  3. first tries with MySensors v2.0: problem staring up.
9 Posts 2 Posters 3.3k Views 4 Watching
  • vgaV Offline
    vgaV Offline
    vga
    i have worked with MySensors v1.5 till now, but i started to begin working with v2.0.
    I have made a test SerialGateway (nearly example sketch) with an arduino nano, and a test sensor node with an arduino Pro Mini 3,3V.
    When starting both arduinos, on the Sensor node i get the following output:
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 0-0-255 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
    TSM:ID
    TSM:ID
    TSM:ID
    !TSM:CHKID:FAIL (ID=255)
    !TSM:FAILURE
    TSM:PDT
    What das that mean? (especially the "!TSM:CHKID_FAIL" and "...:FAILURE"
    My Gateway is not connected to any controller, just want to check, if my Sensor node with the sensor hardware works (serial outputs) but the only thing i get is this.
    Do i have to fully implement the mySensor Network, also the controller connection, or is there a way to test my Sensor node at first, then the communication with the gateway only, and at least put it on my controller?
    Y 1 Reply Last reply
    • vgaV vga
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:ID
      TSM:ID
      TSM:ID
      !TSM:FAILURE
      TSM:PDT
      Y Offline
      Y Offline
      @vga Looks like your sensor is assigned ID 255, while this ID is reserved for broadcast message.
      Assign any ID (#define MY_NODE_ID 123), except for 0 or 255 and try again.
      • vgaV Offline
        vgaV Offline
        vga
        i haven´t set a MY_NODE_ID, the myconfig is set to auto, so i thought this will set automatically. Or is this only, when gateway is connected to controller?
        • vgaV vga
          Y Offline
          Y Offline
          @vga When using auto the controller should hand out the ID's.
          If you have no controller this process will fail, that's probably the reason of the "!TSM:CHKID:FAIL (ID=255)" message.
          The "!TSM:FAILURE" is just the result of the previous error.
          Either connect a controller, or assign a static ID.
          • vgaV Offline
            vgaV Offline
            vga
            yes, for testing without controller i set the NODE_ID manual, and now it works.
            Transmit works now. But when sensor was out of range, transmit fails some times, and sensor comes back into range, the transmit doesn't works again.
            SP:MSG:SEND 1-1-0-0 s=0,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=ok:0
            !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=fail:1
            !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=16,pt=2,l=2,sg=0,ft=1,st=fail:0
            !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=16,pt=2,l=2,sg=0,ft=2,st=fail:1
            !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=16,pt=2,l=2,sg=0,ft=3,st=fail:0
            !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=16,pt=2,l=2,sg=0,ft=4,st=fail:1
            !TSP:MSG:SEND 1-1-0-0 s=0,c=1,t=16,pt=2,l=2,sg=0,ft=5,st=fail:0
            !TSM:UPL FAIL, SNP
            TSM:FPAR
            TSP:MSG:SEND 1-1-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
            !TSP:SEND:TNR
            !TSP:SEND:TNR
            • vgaV vga
              !TSM:UPL FAIL, SNP
              TSM:FPAR
              !TSP:SEND:TNR
              !TSP:SEND:TNR
              Y Offline
              Y Offline
              @vga After a number of failed transfers the sensor will start to search for a parent again ("TSM:FPAR")
              To have a fixed Node ID and fixed parent (so node won't start searching for it) define:
              #define MY_NODE_ID                  (123)
              #define MY_PARENT_NODE_ID           (0)
              • vgaV Offline
                vgaV Offline
                vga
                Ah, Thanks!
                So, i have do i have to set the NODE_ID at Gateway to (i.e. 0), to have a fixed ID, to which i connect the sensor node, if i want it static, right?
                • vgaV vga
                  Ah, Thanks!
                  Y Offline
                  Y Offline
                  @vga Gateway's ID is 0 by default.
                  • vgaV Offline
                    vgaV Offline
                    vga
                    ok, thank you Yveaux for your help!
                    to understand the mechanism, when the sensor node starts to search for parent again, why doesn´t it find the parent node, which used before?
