  3. Video How To - Monitor your Refrigerator
37 Posts 16 Posters 46.2k Views 14 Watching
    Stric
    When I arrived at work today and started checking mails, I had received a bunch of them saying that the temperature in the fridge was too high, so I had to drive home and close the door. I would have gotten a notification earlier through jabber if the server software we use for jabber wasn't acting up :(.
    MySensors stuff was not involved in that particular sensor (esic sensor + tellstick + perl + perl), but the need to monitor this stuff was definitely there.
    petewillP 1 Reply Last reply
    • S Stric
      petewillP
      petewillP
      petewill
      @Stric Dang. Glad you caught it in time! The need to monitor is definitely real. I also want to get my house outfitted with leak detectors at some point...
      • KrieghundK
        KrieghundK
        Krieghund
        I'm sorry to ask a seemingly dumb question, but what do I need to do to get a third Dallas sensor to work? (I have a top/bottom fridge and a deep freezer).
        I edited the following lines:
        DeviceAddress dallasAddresses[] = {
        {0x28, 0x29, 0x4F, 0x1, 0x0, 0x0, 0x80, 0xBB}, //Freezer Address -- Modify for your sensors
        {0x28, 0x22, 0x53, 0x1, 0x0, 0x0, 0x80, 0x1E}, //Fridge Address -- Modify for your sensors
        ** {0x28, 0xA6, 0x58, 0x1, 0x0, 0x0, 0x80, 0x58} //Deep Freezer I added**
        // set the temp resolution
        for (uint8_t i = 0; i < 3; i++) { //i changed from 2
        // Present temp sensors to controller
        ** for (int i = 0; i < 3; i++) { // i changed from 2**
        gw.present(i, S_TEMP);
        ** for (int i = 0; i < 3; i++) { //i changed from 2**
        I'm not sure what I'm missing. Thank you in advance for your help and great project!!!
        KrieghundK 1 Reply Last reply
        • KrieghundK Krieghund
          KrieghundK
          KrieghundK
          Krieghund
          @Krieghund
          Ok, I think I found it. I needed to have the door sensors start at a higher ID:
          int doorChildren[] = {3, 4}; //i changed from 2,3
          Thank you
            @Krieghund
            Thank you
            petewillP
            petewillP
            petewill
            @Krieghund Glad you found it! Sorry, I couldn't respond sooner.
            • CrankyCoderC
              CrankyCoderC
              CrankyCoder
              any chance this has been updated to 2.0? I am having issues getting the internal pull up for the temp sensors working.
              Home Automation Tinkerer
              www.CrankyCoder.net
              Gateway: MQTTClientGateway
              MySensors: 2.3
              • CrankyCoderC CrankyCoder
                petewillP
                petewillP
                petewill
                wrote on last edited by petewill
                #24
                @Jason-Brunk Sorry for the delay. What's the problem? I don't think that would be related to v2.0 but I could be wrong. Have you tried an external resistor?
                • CrankyCoderC
                  CrankyCoderC
                  CrankyCoder
                  my 4.7k resistors showed up today. So i will try with the external.
                  I have been able to get basic arduino sketches to work with the internal pull up and the temp sensor. but as soon as I put mysensors on it, it doesn't pick it up any more. That's why i figured i would see if you updated your sketch to 2 without the need for the external
                  www.CrankyCoder.net
                  MySensors: 2.3
                    petewillP
                    petewillP
                    petewill
                    @Jason-Brunk Interesting. I haven't updated it yet. I need to get a spare weekend to make the jump to 2.0 but I don't know when that will be. I have so many sensors in my house it will take me a while to get everything up to date.
                    • CrankyCoderC
                      CrankyCoderC
                      CrankyCoder
                      I can only imagine. I have seen your youtube channel. jealous
                      www.CrankyCoder.net
                      MySensors: 2.3
                      • TXSpazzT
                        TXSpazzT
                        TXSpazz
                        This is my first sensor so be nice if I'm missing something obvious. :smile:
                        Your sketch has #include <MySensor.h>
                        In the mysensors library it is MySensors.h with an s
                        If I change it to #include <MySensors.h> with the s then on the line with MySensor gw; I get the error: 'MySensor' does not have a name type.
                        I'm trying to figure out how everything works together but can't figure this out.
                        For reference, my programming background consists of an 8th grade computer class where we learned to make something go from one side of the monitor to the other and yes, it was all green.
                        • TXSpazzT TXSpazz
                          mbj
                          wrote on last edited by mbj
                          #29
                          @TXSpazz This difference depends on what version you are using. For version 2 it is Mysensors.h . Earlier versions used Mysensor.h.
                          TXSpazzT 1 Reply Last reply
                          • M mbj
                            TXSpazzT
                            TXSpazzT
                            TXSpazz
                            @mbj Thank you, I was wondering if that was it. I started trying to convert it but since I haven't slept in 23 hours it made my brains hurt, but at least I know what direction to go now.
                            • TXSpazzT TXSpazz
                              petewillP
                              petewillP
                              petewill
                              @TXSpazz Yeah, @mbj is right, it needs to be updated to v2.0. Still haven't had a chance to do it yet :grimacing:
                              • jmkhaelJ
                                jmkhaelJ
                                jmkhael
                                Great work. I've watched almost all your videos. Very instructive.
                                One thing I am wondering about are the gray connectors 'knob like' to quickly wire your cables together. What are they? Where can I buy me some? :bowtie:
                                • jmkhaelJ jmkhael
                                  petewillP
                                  petewillP
                                  petewill
                                  @jmkhael Are you talking about wire nuts perhaps (at least that's what I call them)? I get mine from a local store. http://www.harborfreight.com/158-piece-wire-connector-assortment-67520.html but it looks like ebay has some too. http://www.ebay.com/itm/70Pcs-Electrical-Wire-Twist-Connector-Nut-Terminals-Cap-Spring-Insert-Assortment-/401077102029?hash=item5d620ee5cd:g:5~sAAOSwe7BWzS4k
                                  • jmkhaelJ
                                    jmkhaelJ
                                    jmkhael
                                    Yes. those! thank you
                                    • N
                                      N
                                      Newzwaver
                                      HI
                                      Do you think you can use the PT1000 two wire temp sensor for this project? I have a number of them and they are water proof and very durable.
                                      • N Newzwaver
                                        HI
                                        mbj
                                        @Newzwaver If you Google on this subject you will find threads like this one which may help you understand the issue: http://forum.arduino.cc/index.php?topic=16731.0
                                        Basically I think the answer is that if you already have the electronics to read the signal from the PT1000 and can communicate that to a Mysensors sensor it should be fairly easy. If you have to build it all by yourself it is a bit more work to do like the thread above shows.
                                        On the other hand, buying a few DS18B20 is dirt cheap and and then everything you need is already available. They come in waterproof versions as well if you feel you need this. One example from Ebay is http://www.ebay.com/itm/NEW-Waterproof-Digital-Thermal-Probe-or-Sensor-DS18B20-Length-1M-/172243763999?hash=item281a87431f:g:Lj8AAOSw3YNXYu7h
                                        • N
                                          N
                                          Newzwaver
                                          Hi
                                          And thanks for the reply, I do have the PT1000 as well as those sensors. The only thing is I am trying to find a use for the PT1000. I have already placed one in my deep freeze and one out door but have several more that I just want to use. It's not the cost as most of the projects on this are cheap, it's the challenge of getting it done.
                                          Thanks again, I
