  3. Video How To - Monitor your Refrigerator
37 Posts 16 Posters 46.2k Views 14 Watching
  • CrankyCoderC
    CrankyCoderC
    CrankyCoder
    my 4.7k resistors showed up today. So i will try with the external.
    I have been able to get basic arduino sketches to work with the internal pull up and the temp sensor. but as soon as I put mysensors on it, it doesn't pick it up any more. That's why i figured i would see if you updated your sketch to 2 without the need for the external
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    petewillP 1 Reply Last reply
    • CrankyCoderC CrankyCoder
      petewillP
      petewillP
      petewill
      @Jason-Brunk Interesting. I haven't updated it yet. I need to get a spare weekend to make the jump to 2.0 but I don't know when that will be. I have so many sensors in my house it will take me a while to get everything up to date.
      • CrankyCoderC
        CrankyCoderC
        CrankyCoder
        I can only imagine. I have seen your youtube channel. jealous
        www.CrankyCoder.net
        MySensors: 2.3
        • TXSpazzT
          TXSpazzT
          TXSpazz
          This is my first sensor so be nice if I'm missing something obvious. :smile:
          Your sketch has #include <MySensor.h>
          In the mysensors library it is MySensors.h with an s
          If I change it to #include <MySensors.h> with the s then on the line with MySensor gw; I get the error: 'MySensor' does not have a name type.
          I'm trying to figure out how everything works together but can't figure this out.
          For reference, my programming background consists of an 8th grade computer class where we learned to make something go from one side of the monitor to the other and yes, it was all green.
          • TXSpazzT TXSpazz
            mbj
            wrote on last edited by mbj
            #29
            @TXSpazz This difference depends on what version you are using. For version 2 it is Mysensors.h . Earlier versions used Mysensor.h.
            TXSpazzT 1 Reply Last reply
            • M mbj
              TXSpazzT
              TXSpazzT
              TXSpazz
              @mbj Thank you, I was wondering if that was it. I started trying to convert it but since I haven't slept in 23 hours it made my brains hurt, but at least I know what direction to go now.
              • TXSpazzT TXSpazz
                petewillP
                petewillP
                petewill
                @TXSpazz Yeah, @mbj is right, it needs to be updated to v2.0. Still haven't had a chance to do it yet :grimacing:
                • jmkhaelJ
                  jmkhaelJ
                  jmkhael
                  Great work. I've watched almost all your videos. Very instructive.
                  One thing I am wondering about are the gray connectors 'knob like' to quickly wire your cables together. What are they? Where can I buy me some? :bowtie:
                  • jmkhaelJ jmkhael
                    petewillP
                    petewillP
                    petewill
                    @jmkhael Are you talking about wire nuts perhaps (at least that's what I call them)? I get mine from a local store. http://www.harborfreight.com/158-piece-wire-connector-assortment-67520.html but it looks like ebay has some too. http://www.ebay.com/itm/70Pcs-Electrical-Wire-Twist-Connector-Nut-Terminals-Cap-Spring-Insert-Assortment-/401077102029?hash=item5d620ee5cd:g:5~sAAOSwe7BWzS4k
                    • jmkhaelJ
                      jmkhaelJ
                      jmkhael
                      Yes. those! thank you
                      • N
                        N
                        Newzwaver
                        HI
                        Do you think you can use the PT1000 two wire temp sensor for this project? I have a number of them and they are water proof and very durable.
                        • N Newzwaver
                          HI
                          mbj
                          @Newzwaver If you Google on this subject you will find threads like this one which may help you understand the issue: http://forum.arduino.cc/index.php?topic=16731.0
                          Basically I think the answer is that if you already have the electronics to read the signal from the PT1000 and can communicate that to a Mysensors sensor it should be fairly easy. If you have to build it all by yourself it is a bit more work to do like the thread above shows.
                          On the other hand, buying a few DS18B20 is dirt cheap and and then everything you need is already available. They come in waterproof versions as well if you feel you need this. One example from Ebay is http://www.ebay.com/itm/NEW-Waterproof-Digital-Thermal-Probe-or-Sensor-DS18B20-Length-1M-/172243763999?hash=item281a87431f:g:Lj8AAOSw3YNXYu7h
                          • N
                            N
                            Newzwaver
                            Hi
                            And thanks for the reply, I do have the PT1000 as well as those sensors. The only thing is I am trying to find a use for the PT1000. I have already placed one in my deep freeze and one out door but have several more that I just want to use. It's not the cost as most of the projects on this are cheap, it's the challenge of getting it done.
                            Thanks again, I
