  3. Mi-Light controller for Mysensors
69 Posts 15 Posters 52.7k Views 27 Watching
  • Łukasz KostrzewaŁ
    Łukasz KostrzewaŁ
    Łukasz Kostrzewa
    Thx for answer
    I am noob in programming. Maybe You can post an example how to modify the code?
    Best regards
    • alexsh1A
      alexsh1A
      alexsh1
      Excellent project! I have implemented reversed engineering for (1) some switches (2) LightWaveRF sockets. I tried to implemented Mi-Light with Mysensors but I having spent some time I decided to just buy a WiFi hub ($7) as it is natively supported in Domoticz.
      Mi-Light is an excellent product price wise compare to Philips Hue
      • Łukasz KostrzewaŁ
        Łukasz KostrzewaŁ
        Łukasz Kostrzewa
        Hi
        Anyone have idea how to modify the code to pair domoticz to more than one bulb?
        With actual code I am able to ON/OFF only one bulb :(
        Any idea?
        Best regards
        • Łukasz KostrzewaŁ
          Łukasz KostrzewaŁ
          Łukasz Kostrzewa
          Anybody?
          • Cliff KarlssonC
            Cliff KarlssonC
            Cliff Karlsson
            I would also like this to work with domoticz but as I lack the skills nececary I am now waiting on the next RFlink firmware witch is adding the feature of controlling mi-lights.
            I still think that the node/repeater as descripbed in this topic would be better but as I have no options the RFlink is better than using the standard milight bridge an any way.
            I have added a NRF24L01 PA to my RFlink gateway and am hoping that the range will cover my whole house.
            • Łukasz KostrzewaŁ
              Łukasz KostrzewaŁ
              Łukasz Kostrzewa
              Thx for info
              Best regards
              • Łukasz KostrzewaŁ
                Łukasz KostrzewaŁ
                Łukasz Kostrzewa
                I have new problem.
                I paired wrong bulb and now I can't unpair it.
                How to do that?
                Best regards
                • Iraklis KourtisI
                  Iraklis KourtisI
                  Iraklis Kourtis
                  Hi Ted,
                  Your project looks really amazing and I think it is exactly what I was looking for.
                  I want to change my lighting at home. I am thinking of adding 8 LED strips that will be controlled by 2 x 4 Mi-Light remote controls and 2 x wifi bridges. As I would like to still be able to use the wall switches to turn them on/off I was thinking of using your solution. Do you think it will be feasible with your project? Also is there a way to reduce the wifi bridges to 1 instead of having 2?
                  Thank you for this great project!
                  Iraklis
                  • Łukasz KostrzewaŁ Łukasz Kostrzewa
                    I have new problem.
                    How to do that?
                    Best regards
                    ted
                    @Łukasz-Kostrzewa
                    sorry for the delay. you need to send the unpair command right after turning on the light. see https://hackaday.io/project/5888-reverse-engineering-the-milight-on-air-protocol
                    • Iraklis KourtisI Iraklis Kourtis
                      Hi Ted,
                      Iraklis
                      ted
                      @Iraklis-Kourtis
                      The controller is all you need to control the lights. It does not need wifi bridge
                      • CrankyCoderC
                        CrankyCoderC
                        CrankyCoder
                        Has this been converted to 2.0?
                        Also, to build the controller for this i don't need anything special other than the arduino + nrf24l01 correct? I am VERY interested in this
                        Home Automation Tinkerer
                        www.CrankyCoder.net
                        Gateway: MQTTClientGateway
                        MySensors: 2.3
                        • CrankyCoderC
                          CrankyCoderC
                          CrankyCoder
                          i got 2 of my milight bulbs in today. Just wondering if anyone is still using this?
                          www.CrankyCoder.net
                          MySensors: 2.3
                          • Cliff KarlssonC
                            Cliff KarlssonC
                            Cliff Karlsson
                            I would like to use this solution as it seams to be really great to have both a NRF/Mi-light-Repeater for every "node". But my skils are not enough to make this work with RGB-strips/bulbs and to have it working with domoticz. I am using the standard Domoticz way of controllign them using the original mi-light gateways and have also experimented with RF-link mi-light control.
                            But my dream-scenario is that some nice coding-wiz will post a complete solution that even newbies can integrate this in this forum-thread. But I would not count on it.
                            • CrankyCoderC
                              CrankyCoderC
                              CrankyCoder
                              I have done a little bit of tinkering with it today. i have not cleaned up the code yet, but I have been able to get my arduino repeater to pair with one of the lights, and turn it on and off. My progress so far.
                              • Convert to using the mysensor 2.0 framework
                              • setup a bulb and paired
                              • can turn bulb on and off
                              My next step is to see if i can change colors on the bulb. The only thing I noticed is there is a small delay when switching the radio between the mysensors rf and the milight rf protocol. I may later see if it's possible to do 2 radios. But for now progress is being made with a repeater node.
                              Once it's working, Ill see if i can post some samples of how I controlled it via mqtt. (I use openhab)
                              If the original author of this sketch is interested I will provide him current code progress. Or I can throw it on github if anyone is interested in tinkering with it. I definitely want to get some documentation together for how to get multiple bulbs working on it.
                              www.CrankyCoder.net
                              MySensors: 2.3
                              • CrankyCoderC
                                CrankyCoderC
                                CrankyCoder
                                I have put my mods on github.
