  3. Home Assistant
  4. Can't see my nodes on HA web interface
20 Posts 6 Posters 7.5k Views 6 Watching
  • Dave DanD
    Dave DanD
    Dave Dan
    I had the same issue but adding this in the sensor config will make it work:
      optimistic: true
    I think is related to the fact that your node is not sending confirmation after assigning the new value (activating /deactivating the relay).
    • martinhjelmareM
      martinhjelmareM
      martinhjelmare
      Yes, @Dave-Dan is correct. Look at the example sketch, in the end, you'll see that the node sends confirmation of the updated state back to the gateway and controller.
      • D
        drock1985
        I've got an updated relay+button script at home that fixes this issue. I'll post it after work for anyone else who may need it.
        My Projects
        2 Door Chime Sensor
        Washing Machine Monitor
        A 1 Reply Last reply
        • maverickM
          maverickM
          maverick
          @Dave-Dan @martinhjelmare
          Guys, I've changed that configuration and it perfectly works !!!
          Now I'm going to automate all the house... ;-)
          Thanks for all the support and patience.
          • D drock1985
            anarro
            @drock1985, please can you share it?
            Thank you.
            Antoni.
            D 1 Reply Last reply
            • A anarro
              Thank you.
              Antoni.
              drock1985
              @anarro
              I looked for the sketch the other night and I must have not backed it up on my laptop. I'll see if I can find it in a backup on the weekend/recreate it.
              My Projects
              2 Door Chime Sensor
              • maverickM
                maverickM
                maverick
                Guys, I'm adding this info to the thread just in case that someone may get this useful.
                This is my final sketch:
                 * Version 1.0 - Henrik Ekblad
                 * Example sketch showing how to control physical relays.
                 * This example will remember relay state after power failure.
                 * http://www.mysensors.org/build/relay
                #include <MySigningNone.h>
                #include <MyTransportNRF24.h>
                #include <MyTransportRFM69.h>
                #include <MyHwATMega328.h>
                #define SN "Living Foot Lamp"
                #define SV "1.0"
                #define NODE_ID 19
                #define RELAY_PIN  3  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                #define RELAY_CHILD 1
                MyTransportNRF24 radio(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
                // Select AtMega328 hardware profile
                MyHwATMega328 hw;
                MySensor gw(radio, hw);
                MyMessage msg(RELAY_CHILD, V_STATUS);
                  gw.begin(incomingMessage, NODE_ID);
                  gw.sendSketchInfo(SN, SV);
                  gw.present(RELAY_CHILD, S_LIGHT);
                  pinMode(RELAY_PIN, OUTPUT);
                  gw.send(msg.set(0));
                  if (message.type==V_STATUS) {
                     // Change relay state
                     digitalWrite(RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
                      // debug info
                I'm not finished my board, but here are some pictures showing how I assembled all the pieces
                Video: Show how is The Relay is Working
                • D
                  drock1985
                  @anarro
                  Hey, I am going through and upgrading my nodes to 2.0 Beta; the same 'bug' exists there so I had to patch it to work with HA.
                  Use this code from the 2.0 Beta. Basically all you have to do is tell the node to broadcast its state on receipt of message. This works from both the button and the HA web interface.
                   * Example sketch for a "light switch" where you can control light or something
                   * else from both HA controller and a local physical button
                   * (connected between digital pin 3 and GND).
                   * This node also works as a repeader for other nodes
                  #define MY_REPEATER_FEATURE
                  #define MY_NODE_ID 4
                  #define RELAY_PIN  3  // Arduino Digital I/O pin number for relay
                  #define BUTTON_PIN  6  // Arduino Digital I/O pin number for button
                  #define RELAY_ON 1
                  #define RELAY_OFF 0
                  Bounce debouncer = Bounce();
                  int oldValue=0;
                  bool state;
                    // Setup the button
                    pinMode(BUTTON_PIN,INPUT);
                    // Activate internal pull-up
                    debouncer.attach(BUTTON_PIN);
                    debouncer.interval(5);
                    state = loadState(CHILD_ID);
                  //  send(msg.set(1));
                  void presentation()  {
                    sendSketchInfo("Lamp", "1.0");
                    present(CHILD_ID, S_LIGHT);
                  *  Example on how to asynchronously check for new messages from gw
                    debouncer.update();
                    // Get the update value
                    int value = debouncer.read();
                    if (value != oldValue && value==0) {
                        send(msg.set(state?false:true), true); // Send new state and request ack back
                    oldValue = value;
                    if (message.isAck()) {
                       state = message.getBool();
                       send(msg.set(state?RELAY_ON:RELAY_OFF));
                       // Store state in eeprom
                       saveState(CHILD_ID, state);
                  My Projects
                  2 Door Chime Sensor
                  adrianA 1 Reply Last reply
                  • maverickM
                    maverickM
                    maverick
                    @anarro
                    Awesome! Thanks mate
                    • D drock1985
                      @anarro
                      #define RELAY_ON 1
                      #define RELAY_OFF 0
                      int oldValue=0;
                      bool state;
                        // Setup the button
                        debouncer.update();
                        oldValue = value;
                      adrianA
                      adrianA
                      adrian
                      @drock1985
                      I tried your sketch mate but I still can't see my relay node in the webif.
                      Binary sensors work great but I can't get the the relay node to work.
