  3. [Tutorial] How to burn 1Mhz & 8Mhz bootloader using Arduino IDE 1.6.5-r5
86 Posts 20 Posters 119.7k Views 28 Watching
  • GertSandersG GertSanders
    @jacikaas
    So only disconnect the white cable but leave the black one in the breadboard.
    J
    J
    jacikaas
    @GertSanders
    Thank You!!! That was very silly failure, which eats a lot of time... But it breaks the ice :)))
    Thank You a lot @GertSanders !
    • siodS
      siodS
      siod
      Hi guys,
      I flashed a few sensors already using the 8 MHz and 1MHz bootloaders. I would like to know if I could update my nodes OTA or would I have to modify sth. to make it possible?
      still learning...
      • siodS siod
        Hi guys,
        GertSandersG
        GertSandersG
        GertSanders
        @siod
        For OTA you need to flash the boot loaders that allow this. The standard boot loaders do not have this ability to OTA update.
        siodS 1 Reply Last reply
        • F
          F
          flopp
          I am also having problem upload with FTDI, I can upload sketch if I use UNO as ISP.
          I read that someone also have problem above but nothing is helping me.
          I am using Arduino IDE 1.6.8.
          Can it be the version of Arduino IDE?
          dpressleD 1 Reply Last reply
          • F flopp
            dpressleD
            dpressleD
            dpressle
            @flopp The only way i was able to upload with ftdi is to connect RTS pin to pin 1 via a 0.1 uf cap
            F 1 Reply Last reply
            • dpressleD dpressle
              F
              F
              flopp
              wrote on last edited by flopp
              #58
              @dpressle
              OK will try. Cap minus to GND and cap positive to RTS?
              EDIT: I am using 1Mhz setup
              I change the LOW fuse and Extended but what I can see is that my changes only changes the BOD and internal oscillator.
              low_fuses=0x42
              extended_fuses=0x06
              I noticed that my board have high_fuses=0xde, this setting the 1MHz board also have but not 8MHz. This mean that I dont have any space for Bootloader, can this be my problem?
              • F
                F
                flopp
                I tried with above 8MHz setting and then I can upload to ATmega with a FTDI.
                I will try to change settings one-by-one until I cant upload and write back here.
                • F
                  F
                  flopp
                  #60
                  With this board.txt config
                  atmega328bb.name=ATmega328 on a breadboard (8 MHz internal clock)
                  atmega328bb.upload.protocol=arduino
                  atmega328bb.upload.maximum_size=30720
                  atmega328bb.upload.speed=57600
                  atmega328bb.bootloader.low_fuses=0xE2
                  atmega328bb.bootloader.high_fuses=0xDA
                  atmega328bb.bootloader.extended_fuses=0x06
                  atmega328bb.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
                  atmega328bb.bootloader.unlock_bits=0x3F
                  atmega328bb.bootloader.lock_bits=0x0F
                  atmega328bb.build.mcu=atmega328p
                  atmega328bb.build.f_cpu=8000000L
                  atmega328bb.build.core=arduino:arduino
                  atmega328bb.build.variant=arduino:standard
                  atmega328bb.bootloader.tool=arduino:avrdude
                  atmega328bb.upload.tool=arduino:avrdude
                  I can upload with FTDI. When Arduino IDE change from "Compiling sketch" to "Upload", disconnect DTR and it work.
                  With my sketch it was using 12,9 uA when sleep
                  Same result if I change f_cpu to 1000000L
                  • F
                    F
                    flopp
                    Today I could upload without removing DTR :)
                      @siod
                      siodS
                      siodS
                      siod
                      @GertSanders said:
                      @siod
                      Ok, but after the new release of mysensors ver 2.0 lib and my wish to update my gw and sensor nodes I would like to add OTA update ability as well for upcoming updates.
                      • So does a 1 MHz Bootloader with OTA exist that is compatible to the one from above?
                      • Could OTA easily be added to the above 1MHz Bootloader?
