  3. Mi-Light controller for Mysensors
69 Posts 15 Posters 52.6k Views 27 Watching
  • Łukasz KostrzewaŁ
    Łukasz KostrzewaŁ
    Łukasz Kostrzewa
    I have new problem.
    I paired wrong bulb and now I can't unpair it.
    How to do that?
    Best regards
    • Iraklis KourtisI
      Iraklis KourtisI
      Iraklis Kourtis
      Hi Ted,
      Your project looks really amazing and I think it is exactly what I was looking for.
      I want to change my lighting at home. I am thinking of adding 8 LED strips that will be controlled by 2 x 4 Mi-Light remote controls and 2 x wifi bridges. As I would like to still be able to use the wall switches to turn them on/off I was thinking of using your solution. Do you think it will be feasible with your project? Also is there a way to reduce the wifi bridges to 1 instead of having 2?
      Thank you for this great project!
      Iraklis
      • Łukasz KostrzewaŁ Łukasz Kostrzewa
        I have new problem.
        How to do that?
        Best regards
        ted
        @Łukasz-Kostrzewa
        sorry for the delay. you need to send the unpair command right after turning on the light. see https://hackaday.io/project/5888-reverse-engineering-the-milight-on-air-protocol
        • Iraklis KourtisI Iraklis Kourtis
          Hi Ted,
          Iraklis
          ted
          @Iraklis-Kourtis
          The controller is all you need to control the lights. It does not need wifi bridge
          • CrankyCoderC
            CrankyCoderC
            CrankyCoder
            Has this been converted to 2.0?
            Also, to build the controller for this i don't need anything special other than the arduino + nrf24l01 correct? I am VERY interested in this
            Home Automation Tinkerer
            www.CrankyCoder.net
            Gateway: MQTTClientGateway
            MySensors: 2.3
            • CrankyCoderC
              CrankyCoderC
              CrankyCoder
              i got 2 of my milight bulbs in today. Just wondering if anyone is still using this?
              www.CrankyCoder.net
              MySensors: 2.3
              • Cliff KarlssonC
                Cliff KarlssonC
                Cliff Karlsson
                I would like to use this solution as it seams to be really great to have both a NRF/Mi-light-Repeater for every "node". But my skils are not enough to make this work with RGB-strips/bulbs and to have it working with domoticz. I am using the standard Domoticz way of controllign them using the original mi-light gateways and have also experimented with RF-link mi-light control.
                But my dream-scenario is that some nice coding-wiz will post a complete solution that even newbies can integrate this in this forum-thread. But I would not count on it.
                • CrankyCoderC
                  CrankyCoderC
                  CrankyCoder
                  I have done a little bit of tinkering with it today. i have not cleaned up the code yet, but I have been able to get my arduino repeater to pair with one of the lights, and turn it on and off. My progress so far.
                  • Convert to using the mysensor 2.0 framework
                  • setup a bulb and paired
                  • can turn bulb on and off
                  My next step is to see if i can change colors on the bulb. The only thing I noticed is there is a small delay when switching the radio between the mysensors rf and the milight rf protocol. I may later see if it's possible to do 2 radios. But for now progress is being made with a repeater node.
                  Once it's working, Ill see if i can post some samples of how I controlled it via mqtt. (I use openhab)
                  If the original author of this sketch is interested I will provide him current code progress. Or I can throw it on github if anyone is interested in tinkering with it. I definitely want to get some documentation together for how to get multiple bulbs working on it.
                  www.CrankyCoder.net
                  MySensors: 2.3
                  • CrankyCoderC
                    CrankyCoderC
                    CrankyCoder
                    I have put my mods on github.
