  2. Bug Reports
  3. MySensor.h error
MySensor.h error
8 Posts 5 Posters 7.2k Views 4 Watching
  • nicorodriN Offline
    nicorodriN Offline
    nicorodri
    Hi Everybody,
    What's wrong with this library? I'am trying everything (replacing the IDE, the library, type of board, etc) without success.
    Could any one help me?
    Thank you very much!
    Nicolas
    **Arduino:1.6.9 (Windows 10), Tarjeta:"Arduino/Genuino Uno"
    C:\Users\Nicolás Rodríguez To\Documents\Arduino\IrrigationController\IrrigationController.ino:88:22: fatal error: MySensor.h: No such file or directory
    compilation terminated.
    exit status 1
    Error compilación en tarjeta Arduino/Genuino Uno.
    Este reporte podría tener más información con
    "Mostrar salida detallada durante la compilación"
    opción habilitada en Archivo -> Preferencias.**
    TheoLT 1 Reply Last reply
    • fetsF Offline
      fetsF Offline
      fets
      @nicorodri did you install librairies as mentionned here in section "Installing the sensor libraries"
      • nicorodriN nicorodri
        Hi Everybody,
        Nicolas
        exit status 1
        TheoLT Offline
        TheoLT Offline
        TheoL
        @nicorodri I ran into the same problem today, when I tried to compile the sketch in the API documentation. There might be a bug in that sketch. It's saying:
        Which should be:
        At least it got it working for me. Maybe @hek is able to verify the bug and adjust the example sketch stated here https://www.mysensors.org/download/sensor_api_20
        • tbowmoT Offline
          tbowmoT Offline
          tbowmo
          the header file is renamed to MySensors.h now, to comply with the library name (which is MySensors)
          I believe that the examples on github (here and here) should be changed to use the new file name..
          • tbowmoT tbowmo
            TheoLT Offline
            TheoLT Offline
            TheoL
            @tbowmo glad that it's confirmed. I was beginning to think I'm getting crazy ;-)
            • hekH Offline
              hekH Offline
              wrote on last edited by hek
              @theol, Thanks, I'll update the main site accordingly.
              Edit: done
                Edit: done
                TheoLT Offline
                TheoLT Offline
                TheoL
                @hek Thank you. Does this name change mean, that I can keep 1.5 and 2.0 beside eachother? Would be great and handy for the next couple of months/weeks
                • hekH Offline
                  hekH Offline
                  No, wouldn't recommend it. Besides the folder name was MySensors in 1.5.4 as well.
                  https://github.com/mysensors/MySensors/tree/1.5.4/libraries/MySensors
                  11.9k
                  113.3k