                      Node serial
                      Starting repeater (RNNRA-, 2.0.0)
                      TSM:INIT
                      TSM:RADIO:OK
                      TSP:ASSIGNID:OK (ID=7)
                      TSM:FPAR
                      TSP:MSG:SEND 7-7-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                      TSP:MSG:READ 0-0-7 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                      TSP:MSG:PAR OK (ID=0, dist=1)
                      TSM:FPAR:OK
                      TSM:ID
                      TSM:CHKID:OK (ID=7)
                      TSM:UPL
                      TSP:PING:SEND (dest=0)
                      TSP:MSG:SEND 7-7-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                      TSP:MSG:READ 0-0-7 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                      TSP:MSG:PONG RECV (hops=1)
                      TSP:CHKUPL:OK
                      TSM:UPL:OK
                      TSM:READY
                      NODE:!REG
                      TSP:MSG:SEND 7-7-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                      TSP:MSG:SEND 7-7-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                      TSP:MSG:SEND 7-7-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                      TSP:MSG:READ 0-0-7 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                      TSP:MSG:READ 0-0-7 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                      TSP:MSG:SEND 7-7-0-0 s=255,c=3,t=11,pt=0,l=4,sg=0,ft=0,st=ok:Lamp
                      TSP:MSG:SEND 7-7-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                      TSP:MSG:SEND 7-7-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                      Request registration...
                      TSP:MSG:SEND 7-7-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                      TSP:MSG:READ 0-0-7 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                      Node registration=1
                      Init complete, id=7, parent=0, distance=1, registration=1
                      The sketch is the same I just changed MySensor.h to MySensors.h and the NODE ID to 7,
                      HA log
                      16-07-30 11:21:15 homeassistant.components.mysensors: update sensor_update: node 7
                      • adrianA adrian
                        @drock1985
                        Node serial
                        TSM:INIT
                        TSM:RADIO:OK
                        TSM:FPAR
                        TSM:FPAR:OK
                        TSM:ID
                        TSM:CHKID:OK (ID=7)
                        TSM:UPL
                        TSP:CHKUPL:OK
                        TSM:UPL:OK
                        TSM:READY
                        NODE:!REG
                        Node registration=1
                        HA log
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        @adrian
                        No value is sent for the light in the log. Home assistant needs at least one value to show the device in the gui.
                        In 2.0.0 setup is called before presentation, and the node is not registered on the gateway until after presentation. The node is not allowed to send regular messages until it's registered. This logic flow makes it hard for controllers that need an initial value. You have to make sure to send the value at least once in the loop. I would try to do this specifically and separate from the normal flow of the loop.
                        In the dev branch of mysensors setup is called after registration, so there you could send the initial value in setup.
                          @adrian
                          adrianA
                          adrianA
                          adrian
                          @martinhjelmare
                          For now I should send the state msg from the loop?
                          Can you share one of your sketches?
                          Thanks a lot
                          • adrianA adrian
                            @martinhjelmare
                            Thanks a lot
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @adrian
                            I would try something like this:
                            #define MY_NODE_ID 1
                            #define RELAY_PIN  5  // Arduino Digital I/O pin number for relay
                            #define BUTTON_PIN  3  // Arduino Digital I/O pin number for button
                            #define CHILD_ID 1
                            #define RELAY_ON 1
                            #define RELAY_OFF 0
                            bool state = false;
                            bool initialValueSent = false;
                              // Setup the button
                              pinMode(BUTTON_PIN, INPUT_PULLUP);
                              debouncer.interval(10);
                              present(CHILD_ID, S_BINARY);
                              if (!initialValueSent) {
                                Serial.println("Sending initial value");
                                Serial.println("Requesting initial value from controller");
                                request(CHILD_ID, V_STATUS);
                                wait(2000, C_SET, V_STATUS);
                              if (debouncer.update()) {
                                if (debouncer.read()==LOW) {
                                  state = !state;
                                  send(msg.set(state?RELAY_ON:RELAY_OFF), true); // Send new state and request ack back
                                  Serial.println("Receiving initial value from controller");
                                  initialValueSent = true;
                                state = (bool)message.getInt();
                            Node serial log:
                            TSM:INIT
                            TSM:RADIO:OK
                            TSP:ASSIGNID:OK (ID=1)
                            TSM:FPAR
                            TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
                            TSP:MSG:READ 0-0-1 s=255,c=3,t=8,pt=1,l=1,sg=0:0
                            TSM:FPAR:OK
                            TSM:ID
                            TSM:CHKID:OK (ID=1)
                            TSM:UPL
                            TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
                            TSP:MSG:READ 0-0-1 s=255,c=3,t=25,pt=1,l=1,sg=0:1
                            TSP:CHKUPL:OK
                            TSM:UPL:OK
                            TSM:READY
                            TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                            TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                            TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
                            TSP:MSG:READ 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                            TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=4,sg=0,ft=0,st=ok:Lamp
                            TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
                            TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
                            TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                            TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                            Node registration=1
                            Init complete, id=1, parent=0, distance=1, registration=1
                            TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
                            TSP:MSG:SEND 1-1-0-0 s=1,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=ok:
                            TSP:MSG:READ 0-0-1 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                            Incoming change for sensor:1, New status: 0
                            TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:1
                            TSP:MSG:READ 0-0-1 s=1,c=1,t=2,pt=2,l=2,sg=0:1
                            Incoming change for sensor:1, New status: 1
                            TSP:MSG:READ 0-0-1 s=1,c=1,t=2,pt=2,l=2,sg=0:0
                            Btw, message.getBool() always returns 0 in my tests, so I switched to message.getInt() in the sketch above. Can anyone confirm that message.getBool is working in 2.0.0?
