motion sensor as "unknown" and S_ARDUINO_REPEATER.
                              And, the debug seriell monitor tells me:
                              TSM:INIT
                              TSM:RADIO:OK
                              TSM:FPAR
                              TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                              TSM:FPAR
                              TSM:FPAR
                              TSM:FPAR
                              !TSM:FPAR:FAIL
                              !TSM:FAILURE
                              TSM:PDT
                              Hope, someone can help - it is very frustrating.
                              tekkaT 1 Reply Last reply
                              • blebbensB blebbens
                                 * LEDs (OPTIONAL):
                                // #define MY_DEBUG
                                TSM:INIT
                                TSM:RADIO:OK
                                TSM:FPAR
                                TSM:FPAR
                                TSM:FPAR
                                TSM:FPAR
                                !TSM:FPAR:FAIL
                                !TSM:FAILURE
                                TSM:PDT
                                tekkaT
                                tekkaT
                                tekka
                                @blebbens Please also post the debug log of your GW while the node is booting.
                                • blebbensB
                                  blebbensB
                                  blebbens
                                  Okay, could you please tell me how to do that.
                                  At the moment I do not know where to find it.
                                  AWIA 1 Reply Last reply
                                    AWIA
                                    AWIA
                                    AWI
                                    @blebbens connect the gateway to your computer usb port and look at the serial to see the debug log.
                                    In addition where does domoticz show the "unknown" sensor? In the hardware log there is always one with id 255 for the node.
                                    From you log I read a lot of "failed" messages. This indicates transmission errors which could result from your amplified radio's. These a more error prone than the non amplified ones. For testing you better use the non amplified.
                                    • blebbensB
                                      blebbensB
                                      blebbens
                                      This is what domoticz looks like...
                                      Connecting the serial gateway to my computer means, I can not connect it to domoticz ?
                                      For debugging I have to enable #define MY_DEBUG ?
                                      Or, is there a way to read the log file on the gateway ?
                                        I don't know about domoticz but perhaps you can get the logs. Or use MYSController.
                                        Otherwise, when you need it, you can debug gw and node on your computer. Just connect both devices to your computer. Then of course this is not connected to domoticz but for debugging i often do this, it's useful.
                                        So:
                                        • connect gw+node to your computer
                                        • then use Serial monitor from arduino if you want, to monitor one device. choose right baudrate and comport of course
                                        • and for other device, use another serial monitor like putty etc..
                                          or a sniffer if you really want to keep it connected to your controller. But for noobs, i would advice to simply use two serial monitor when you need to debug, easier..
                                          AWIA
                                          AWIA
                                          AWI
                                          @blebbens your domoticz screen looks fine. No errors but also no sensors reported. Only the node is known.
                                          As @scalz mentioned, just connect the node and gateway to your computer watch what happens on the serial monitor (arduino idea or whatever you are using) the node does not have to be connected to domoticz for initial debugging.
