  3. Arduinon startup complete request strange behaviour (python)
12 Posts 2 Posters 3.8k Views 1 Watching
  • marceltrapmanM
    marceltrapmanM
    marceltrapman
    @hek is it in any way possible that messages get scrambled on the gateway when they cross each other?
    Fulltime Servoy Developer
    hekH 1 Reply Last reply
      @marceltrapman
      No, i don't really see how this could happen. Do you have any idea what other message it could have gotten mixed up with?
      What happens if you turn of debug-printing does it disappear?
      • marceltrapmanM
        marceltrapmanM
        marceltrapman
        This happened with and without debug printing.
        The funny thing is that it appeared 'out of the blue', showed up a couple of restarts and it looks like it disappeared again with the last restart.
        I will keep an eye on it since I will need a lot of restarts before I am ready with the plugin ")
        • marceltrapmanM
          marceltrapmanM
          marceltrapman
          wrote on last edited by marceltrapman
          OK, this time it is completely clear to me but I don't know why yet.
          Receiving command 1;2;2;2;0;0;4;11;Arduino startup complete.
          Two sensor/gateway messages were concatenated.
          The first a relay device 'reporting for duty', asking for the registered state of itself 1;2;2;2;
          And following the gateway reporting for duty: 0;0;4;11;Adruino startup complete
          Strange though that the gateway presentation comes after the sensor presentation...
            @marceltrapman
            Are you really "breaking" the commands on newline character on the phyton side? Please post your code ;)
            • marceltrapmanM
              marceltrapmanM
              marceltrapman
              See below, the answer is yes. I do a readline() and it breaks on '\n' by default and MySensors does the same.
              BTW I added the flush() after sending my previous post as well as removing all sleeping code from the sensor.
              I will start playing with this because I suspect one of these two (or both) solved the issue.
              I now see Receiving command 0;0;4;11;Arduino startup complete. before anything else :)
              EDIT: false alarm. A new upload of the sketch and a restart made the issue appear again :(
                  try:
                      request = self.connection.readline()
                  except:
                      self.debugLog("Unexpected error:", sys.exc_info()[0])
                      request = None
                  finally:
                      self.connection.flush()
                      if request:
                          request = request.strip("\n\r")
                          self.debugLog("Receiving command %s" % request)
                    try:
                    except:
                        request = None
                    finally:
                        if request:
                @marceltrapman
                Should you really flush after calling readline()?
                • marceltrapmanM
                  marceltrapmanM
                  marceltrapman
                  Nope, this was a 'if it does not help it will not hurt'.
                  I am going to remove it.
                    Hard to say,
                    It surely looks like readline() gives back more that one line to me.
                    I'm no phyton expert. But where is request-variable declared? Is it cleared between runs?
                    • marceltrapmanM
                      marceltrapmanM
                      marceltrapman
                      Yes, all variables are cleared before I re-use them which is completely obsolete even because they are defined in the method and the method is called from within a/the loop.
                      I will ask the Indigo gurus about this...
                      12.5k