                    https://github.com/brunkj/MySensorsMiLight/
                    I have not been able to mess with it since the weekend. Still trying to get some info on the RGB part. If anyone wants to take a shot at it let me know if you make any progress :)
                    www.CrankyCoder.net
                    MySensors: 2.3
                    • CrankyCoderC
                      CrankyCoderC
                      CrankyCoder
                      spent some more time working on this. Still not having luck figuring out a what to send to the V_VAR1 to get the bulb to do anything
                      I can send simple on off for S_LIGHT V_STATUS
                      if (message.type == V_STATUS)
                          //Serial.println("triggered V_STATUS");
                          mlr.begin();
                          // Change light status
                          if ( message.getBool())
                            Serial.println("here");
                            // Serial.println("triggered ON");
                            sendCommand (outgoingPacket_on, sizeof(outgoingPacket_on));
                          else {
                            //  Serial.println("triggered off");
                            sendCommand(outgoingPacket_off, sizeof(outgoingPacket_off));
                          _begin();
                      Easy. But the V_VAR1 on S_CUSTOM I can't figure out what to put in the payload
                      if (message.type == V_VAR1)
                          // Serial.println("triggered V_VAR1");
                          incomingCommand = (char *)message.getCustom();
                          Serial.println((char *)message.getCustom());
                           mlr.begin();
                           Serial.println("#############");
                          for (int i=0; i<sizeof(outgoingPacket); i++)
                          { outgoingPacket[i] = 16*char_to_uint8_t(incomingCommand[i*2]) + char_to_uint8_t(incomingCommand[i*2+1]);
                            Serial.println(outgoingPacket[i]);
                          Serial.write(outgoingPacket, 7);
                          sendCommand(outgoingPacket, sizeof(outgoingPacket));
                          _begin();
                      I have referenced the hacking milight protocol pages and many other, I just can't seem to get it right to get my bulb to do anything.
                      Anyone want to take a shot at it? or have payload data I could try?
                      full sketch
                      #define MY_REPEATER_FEATURE
                      #include <MyConfig.h>
                      #define CE_PIN 9     //CE and CSN pin for nrf24 radio
                      #define CSN_PIN 10
                      #include <nRF_24L01.h>
                      #include <avr/power.h>
                      #include <printf.h>
                      #include "PL1167_nRF24.h"
                      #include "MiLightRadio.h"
                      #define NODE_ID 100
                      #define mi_command_repeat 30   //# of times to resend the command to bulb
                      RF_24 mi_radio(CE_PIN, CSN_PIN);
                      PL1167_nRF24 prf(mi_radio);
                      MiLightRadio mlr(prf);
                                                             // B0-176   F2-242    EA-234    6D    B0    02    f0
                      static uint8_t outgoingPacket_on[7] = { 0xB0, 0xF2, 0xEA, 0x6D, 0x91, 0x03, 0x00};  //the first three #s are remote ID, replace with yours
                      static uint8_t outgoingPacket_off[7] = { 0xB0, 0xF2, 0xEA, 0x04, 0x91, 0x04, 0x00};
                      uint8_t outgoingPacket[7];
                      #define sizeofincomingCommand 15 //command comes in text form of 7 uint8_t, with an additional NULL at end
                      char *incomingCommand;    //array for incoming command
                      boolean mi_radio_state = false;
                        //Send the sensor node sketch version information to the gateway
                        sendSketchInfo("Milight controller", "1.0");
                         //clock_prescale_set(clock_div_2);     //for a barebone atmega328p, this  will make the CPU running at 4MHz.
                        //Serial.begin(115200);
                        // The third argument enables repeater mode.
                        present(0, S_LIGHT);
                        present(1, S_CUSTOM);
                        // The command will be transmitted in V_VAR1 type, in the following 7 byte format: ID1 ID2 ID3 COLOR BRIGHTNESS COMMAND.