                                https://github.com/brunkj/MySensorsMiLight/
                                I have not been able to mess with it since the weekend. Still trying to get some info on the RGB part. If anyone wants to take a shot at it let me know if you make any progress :)
                                www.CrankyCoder.net
                                MySensors: 2.3
                                • CrankyCoderC
                                  CrankyCoderC
                                  CrankyCoder
                                  spent some more time working on this. Still not having luck figuring out a what to send to the V_VAR1 to get the bulb to do anything
                                  I can send simple on off for S_LIGHT V_STATUS
                                  if (message.type == V_STATUS)
                                      //Serial.println("triggered V_STATUS");
                                      mlr.begin();
                                      // Change light status
                                      if ( message.getBool())
                                        Serial.println("here");
                                        // Serial.println("triggered ON");
                                        sendCommand (outgoingPacket_on, sizeof(outgoingPacket_on));
                                      else {
                                        //  Serial.println("triggered off");
                                        sendCommand(outgoingPacket_off, sizeof(outgoingPacket_off));
                                      _begin();
                                  Easy. But the V_VAR1 on S_CUSTOM I can't figure out what to put in the payload
                                  if (message.type == V_VAR1)
                                      // Serial.println("triggered V_VAR1");
                                      incomingCommand = (char *)message.getCustom();
                                      Serial.println((char *)message.getCustom());
                                       mlr.begin();
                                       Serial.println("#############");
                                      for (int i=0; i<sizeof(outgoingPacket); i++)
                                      { outgoingPacket[i] = 16*char_to_uint8_t(incomingCommand[i*2]) + char_to_uint8_t(incomingCommand[i*2+1]);
                                        Serial.println(outgoingPacket[i]);
                                      Serial.write(outgoingPacket, 7);
                                      sendCommand(outgoingPacket, sizeof(outgoingPacket));
                                      _begin();
                                  I have referenced the hacking milight protocol pages and many other, I just can't seem to get it right to get my bulb to do anything.
                                  Anyone want to take a shot at it? or have payload data I could try?
                                  full sketch
                                  #define MY_REPEATER_FEATURE
                                  #include <MyConfig.h>
                                  #define CE_PIN 9     //CE and CSN pin for nrf24 radio
                                  #define CSN_PIN 10
                                  #include <nRF_24L01.h>
                                  #include <avr/power.h>
                                  #include <printf.h>
                                  #include "PL1167_nRF24.h"
                                  #include "MiLightRadio.h"
                                  #define NODE_ID 100
                                  #define mi_command_repeat 30   //# of times to resend the command to bulb
                                  RF_24 mi_radio(CE_PIN, CSN_PIN);
                                  PL1167_nRF24 prf(mi_radio);
                                  MiLightRadio mlr(prf);
        // B0-176   F2-242    EA-234    6D    B0    02    f0
                                  static uint8_t outgoingPacket_on[7] = { 0xB0, 0xF2, 0xEA, 0x6D, 0x91, 0x03, 0x00};  //the first three #s are remote ID, replace with yours
                                  static uint8_t outgoingPacket_off[7] = { 0xB0, 0xF2, 0xEA, 0x04, 0x91, 0x04, 0x00};
                                  uint8_t outgoingPacket[7];
                                  #define sizeofincomingCommand 15 //command comes in text form of 7 uint8_t, with an additional NULL at end
                                  char *incomingCommand;    //array for incoming command
                                  boolean mi_radio_state = false;
                                    //Send the sensor node sketch version information to the gateway
                                    sendSketchInfo("Milight controller", "1.0");
                                     //clock_prescale_set(clock_div_2);     //for a barebone atmega328p, this  will make the CPU running at 4MHz.
                                    //Serial.begin(115200);
                                    // The third argument enables repeater mode.
                                    present(0, S_LIGHT);
                                    present(1, S_CUSTOM);
                                    // The command will be transmitted in V_VAR1 type, in the following 7 byte format: ID1 ID2 ID3 COLOR BRIGHTNESS COMMAND.
                                    // see https://hackaday.io/project/5888-reverse-engineering-the-milight-on-air-protocol
                                    Serial.println(message.type);
                                      mlr.begin();
                                      else {
                                      _begin();
                                       mlr.begin();
                                      _begin();
                                  //gw.begin(incomingMessage, NODE_ID, true);
                                  void sendCommand(uint8_t mi_Command[7], int sizeofcommand)
                                  { for (int i = 0; i < mi_command_repeat; i++)
                                    { mlr.write(mi_Command, sizeofcommand);
                                  uint8_t char_to_uint8_t(char c)
                                  	uint8_t i;
                                  	if (c <= '9')
                                  		i = c - '0';
                                  	else if (c >= 'a')
                                  		i = c - 'a' + 10;
                                  		i = c - 'A' + 10;
                                  	return i;
                                  www.CrankyCoder.net
                                  MySensors: 2.3
                                  • n1ck1355N
                                    n1ck1355N
                                    n1ck1355
                                    wrote on last edited by n1ck1355
                                    #48
                                    @Jason-Brunk
                                    unfortunately i havnt got my own milight bulbs but for what i've seen on the
                                    reverse engineered protocol page the payload must be something like
                                    "07B0F2EA359001B9ACF9" for all on or
                                    "07B0F2EA7D910FD4EC72" for green
                                    or the part "07B0F2EA" must be the ID so the payload
                                    is somethink like "359001B9ACF9" for all on and
                                    "7D910FD4EC72" for green
                                    • n1ck1355N
                                      n1ck1355N
                                      n1ck1355
                                      @ted are you there and can get a hint please? :)
                                      • n1ck1355N n1ck1355
                                        ted
                                        @n1ck1355 @Jason-Brunk
                                        sorry i'm been really busy with job recently. I used openhab to send the payload to V_VAR1 and S_CUSTOM. When I get home tonight, I'll post the openhab rule file so people can get some sense how to control color.
                                        • n1ck1355N
                                          n1ck1355N
                                          n1ck1355
                                          that's really great :) Thanks!
