  3. Powering a sensor with digital out
27 Posts 7 Posters 6.5k Views 7 Watching
  • mfalkviddM
    You could try changing
    const int VAL_PROBE = 0; // initializing the moisture variable
    to
    #define VAL_PROBE A0
    I don't see any point in declaring it const int, and I prefer to use the An naming to make it clear which pin I am using.
    • hozzeH
      hozzeH
      hozze
      wrote on last edited by hozze
      @TheoL , Thanks for the suggestion . Tried that, same result.
      @mfalkvidd , Thanks for the code suggestion, I made the change. Regarding the issue, I did check with a multi-meter and it shows 0V . To make sure I also used the example blink sketch with pin 2 as output and it is showing 3.24V I will attach the wiring diagram(I haven't drawn one). Things I noticed.
      • On commenting the Mysensor.h library and related code from above sketch I'm able to turn on the Pin
      • I tried using different digital pins and same result.
      • To make sure I measured the output pin voltage powering it with USB ( without connecting the board to radio and soil sensor ) , same result voltage is 0V
      • hozzeH hozze
        @hozze looks like good troubleshooting, great work.
        Very interesting that it works when uncommenting the MySensors stuff. I think there are some leds blinking features in 2.0 (have not yet moved to 2.0 myself so I don't know more than what I've read in the forum), but I think that is only enabled for gateways.
        Does it help if you remove include <SPI.h>? It looks like SPI is not used so it shouldn't make a difference but you might as well remove it if you aren't using it.
          This feature is also present in previous versions and not limited to gateways.
          Pin 2 however is never used for leds as it is the default irq pin for nRF.
          Try with another pin, e.g. 4/5/6 and see if that makes a difference.
          • hozzeH
            hozzeH
            hozze
            @mfalkvidd : Removed SPI.h , it didn't help though. Thanks for pointers on cleaning up the code :smiley:
            @Yveaux :
            Tried with pin 5 , same result.
            Tried using a different pro mini ( Atmega328 16Mhz 5 v ) got same result , no output on pin :expressionless:
            • hozzeH hozze
              @Yveaux :
              @hozze make sure you don't define MY_LEDS_BLINKING_FEATURE or MY_INCLUSION_MODE_FEATURE, as their pin mappings might interfere with your application.
              • hozzeH
                hozzeH
                hozze
                @Yveaux I don't have those defined. Below is my current code.
                #define MY_NODE_ID 1  // node id
                #define MY_RADIO_NRF24  // enabling support for NRF radio module
                #define NODE_ID 1  // sensor id
                #define SENS_ON 5
                MyMessage msg(NODE_ID, V_LEVEL); // constructing the msg
                  pinMode(SENS_ON, OUTPUT);
                  present(NODE_ID, S_MOISTURE);  // presenting the sensor
                  sendSketchInfo("SoilSensor", "0.1"); //meta data
                  digitalWrite(SENS_ON, HIGH);
                  delay(1000); // To check the input voltage of pin 2
                  int moisture = analogRead(VAL_PROBE); //measuring the moisture
                  send(msg.set(moisture));  // sending the data
                  digitalWrite(SENS_ON, LOW); // turn it off
                //  sleep(1000);  // sleeping for 10 sec
                An as soon as I comment it out like below the pin out on 5 works
                #define SENS_ON 5
                //#include <MySensors.h>
                //  present(NODE_ID, S_MOISTURE);  // presenting the sensor
                //  sendSketchInfo("SoilSensor", "0.1"); //meta data
                // send(msg.set(moisture));  // sending the data
                • hozzeH hozze
                  #define SENS_ON 5
                  #define SENS_ON 5
                  @hozze it's strange that you only measure 3.24V on the output pin if you're using a 5V pro mini. This is IMHO an indication that something is wrong, also when your pin does seem to toggle.
                  TheoLT 1 Reply Last reply
                  • hozzeH
                    hozzeH
                    hozze
                    I see that output on pro mini Atmega168 3.3v with commented sketch.
                    I tried with a different 5v pro mini Atmega368 and I'm getting 5.04V on output pin with commented sketch.
                    • YveauxY Yveaux
                      TheoLT
                      TheoLT
                      TheoL
                      @Yveaux @hozze Are you sure it's a ProMini 5V? Could you measure the voltage on the Raw pin.
                      I've received some Pro Mini 3.3V while I actually did order 5V.
                      It's just a guess.
                      hozzeH 1 Reply Last reply
                      • TheoLT TheoL
                        It's just a guess.
                        hozzeH
                        hozzeH
                        hozze
                        @TheoL I have two pro mini's. I measured the voltage across a output pin ( HIGH ) and GND and it gives me near 5V on one and near 3.3V on another .So it looks as if I do have 5V pro mini.
                        I have tried few other sketches on both, seems they are working fine, I face the specific issue only when including the Mysensor.h library. I will give it a try on a nano that I have and see what happens.
                        • hozzeH hozze
                          TheoLT
                          TheoLT
                          TheoL
                          @hozze It was just a guess. I once compiled a sketch for a 5V and uploaded it to a ProMini 3.3V. Took me a while before I noticed my mistake. I just didn;t understand why my Arduino couldn't control my relay boards ;-)
                          • TheoLT TheoL
                            hozzeH
                            hozzeH
                            hozze
                            @TheoL :smiley: me too learning things the hard way.