                      • Should i just use the "ATmega328 internal 8Mhz with MYSBootloader" instead of the above mentioned bootloaders?
                      still learning...
                      • cimba007C
                        cimba007C
                        cimba007
                        Recently I read a lot about the 0ms, 4.1ms, 65ms start-up time of the low fuses.
                        I thought adding a small example to prove that the 65ms start-up time is apparently only important during initial powerup.
                        Used library: https://github.com/rocketscream/Low-Power
                        Testcode:
                        #include <LowPower.h>
                        // the setup function runs once when you press reset or power the board
                          // initialize digital pin 13 as an output.
                          pinMode(13, OUTPUT);
                          Serial.begin(19200);
                        // the loop function runs over and over again forever
                          LowPower.powerDown(SLEEP_15Ms, ADC_OFF, BOD_OFF);
                          Serial.write(".");
                          Serial.flush();
                        First dot:
                        0_1472662964196_upload-072d9398-ce73-4662-bbed-0e2c10ba1cee
                        Second dot:
                        0_1472663028575_upload-c7a0d030-d518-469e-a077-83f755199ab0
                        = 15ms (sleep) + 2ms (serial communication)
                        ~17ms including overhead for sending serial command
                        I will try out your bootloader and I can only say that it looks promising
                        • cimba007C
                          cimba007C
                          cimba007
                          wrote on last edited by cimba007
                          #64
                          I ran into an rather strange problem.
                          Mygateway is using esp8266_mqtt_client @ 80Mhz and my node is using the 1mhz bootloader.
                          If I enable debug logging on the gateway everything is working fine.
                          Upon disabling debug logging on the gateway and enabling debug lobbing on the node I get this:
                          TSP:PING:SEND (dest=0)<\n>
                          TSP:MSG:SEND 11-11-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1<\n>
                          TSP:CHKUPL:FAIL (hops=255)<\n>
                          !TSM:UPL:FAIL<\n>
                          Note that I don't use hardware ack. My assumption is that it takes too long to switch from send mode on the node to receive mode and that the gateway is responding too "fast" for the 1mhz node. Could this be possible?
                          I even tried out 57600baut serial data rate on the node thanks to this "calibration" sketch for the internal oscillator.
                            Serial.begin(57600);
                            pinMode(A4,OUTPUT);
                            Serial.println(OSCCAL);
                          // Use hterm to repeatatly send the same message unti you cacn read it
                            static uint8_t val = 140;
                            OSCCAL=val;
                            //Serial.println();
                            Serial.print("Osccal= ");
                            Serial.println(OSCCAL,DEC);
                            delay(500);
                            //digitalWrite(A4,HIGH);
                            //delay(1);
                            //digitalWrite(A4,LOW);
                            //delay(100);
                            while(Serial.available())
                              Serial.write(Serial.read());
                            val++;
                            if(val > 200)
                              val = 140;
                          Just add this
                          void before()
                            Serial.begin(MY_BAUD_RATE);
                            OSCCAL=150;
                          with 150 is the middle of the OSCCAL values where the serial calibration sketch is working. (its working from osccal 140 to osccal 160)
                          0_1472678204477_upload-47191440-9269-4f90-91af-f37336ce037f
                          • F flopp
                            F
                            F
                            flopp
                            @flopp said in [Tutorial] How to burn 1Mhz & 8Mhz bootloader using Arduino IDE 1.6.5-r5:
                            Yesterday I burn with above settings, I had to use 5v to power the pro mini(I don't know if the pro mini is 5 or 3.3v) I had to power it with 5v otherwise I couldn't burn any new bootloader.
                            • F flopp
                              @dpressle
                              low_fuses=0x42
                              extended_fuses=0x06
                              GertSandersG
                              GertSandersG
                              GertSanders
                              @flopp
                              To use the FTDI connection:
                              You need a ceramic cap (not polarised).
