  3. Problems with first sensors
62 Posts 9 Posters 34.9k Views 11 Watching
    ah ok. I don't know for these sketch. But those from the arduino example folder should be ok.
    If not, clean your arduino install, and install it again. with the help from the links above, this should be ok.
    I hope it helps.
    • blebbensB
      blebbensB
      blebbens
      Nano seems to be damaged. Trying a new one tomorrow.
      One more question, please: I downloadee mysensors library 20.
      As I am using a serial hateway, I notices the gateway sketch uses the old gw.xxx structure. Do I have to modfiy the sketch on my own for preparing it for library 2.0? (My programming skills are under development). On githib the sketch is very basic, there is missing a lot?!
        where do you see that gateway use old structure?
        the serial gw sketch you have in arduino ide should be the same as github. if not, you have not well updated your lib..
        don't worry, the sketch is very basic but it works. it's because lot of stuff is hidden for easing the lib use.
        • blebbensB
          blebbensB
          blebbens
          To me as a newbie it is a bit confusing...
          This sketch comes from mysensors.org:
           * LEDs (OPTIONAL):
          #define NO_PORTB_PINCHANGES
          #include <MySigningNone.h>
          #include <MyTransportRFM69.h>
          #include <MyTransportNRF24.h>
          //#include <MyHwATMega328.h>
          #include <MyParserSerial.h>
          #include <stdarg.h>
          #include <PinChangeInt.h>
          #include "GatewayUtil.h"
          //MyTransportRFM69 transport;
          //MySigningNone signer;
          //MySigningAtsha204 signer;
          // Hardware profile
          MyHwATMega328 hw;
          #ifdef WITH_LEDS_BLINKING
          MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
          char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
          int inputPos = 0;
          boolean commandComplete = false;  // whether the string is complete
          void parseAndSend(char *commandBuffer);
          void output(const char *fmt, ... ) {
             va_list args;
             va_start (args, fmt );
             va_end (args);
             Serial.print(serialBuffer);
            // Add interrupt for inclusion button to pin
            PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
            // Send startup log message on serial
            serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
            checkInclusionFinished();
            if (commandComplete) {
              // A command wass issued from serial interface
              // We will now try to send it to the actuator
              parseAndSend(gw, inputString);
              inputPos = 0;
            SerialEvent occurs whenever a new data comes in the
           hardware serial RX.  This routine is run between each
           time loop() runs, so using delay inside loop can delay
           response.  Multiple bytes of data may be available.
          void serialEvent() {
            while (Serial.available()) {
              // get the new byte:
              char inChar = (char)Serial.read();
              // if the incoming character is a newline, set a flag
              // so the main loop can do something about it:
              if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
                if (inChar == '\n') {
                  inputString[inputPos] = 0;
                  commandComplete = true;
                  // add it to the inputString:
                  inputString[inputPos] = inChar;
                  inputPos++;
                  inputPos = 0;
          Looks like the sketch for mysensors library 1.x.
          And this one is from github:
           * LEDs (OPTIONAL):
           * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
          #if F_CPU == 8000000L
          #define MY_BAUD_RATE 38400
          // Flash leds on rx/tx/err
          // Set blinking period
          // Enable inclusion mode
          To me ot looks like this is meant for mysensors.org 2.0, which looks incomplete. Think, they have to be merged ?
            I know the difference between the two versions. But, as I said, no need to merge.
            Please note:
            • The examples you found on mysensors.org are, i guess, not all updated yet. but mysensors team is working hard, it's lot of work ;)
            • The example from github are compiled for mysensors 2. You think this is incomplete but that's wrong. The stuff you think missing is simply hidden. For easing noob experience.
            • So only 1.x older user sketch need to be updated to 2.0. If you are starting with mysensors, i don't think you have older sketch to convert, isn't it?
            • if not already done., use https://www.mysensors.org/about/arduino#installing-the-sensor-libraries to install the latest lib from Arduino software
            • Then no need to go to mysensors or git to get the latest examples. It's available in Arduino software. File Menu\Examples\Mysensors
            For discovering Arduino software, or arduino in general, you can have a look at
            https://www.arduino.cc/en/Guide/HomePage
            https://www.arduino.cc/en/Tutorial/HomePage
            https://www.arduino.cc/en/Reference/HomePage
            • blebbensB
              blebbensB
              blebbens
              Oh, just realized domoticz setup uses a serial gateway baud rate of 115.200, the sketches are using 38.400. Perhaps, this is the big mistake.
              • blebbensB
                blebbensB
                blebbens
                It is very frustrating...
                Uploaded the serial gateway sketch from examples ro my serial gateway (not serialgateway485). I just modified the baud rate to 115200. domoticz recognizes the gateway as version 2.0.
                I also uploaded the motion sketch from examples to a new arduino nano and modified nothing.