                        // see https://hackaday.io/project/5888-reverse-engineering-the-milight-on-air-protocol
                        Serial.println(message.type);
                          mlr.begin();
                          else {
                          _begin();
                           mlr.begin();
                          _begin();
                      //gw.begin(incomingMessage, NODE_ID, true);
                      void sendCommand(uint8_t mi_Command[7], int sizeofcommand)
                      { for (int i = 0; i < mi_command_repeat; i++)
                        { mlr.write(mi_Command, sizeofcommand);
                      uint8_t char_to_uint8_t(char c)
                      	uint8_t i;
                      	if (c <= '9')
                      		i = c - '0';
                      	else if (c >= 'a')
                      		i = c - 'a' + 10;
                      		i = c - 'A' + 10;
                      	return i;
                      www.CrankyCoder.net
                      MySensors: 2.3
                      • n1ck1355N
                        n1ck1355N
                        n1ck1355
                        wrote on last edited by n1ck1355
                        #48
                        @Jason-Brunk
                        unfortunately i havnt got my own milight bulbs but for what i've seen on the
                        reverse engineered protocol page the payload must be something like
                        "07B0F2EA359001B9ACF9" for all on or
                        "07B0F2EA7D910FD4EC72" for green
                        or the part "07B0F2EA" must be the ID so the payload
                        is somethink like "359001B9ACF9" for all on and
                        "7D910FD4EC72" for green
                        • n1ck1355N
                          n1ck1355N
                          n1ck1355
                          @ted are you there and can get a hint please? :)
                          • n1ck1355N n1ck1355
                            ted
                            @n1ck1355 @Jason-Brunk
                            sorry i'm been really busy with job recently. I used openhab to send the payload to V_VAR1 and S_CUSTOM. When I get home tonight, I'll post the openhab rule file so people can get some sense how to control color.
                            • n1ck1355N
                              n1ck1355N
                              n1ck1355
                              that's really great :) Thanks!
                                ted
                                @n1ck1355
                                sorry for the delay. Here is what I learned from https://hackaday.io/project/5888-reverse-engineering-the-milight-on-air-protocol
                                Basically, the mi controller will receive text string and convert them into HEX format and send it to the bulb. The text string should be formatted as the following (+ added for easy of reading, no '+' in the actual command):
                                ID + color + brightness + button code + seq
                                The ID is the ID of the bulb to be controlled, it is six byte in ASCII but will be converted into 3 byte HEX before sending to the bulb.
                                color, brightness and button code are each 2 byte in ASCII and will be converted into 1 byte HEX and send to bulb.
                                Seq is 2 byte in ASCII but it appears that you can just use "00".
                                To change color, you need to send a color code (e.g.: "00"=purple, "1B"=red, "40"=yellow,e tc) and using button code "OF".
                                To change back to white, you use "04" as color code and "13" as button code.
                                The detailed button code definition can be found here:
                                https://cdn.hackaday.io/images/1224221432724803073.jpg
                                Hope this helps.
                                • n1ck1355N
                                  n1ck1355N
                                  n1ck1355
                                  Thank you @ted :)
                                  i already played with it and can turn the bulbs on/off. i will play around with your
                                  information to make the other funktions work.
                                  But what i see is that you cannot e.g. dim the bulbs softly from say 100% to 20% cause
                                  that would be more commands behind each other. But the node must reset itself after
                                  each command by calling _Begin() and that takes some time..
                                  any suggestions to resolve that?
                                    Thank you @ted :)
                                    ted
                                    @n1ck1355
                                    my only solution is to use two radios, one receives command from the gateway and the other sending command to the bulbs. it might be doable with just 1 arduino by using softSPI.
                                    Nca78N 1 Reply Last reply
                                    • T ted
                                      @n1ck1355
                                      @ted said:
                                      @n1ck1355
                                      I don't see why you would need SoftSPI for that ? It should just need some change for CE and CSN pins for the NRF that is used to send data to the milights. I will try to find time to check that this week.
                                      • n1ck1355N
                                        n1ck1355N
                                        n1ck1355
                                        @Nca78 :
                                        did you have success with thw NRF boards connecting?
                                          @Nca78 :
                                          @n1ck1355 said:
                                          @Nca78 :
                                          Hello, unfortunately I had no time to test it, I was busy with my Livolo switch :P
