  3. Burn bootloader while NRF24L01 is connected
11 Posts 2 Posters 2.6k Views 2 Watching
  • F Offline
    F Offline
    flopp
    I think I have distroyed many ATmega328p when I am trying to burn bootloader to it while NRF24L01 is connected to ATmega, both are using MISO, MOSI and SCK.
    Can anyone confirm my thoughts?
    • F Offline
      F Offline
      Fabien
      No, uselly you have "Enable" pin with pullup
      • F Offline
        F Offline
        flopp
        wrote on last edited by flopp
        So they are not distroyed?
        But I cant upload new bootloader when NRF is connected the ATmega always answer
        avrdude: Device signature = 0x000000
        avrdude: Yikes!  Invalid device signature.
        I remove the NRF and still answer
        • F Offline
          F Offline
          Fabien
          check ou have pullup resistor on CSN. Or you can try to remove NRF24 and try to burn bootloader.
          F 1 Reply Last reply
          • F Fabien
            F Offline
            F Offline
            flopp
            See above: I get same answer when NRF is removed
            • F Offline
              F Offline
              Fabien
              I don't know why your atmega isn't responding but it's not related to programming when NRF is connected.
              Can you check the fuse ? Is it work with new atmega you ISP hardware is ok ?
              F 2 Replies Last reply
              • F Fabien
                F Offline
                F Offline
                flopp
                Yes, it works with new atmega.
                I am using Arsuino UNO as ISP.
                I will try to find a way to read fuses or maybe it is writing when I use AVRdude manually
                • F Offline
                  F Offline
                  flopp
                  I tried with new atmega, it worked fine, so I tried with new atmega and NRF connected, worked fine. So I can be sure that the problem was/is not the NRF, as @Fabien said, thanks.
                  I don't understand what it can be, I have destroyed maybe 5 pieces when I try to upload new sketch, through Arduino UNO as ISP, maybe it can be power problem or maybe the wires got loosen when I upload sketch?
                  • F Fabien
                    F Offline
                    F Offline
                    flopp
                    I cannot check the fuses, atmega doesn't answer.
                    • F Offline
                      F Offline
                      flopp
                      I am using IDE 1.6.8
                      • F Offline
                        F Offline
                        flopp