                Domoticz now is able to see the node, but it is named unknown. The child ID 255 (that must be wrong) is named S_ARDUINO_REPEATER_NODE - that is wrong. It has to be S_MOTION. Despite I was using the newest sketch, domoticz calls it version 1.0.
                Could someone tell me the solution, please?
                • Tore André RosanderT
                  Tore André Rosander
                  @blebbens
                  The version 1.0 comes from this piece of code and has nothing to do with the mysensors version.
                  It would be nice to see the serial output from your node when you connect it to your gateway.
                  Also try to comment out the sleep function so there is less code that could cause a problem.
                  • blebbensB
                    blebbensB
                    blebbens
                    wrote on last edited by blebbens
                    This is the code for my serial gateway to domoticz (arduino nano, NRF24L01+PA+ANTENNA) I am actually using...
                     * LEDs (OPTIONAL):
                    #define MY_BAUD_RATE 115200
                    And this sketch is for the motion sensor (arduino nano, HC-SR501 and NRF24L01+PA+ANTENNA)...
                     * Version 1.0 - Henrik Ekblad
                    // Enable debug prints
                    // #define MY_DEBUG
                    // Initialize motion message
                      present(CHILD_ID, S_MOTION);
                      // Read digital motion value
                      Serial.println(tripped);
                    Domoticz still recognizes the motion sensor as "unknown" and S_ARDUINO_REPEATER.
                    And, the debug seriell monitor tells me:
                    TSM:INIT
                    TSM:RADIO:OK
                    TSM:FPAR
                    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                    TSM:FPAR
                    TSM:FPAR
                    TSM:FPAR
                    !TSM:FPAR:FAIL
                    !TSM:FAILURE
                    TSM:PDT
                    Hope, someone can help - it is very frustrating.
                    tekkaT 1 Reply Last reply
                    • blebbensB blebbens
                       * LEDs (OPTIONAL):
                      // #define MY_DEBUG
                      TSM:INIT
                      TSM:RADIO:OK
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      TSM:FPAR
                      !TSM:FPAR:FAIL
                      !TSM:FAILURE
                      TSM:PDT
                      tekkaT
                      tekkaT
                      tekka
                      @blebbens Please also post the debug log of your GW while the node is booting.
                      • blebbensB
                        blebbensB
                        blebbens
                        Okay, could you please tell me how to do that.
                        At the moment I do not know where to find it.
                        AWIA 1 Reply Last reply
                          AWIA
                          AWIA
                          AWI
                          @blebbens connect the gateway to your computer usb port and look at the serial to see the debug log.
                          In addition where does domoticz show the "unknown" sensor? In the hardware log there is always one with id 255 for the node.
                          From you log I read a lot of "failed" messages. This indicates transmission errors which could result from your amplified radio's. These a more error prone than the non amplified ones. For testing you better use the non amplified.
                          • blebbensB
                            blebbensB
                            blebbens
                            This is what domoticz looks like...
                            Connecting the serial gateway to my computer means, I can not connect it to domoticz ?
                            For debugging I have to enable #define MY_DEBUG ?
                            Or, is there a way to read the log file on the gateway ?
                              I don't know about domoticz but perhaps you can get the logs. Or use MYSController.
                              Otherwise, when you need it, you can debug gw and node on your computer. Just connect both devices to your computer. Then of course this is not connected to domoticz but for debugging i often do this, it's useful.
                              So:
                              • connect gw+node to your computer
                              • then use Serial monitor from arduino if you want, to monitor one device. choose right baudrate and comport of course
                              • and for other device, use another serial monitor like putty etc..
                                or a sniffer if you really want to keep it connected to your controller. But for noobs, i would advice to simply use two serial monitor when you need to debug, easier..
                                AWIA
                                AWIA
                                AWI
                                @blebbens your domoticz screen looks fine. No errors but also no sensors reported. Only the node is known.
                                As @scalz mentioned, just connect the node and gateway to your computer watch what happens on the serial monitor (arduino idea or whatever you are using) the node does not have to be connected to domoticz for initial debugging.
                                • blebbensB
                                  blebbensB
                                  blebbens
                                  #21
                                  Okay, I have...
                                  The motion sensor connected to the Arduino IDE. The output of the serial monitor (at this time the gateway was connected to the controller):
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR
                                  !TSM:FPAR:FAIL
                                  !TSM:FAILURE
                                  TSM:PDT
                                  TSM:INIT
                                  TSM:RADIO:OK
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR
                                  TSM:FPAR
                                  An at this point I had the gateway connected to the arduino IDE (the motion sensor was not connected to the computer):
                                  0;255;3;0;9;TSM:INIT
                                  0;255;3;0;9;TSM:RADIO:OK
                                  0;255;3;0;9;TSM:GW MODE
                                  0;255;3;0;9;TSM:READY
                                  0;255;0;0;18;2.0.0
                                  0;255;3;0;9;TSP:SANCHK:OK
                                  I never had both, gateway and sensor, connected to the monitor at the same time. I am afraid, I didn´t understand to use MYScontroller. Did not find the com-port settings etc. It always tries to connect to gateway 192.168.0.x, my network is not set up to this IP.
