  3. Water high volume flow meter
6 Posts 4 Posters 2.4k Views 5 Watching
  • E
    E
    ericvdb
    Guys,
    did anyone came across a water flow meter for +/- 240L/min? Most i find is 30L/min.
    Thanks in advance
    SparkmanS 1 Reply Last reply
      Guess it depends much on the pipe dimensions used.
      • E
        E
        ericvdb
        The pump of my swimming pool can do 240L/min, the pipe diameter is 35mm.
        marekdM 1 Reply Last reply
        • E ericvdb
          marekdM
          marekdM
          marekd
          this is over 14m3/h of water, this is a lot. Are you sure about that?
          you can find a flow meter up to 120L/min for 1.5" pipe, but 240 is like industrial size for me.
          • E ericvdb
            Guys,
            Thanks in advance
            SparkmanS
            SparkmanS
            Sparkman
            @ericvdb
            They are available, but not cheap. Here are some examples for the North American market: http://www.jerman.com/dljcmeters.html.
            Al
            • SparkmanS
              SparkmanS
              Sparkman
              Here's one on AliExpress that can do 200 l/m: http://www.aliexpress.com/item/YF-DN50-2-inch-Large-diameter-turbine-flow-meter-water-flow-sensor-industrial-flow-meter-Available/32297810863.html?spm=2114.40010208.4.71.i72mzF. Not sure if I would trust it though.
