  3. [Solved]Gateway and Sensor not working , TSM:RADIO:FAIL
9 Posts 3 Posters 8.7k Views 3 Watching
  • Jan RößlerJ
    Jan RößlerJ
    Jan Rößler
    wrote on last edited by tekka
    Hello ,
    im trying to get everything working but it giving me errors on Serial Monitor.
    im using the Example Sketch of gateway and Relay.
    mysensors version is the newest 2.0.0
    I hope someone can help me to sort this out.
    My Hardware:
    2x Arduino Nano 5V and 3V3
    2x NRF24L01 + PA + LNA
    1x 4x5V Relays ( Only One connected )
    Gateway:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;!TSM:RADIO:FAIL
    0;255;3;0;9;!TSM:FAILURE
    0;255;3;0;9;TSM:PDT
    Relay Actuator
    Starting repeater (RNNRA-, 2.0.0)
    TSM:INIT
    !TSM:RADIO:FAIL
    !TSM:FAILURE
    TSM:PDT
    • Jan RößlerJ Jan Rößler
      Hello ,
      My Hardware:
      Gateway:
      0;255;3;0;9;TSM:PDT
      Relay Actuator
      TSM:INIT
      !TSM:RADIO:FAIL
      !TSM:FAILURE
      TSM:PDT
      @Jan-Rößler welcome to the MySensors community!
      the most common reason for radio init fail is miswired radio or power issues. The flowchart at https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help can be useful when troubleshooting.
      Have you double-checked the wires between the arduinos and the radios? How are you powering the radios? What capacitors are you using and are the capacitors connected with correct polarity?
      • Jan RößlerJ
        Jan RößlerJ
        Jan Rößler
        Changed the power supply it still dont work. capacitor im using a 10 µf ( i have no other one )
        This is how i wired everything , i think there is the misstake , where can i find the wire layout for arduino Nano ?
          @Jan-Rößler use D9, D10, D11, D12 and D13 like the bottom picture and you should be fine
          J 1 Reply Last reply
          • Jan RößlerJ
            Jan RößlerJ
            Jan Rößler
            ok thanks it works now :D thanks alot
              @Jan-Rößler you're welcome! Thanks for reporting back.
                J
                J
                Jean-sebastien Bridoux
                @mfalkvidd Hello mfalkvidd, I am new on this forum but I had followed Mysensors for a long time. I have the same symptoms as Jan meets. we checked double the wiring connection, and change NRF24L01 module . always the same message:
                0;255;3;0;9;TSM:PDT
                I Have tried two ways ESP8266 + NRF24L01 (gateway ESP8266) and Arduino NANO + NRF24L01 (serial gateway)same error...
                For both assemblies, I used the schematics from mysensors site (connecting radio).
                I don't know what I missed, do you have any Idea?
                Thank you for your help
                • J Jean-sebastien Bridoux
                  0;255;3;0;9;TSM:PDT
                  Welcome to the forum @Jean-sebastien-Bridoux
                  Sorry, I don't have any ideas for further troubleshooting.
                    J
                    J
                    @mfalkvidd Ok thanks for your reply