                                  Does the output help ?
                                    #22
                                    nope, output can't help as it's only one device..
                                    I think you're talking about MYSController config when you say 192.168.0.x, isn't it? or i don't understand lol
                                    To know your serialports in use:
                                    • with Win for instance, go to something like Control Panel → Device Manager → COM & LPT ports
                                    • connect your devices to usb, and disconnect one by one. So now you know which one use which port.
                                    About MYSController: you will need to setup the serial port for GW.
                                    • With GW connected to usb, click Settings button and then click Gateway tab.
                                    • Check Serial GW and choose port&bauds.
                                    • Now, still in MYSController, you can click Connect button. There are tabs in MYSController for different debug levels. Look a bit at features.
                                    • It should connect, if it does not, un/replug your gw, and reclick Connect.
                                    Then you'll have the logs for your GW if it is enabled in sketch of course.
                                    As said above, if you would like, you could use another software (serial monitor) in place of MYSController. but not required here.
                                    Now, for the other device (node), you can monitor it in Arduino software by setting well port&bauds. you know it now ;)
                                    Could you try in this order, please :
                                    • plug GW only. And connect with MYSController
                                    • then plug node, and open your Arduino Serial monitor.
                                    does it work? if no, logs, thx ;)
                                    • blebbensB
                                      blebbensB
                                      blebbens
                                      #23
                                      Okay, done it... both connected, gw on MYScontroller, motion sensor monitored using IDE...
                                      Sensor output:
                                      TSM:INIT
                                      TSM:RADIO:OK
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      TSM:FPAR
                                      !TSM:FPAR:FAIL
                                      !TSM:FAILURE
                                      TSM:PDT
                                      And gateway output:
                                      MYScontroller debug:
                                      16.07.2016 19:43:42	INFO	Flushing FIFO
                                      16.07.2016 19:43:42	INFO	Connected to COM7
                                      16.07.2016 19:43:44	RX	0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
                                      16.07.2016 19:43:44	CHILD	New child discovered, node id=0, child id=internal
                                      16.07.2016 19:43:44	RX	0;255;3;0;9;TSM:INIT
                                      16.07.2016 19:43:44	RX	0;255;3;0;9;TSM:RADIO:OK
                                      16.07.2016 19:43:44	RX	0;255;3;0;9;TSM:GW MODE
                                      16.07.2016 19:43:44	RX	0;255;3;0;9;TSM:READY
                                      16.07.2016 19:43:44	RX	0;255;3;0;14;Gateway startup complete.
                                      16.07.2016 19:43:44	RX	0;255;0;0;18;2.0.0
                                      16.07.2016 19:43:44	DEBUG	Update child id=255, type=S_ARDUINO_REPEATER_NODE
                                      16.07.2016 19:43:44	RX	0;255;3;0;9;No registration required
                                      16.07.2016 19:43:44	RX	0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1
                                      16.07.2016 19:44:44	RX	0;255;3;0;9;TSP:SANCHK:OK
                                      16.07.2016 19:45:44	RX	0;255;3;0;9;TSP:SANCHK:OK
                                      MySensors debug:
                                      8	16.07.2016 19:43:44	TX	-1	-1		-1	-1	NA (-1)	N/A	NA (-1)	-1			required
                                      Nodes debug: this message was shown before I connected the sensor to power
                                      7	16.07.2016 19:43:44	0 - Gateway	S_ARDUINO_REPEATER_NODE	S_ARDUINO_REPEATER_NODE	2.0.0
                                      And messages tab:
                                      6	16.07.2016 19:43:44	RX	0 - Gateway	INTERNAL	C_INTERNAL	NO	I_GATEWAY_READY	Gateway startup complete.
                                      7	16.07.2016 19:43:44	RX	0 - Gateway	INTERNAL	C_PRESENTATION	NO	S_ARDUINO_REPEATER_NODE	2.0.0
                                      Okay, hope, this helps now.
                                      That´s strange, because there is no repeater... just a motion sensor sketch.
                                      • blebbensB
                                        blebbensB
                                        blebbens
                                        No one ? It is so frustrating...
                                        Read some more threads like this (https://forum.mysensors.org/topic/4280/simple-serial-gateway-and-sensor-does-not-work)... seems to be a common problem of MySensors 2.0 ?
                                        • SGiS
                                          SGiS
                                          SGi
                                          Try this: https://forum.mysensors.org/topic/4316/version-2-0-isn-t-working