                              RTS - CAP - RESET pin of ATMEGA
                              RESET pin needs a pull up resistor of 10K, connect as follows: VCC - 10K resistor - RESET pin of ATMEGA
                              • MasMatM
                                MasMatM
                                MasMat
                                wrote on last edited by MasMat
                                #67
                                Help!
                                I semi-followed this thread but also built a shield like this:
                                http://www.instructables.com/id/Arduino-UNO-as-AtMega328P-Programmer/
                                For the Uno, the ArduinoISP sketch goes fine. After that, I connect the shield and 328p and upload stuff.
                                Since my build has 3.3V regulated power (using PCB My Slim 2AA Battery Node..but I can sneak wires to it easily so no need for batteries), I selected 'Board -> Pro Mini' and type '3.3V 8Mhz'. Burn bootloader goes fine, no errors. Upload sketch using programmer (Arduino as ISP) also uploads fine.
                                When I plug it in (USB FTDI-clone 3.3V selected) and see serial monitor, it remains blank. Nor does the node work when plugged into power.
                                Anybody else try this? Ideas? The slim node has all caps and resistor connected.
                                EDIT:
                                I used the recommended board download from 8Mhz instructions and bingo, it's working...partly. Have to check radio wiring.
                                Should just follow instructions and not go off on my own......
                                MasMatM 1 Reply Last reply
                                • MasMatM MasMat
                                  Help!
                                  EDIT:
                                  MasMatM
                                  MasMatM
                                  MasMat
                                  Continuing on...I need help getting my Atmega328P-PU to work.
                                  I'm able to burn the bootloader (8MHz on breadboard) and upload sketch ("using programmer"). However when I power the PCB, the sketch doesn't run. I soldered on a LED and uploaded BlinkWithoutDelay, just to verify that it works, but does not. I measured power and all connections. I'm powering with regulated 3.3V.
                                  To make things more weird, I connected FTDI to one node and with that connection it works fine. But when powering from pins, nothing (again using regulated 3.3V.
                                  • electrikE
                                    electrikE
                                    electrik
                                    That sounds more like your power connections are not good. You should check them again.
                                    Or perhaps the capacitor of the ftdi makes the difference, and you should add one in your circuit.
                                    Are the atmegas genuine or can they be fake ones?
                                    • electrikE electrik
                                      MasMatM
                                      MasMatM
                                      MasMat
                                      @electrik Everything's 100% chinese :)
                                      I checked power at all terminals and the atmega-connections, as well as radio hookup etc. I have all the caps on "My Slim Node" (4x 0,1yF and 4,7 yF). I normally get better power thru regulators than with FTDI but I did check that originally.
                                      I built two like this, same type of problem. I have Gert Sanders's "boards" installed. Is there a very basic setup I could try? I'm having trouble figuring out all the options that are available. All I want is Atmega working like a normal 3.3v/8MHz Arduino.
                                      • electrikE
                                        electrikE
                                        electrik
                                        Did you read this?
                                        https://forum.mysensors.org/topic/9388/atmega328p-au-counterfeit/15
                                        • MasMatM
                                          MasMatM
                                          MasMat
                                          #72
                                          I have now. I always have that nagging feeling...
                                          But after MANY iterations, finally success. At least partly. :v:
                                          BlinkWithoutDelay works AND mysensors sketch as well (will do more testing...).
                                          What made it work, if anyone else struggles with this:
                                          -connect uno (to computer-linux), board:uno, upload ArduinoISP, disconnect
                                          -add shield to uno and atmega328p-pu to shield, connect to computer, board: "8mhz on breadboard", "programmer: "Arduino as ISP", burn bootloader, disconnect
                                          -board: Uno, connect as above, "upload sketch using programmer", disconnect EDIT this last part appears to work but internal clock is all messed up. Bootloader works fine like this.
                                          The magic happened after I changed the board back to Uno after burning bootloader. Why is beyond me, but maybe some arduino-ninja can figure it out.
