  3. [Solved] API 2.0 void receive(const MyMessage& message) Problem
8 Posts 2 Posters 2.8k Views 2 Watching
  • P Offline
    P Offline
    paqor
    wrote on last edited by tekka
    Hello, unfortunately is triggered no message here. The "textField" I applied and it is also available with a value. It is not even the "println" will be displayed. What am I doing wrong?
    sleep(SLEEP_TIME); //sleep for: sleepTime
    //incomingMessage_____________________________________________________
      gasSensor.setR0(R0C);
     Serial.println(F("Incoming Message:"));
    • P paqor
      T Offline
      T Offline
      TheoL
      @paqor I wouldn't put sensor readings in a message handler. Could you try this, just to test the messages?
      wait(SLEEP_TIME); //sleep for: sleepTime // byTheo: Changed
      //  gasSensor.setR0(R0C);  // byTheo: Changed
      // Serial.println(F("Incoming Message:")); // byTheo: Changed
      Serial.println("Incoming Message:");
      And I also advice not to use sleep when having a node that can receive messages.
      • P Offline
        P Offline
        paqor
        VIELEN VIELEN DANK!!!!
        Thanks alot:smiley:
        • P paqor
          Thanks alot:smiley:
          T Offline
          T Offline
          TheoL
          @paqor That it solve your problem?
          P 1 Reply Last reply
          • T TheoL
            P Offline
            P Offline
            paqor
            wrote on last edited by paqor
            Yes
            https://gleisnetze.de/2016/08/07/sensoren4sketch-v0-6-under-contrstruction/
            • P paqor
              Yes
              T Offline
              T Offline
              TheoL
              @paqor That's great. I looked at the Sketch you posted on your site and noticed you're still using a delay. Which as short as it may be can cause messages to be missed.
              void loop(){
              //TEMP_FEUCHTE
              My advice is to do this with a wait as well.
              void loop(){
              //TEMP_FEUCHTE
              wait(dht.getMinimumSamplingPeriod()); // Changed ByTheo
              That way you don't block incoming messages. Generally, if you want your sketch to wait use a wait.
              • P Offline
                P Offline
                paqor
                Okay, super, Thank you very much for your effort. I will correct it immediately
                • T TheoL
                  void loop(){
                  //TEMP_FEUCHTE
                  void loop(){
                  //TEMP_FEUCHTE
                  P Offline
                  P Offline
                  paqor
                  void loop(){
                  //TEMP_FEUCHTE
                  void loop(){
                  //TEMP_FEUCHTE
                  genial, works perfectly....
