  3. PiDome
  4. PiDome Domotica/Home Automation
Scheduled Pinned Locked Moved PiDome
controllerserialgatewayraspberrymqttpidome
199 Posts 17 Posters 144.4k Views 5 Watching
  • FrancoisF
    FrancoisF
    Francois
    wrote on last edited by Francois
    #29
    @John I did as you say with the MqTT drive now if I click on the driver and then on the "Pidome MySensor Mqtt" noting happen
    upload-235f809e-bcb0-4de6-9104-ee41273114bd
    applog:appLog.txt
    Also if I click in view nothing happens
    upload-40f6c457-0d63-4919-a618-7e37b7536bb7
    • JohnJ
      JohnJ
      John
      wrote on last edited by John
      #30
      Clear your browsers cache and try again. The devices appear at the plugin.
      P.S.
      I will in a later state modify the driver name, it is an emulator between the devices and the plugin so the plugin can create devices the same way a driver can. The reason why it is a plugin is that drivers are hardware based (GPIO, USB access). The plugin now behaves like it is hardware.
      • FrancoisF
        FrancoisF
        Francois
        @John Hi I am back again. I now can see the MQTT node sensor. When I want to add the node sensor the custom devices don't show up in the "Select device to use" Why will that be?
        Custom device adde
        upload-c9a0b7b8-0e8a-4b1b-8d98-0bd9584820e9
        Custom device not show.
        upload-245527f8-f376-400c-96d2-b46432d82a93
        • JohnJ
          JohnJ
          John
          #32
          Device skeletons are limited to their driver/plugin and can not be interchanged (yet). When you are using the MQTT plugin you should create a MySensors MQTT custom device/skeleton. The first listing above shows these devices as a device for the serial version.
          • FrancoisF
            FrancoisF
            Francois
            @john Mysensor MQTT is now working. Thank for all you help :-) :+1:
            • JohnJ
              JohnJ
              John
              :+1: Next step would be integrating the Ethernet gateway, but that could take a week or so (working on other demanding tasks currently).
              • FrancoisF
                FrancoisF
                Francois
                @John I see that you don't have any time days in your automation triggers. Do you plan to do this at a later stage?
                I see that you are going to do twitter integration are you look as other message integration tools like pushbullet?
                • JohnJ
                  JohnJ
                  John
                  #36
                  Currently the triggers do days in the form of "Every day", "Weekdays", "Weekend" and per day like "Mon", "Tue":
                  Alt text
                  The time currently can be fixed, sunrise or sunset with calculations:
                  Alt text
                  The above can then be resulted in a rule like below:
                  Alt text
                  The above would then say that: "turn true every day when it is 30 minutes before sunset".
                  About messaging integration:
                  The messaging framework is currently partly integrated and currently only takes care of SMS messages (outgoing). When the full messaging framework is implemented twitter will be added together with it's messaging API which could then be used to integrate web services. Currently i'm still very busy with a lot of core parts where developing devices, plugins stands next to it when specific API parts are done. So i can not say if or when pushbullet integration will be available and/or it is created by me.
                  • FrancoisF
                    FrancoisF
                    Francois
                    @John what will I do if my Alarm is trigger and I want to switch it off after 10 min?
                    • JohnJ
                      JohnJ
                      John
                      Because triggers are meant to be used as real triggers. If this happens quickly do that. If you would automate your alarm you would need to create a second trigger which would say, depending on the earlier example: when every day it is 20 minutes before sunset, execute alarm off.
                      Currently next to the triggers i'm busy with Automation flows you can build with blockly. But this is still under heavy development: https://twitter.com/Pi_Dome/status/510355701114605568/photo/1
                      • FrancoisF
                        FrancoisF
                        Francois
                        @john I have the automation trigger for if the humidity for the bathroom. I have two trigger on for switching the fan on if Hum is >20 and one to switch the fan off it is Hum <19 this work. What I try now do now is combine this into one trigger where I use the "or" function . Can the execution list only execute one function for multiple condition?
                        upload-c4e64a4f-3ec2-48c0-8888-75e85bb0c6b1
                        • JohnJ
                          JohnJ
                          John
                          @Fwessels
                          The above is one trigger.
                          Currently you have set it up like:
                          IF (the data description of room 01 > 20%H) OR (the data description of room 01 < 19%H) DO (set study lights to On)
                          Triggers are really also meant as triggers and are based on a combination of rules which should always revert to true with a list of actions of the total list of rules are true. To put it simple: "When this, then that". There is no "else" ;)
                          If you want to turn on and turn of based on a quick trigger action you should or create two triggers, or wait for the Automation rules to be implemented in the server which currently is in development.
                          • FrancoisF
                            FrancoisF
                            Francois
                            @john I have two triggers and that is working.
                            • FrancoisF
                              FrancoisF
                              Francois
                              @John Hi did not bug you for an while. I change my setup to work with the MQTTGateway but now I have the following issue.
                              1. My motion and door sensors is not changing status in the "Data description" field. This did work with the serial gateway.
                              2. On my relay button sensor the "Toggle description" is not changing it I press the button this did work on the serial gateway.
                              I run you latest snapshot (373)
                              PS the Android client is now working on my Tablet and Phone (4.4.2)
                              JohnJ 1 Reply Last reply
                              • FrancoisF Francois
                                JohnJ
                                JohnJ
                                John
                                @Francois
                                That's the current latest yeah, have you defined the the data and/or toggle buttons as boolean or as an integer?
                                The Android client was kinda annoying, when deployed on a device from the development it worked, but when installed by the apk file it stopped working... Thanks for confirming it now works!
                                • FrancoisF
                                  FrancoisF
                                  Francois
                                  @John I did the same as the serial configuration as data field and boolean
                                  • JohnJ
                                    JohnJ
                                    John
                                    @Francois
                                    So both the data field as the toggle buttons are defined as booleans?
                                    Since alpha 271 the server also displays the last received date and time positioned above the controls, are these modified? Not yet real time in the web interface, you have to click the device again in the list to see if it is updated.
                                    • FrancoisF
                                      FrancoisF
                                      Francois
                                      @John both the fields are defined as data fields and as boolean. But the data field is not changing. This configuration is working in the serial gateway. Should I change this to toggle button for the MQTTGateway?
                                      upload-0c9c8b71-3c36-4c09-a365-6c2c6b6863b8
                                      • JohnJ
                                        JohnJ
                                        John
                                        @Francois
                                        Not needed, i understood you also had a toggle button.
                                        Is it possible to mail you an updated MySensors library package? it currently is not possible to compile the whole server.
                                        • FrancoisF
                                          FrancoisF
                                          Francois
                                          @John Yes you can email the update library. Do you still have my email address?