                            Thanks for all the pointers that you guys are giving . Looks as if I'm in the right place and with a great community,
                            Let me tinker a bit more and see if I can get somewhere, if anyone can give any further info kindly do.
                            Boots33B 1 Reply Last reply
                            • hozzeH hozze
                              Boots33B
                              Boots33B
                              Boots33
                              @hozze You should enable debugging at the top of your sketch with
                              and check the serial monitor to see if the radio is initialising . Maybe the loop part of the program will not run if this does not happen. That could be why commenting out the #include <MySensors.h> allows it to work.
                              You might also use wait instead of delay
                              • hozzeH
                                hozzeH
                                hozze
                                @Boots33 , I enabled MY_DEBUG. Sorry if I sound stupid. I have connected the pro mini to computer with USB serial CP2102 for programming/serial debug , at the same time can I power the pro mini + Radio with an external power supply 3.3V ?
                                I did something similar with a ATTINY85 few days back and bricked it :cry: ( Connected it to USB and same time powered it )
                                mfalkviddM Boots33B 2 Replies Last reply
                                • hozzeH hozze
                                  @hozze connect gnd from the serial adapter AND the external power supply to gnd on the Arduino. Connect + on the external adapter to the pin you normally use (vcc or raw). Do not connect + from the serial adapter. That's it.
                                  • hozzeH hozze
                                    Boots33B
                                    Boots33B
                                    Boots33
                                    @hozze The whole purpose of a good forum is for people to share ideas and knowledge. So never be worried about asking questions. :)
                                    • hozzeH
                                      hozzeH
                                      hozze
                                      Thanks guys, I will check this out.
                                      • hozzeH
                                        hozzeH
                                        hozze
                                        Was away from arduino for over a week with regular job. Tested the code with debug on a new arduino pro mini 3.3v 8Mhz and the below is the output ( please note that the values getting send are random values , i'm still not able to power the sensor with digital Pin )
                                        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
                                        TSP:MSG:SEND 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
                                        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
                                        TSP:MSG:READ 0-0-1 s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                        TSP:MSG:SEND 1-1-0-0 s=1,c=0,t=35,pt=0,l=0,sg=0,ft=0,st=ok:
                                        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=ok:SoilSensor
                                        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:0.1
                                        Request registration...
                                        TSP:MSG:SEND 1-1-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                        TSP:MSG:READ 0-0-1 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                        Node registration=1
                                        Init complete, id=1, parent=0, distance=1, registration=1
                                        TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:786
                                        TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:503
                                        TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:410
                                        TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:425
                                        TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:461
                                        TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:539
                                        TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:507
                                        TSP:MSG:SEND 1-1-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:392
                                        Looks fine for me , still I can't turn a digital pin On :disappointed:
                                        • hozzeH hozze
                                          Node registration=1
                                          Boots33B
                                          Boots33B
                                          Boots33
                                          @hozze It really should be working. I tried your original above and with a led connected to pin 5 it turns on when the code is run
                                          try the code below with some serial prints to see what happens
                                          #define MY_NODE_ID 150  // node id
                                          #define SENS_ON 5
                                          #define POWER_ON 1  //  value to write to turn on sensor
                                          #define POWER_OFF 0 //  value to write to turn off sensor
                                            digitalWrite(SENS_ON, POWER_ON);
                                            Serial.print("Sensor Power on pin "); Serial.print(SENS_ON); Serial.print(" is..."); Serial.println((POWER_ON));
                                            wait(1000); // To check the input voltage of pin 2
                                            digitalWrite(SENS_ON, POWER_OFF); // turn it off
                                            Serial.print("Sensor Power on pin "); Serial.print(SENS_ON); Serial.print(" is..."); Serial.println((POWER_OFF));
                                            wait(1000);
                                          I get an output like this below and the led flashes on and off at 1 second intervals. Maybe try just a led with a 200 to 300 ohm resistor on pin 5 to see what is happening. could the moisture sensor be drawing more than the arduino can give?
                                          TSP:MSG:SEND 150-150-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=ok:0
                                          TSP:MSG:READ 0-0-150 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                          TSP:MSG:SEND 150-150-0-0 s=1,c=0,t=35,pt=0,l=0,sg=0,ft=0,st=ok:
                                          TSP:MSG:SEND 150-150-0-0 s=255,c=3,t=11,pt=0,l=10,sg=0,ft=0,st=ok:SoilSensor
                                          TSP:MSG:SEND 150-150-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:0.1
                                          TSP:MSG:SEND 150-150-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
                                          TSP:MSG:READ 0-0-150 s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                          Node registration=1
                                          Init complete, id=150, parent=0, distance=1, registration=1
                                          Sensor Power on pin 5 is...1
                                          TSP:MSG:SEND 150-150-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:511
                                          Sensor Power on pin 5 is...0
                                          TSP:MSG:SEND 150-150-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:313
                                          TSP:MSG:SEND 150-150-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:254
                                          TSP:MSG:SEND 150-150-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:326
                                          TSP:MSG:SEND 150-150-0-0 s=1,c=1,t=37,pt=2,l=2,sg=0,ft=0,st=ok:235
