  3. Hacking a Neato Robotics BotVac Connected
71 Posts 29 Posters 93.8k Views 25 Watching
  • korttomaK
    korttomaK
    korttoma
    FYI, a friend of mine has created a PHP library for the Neato cloud service -> https://github.com/tomrosenback/botvac
    It is based on the work @kangguru has done.
    • Tomas
    d96mbeD 1 Reply Last reply
    • korttomaK korttoma
      d96mbeD
      d96mbeD
      d96mbe
      @korttoma Works like a charm. Used PHP CLI on Windows 10. You have to enable extensions; php_curl and php_openssl in php.ini.
      • Jonathan8301J
        Jonathan8301J
        Jonathan8301
        The PHP API Works great for me. I have two questions though.
        1. The [isCharging] value in the [details] array of the State JSON is always empty, even when it is clearly charging i.e. the [charge] value changes. Any Idea why?
        2. Whenever I call the pause cleaning, and then return to base, the robot will go back to its base, but it will not dock with it, is there any particular reason for this? and is there a way to have it return to the dock, and actually dock and charge with out just letting run through the entire cleaning cycle?
        RawLiquidR 1 Reply Last reply
        • Jonathan8301J Jonathan8301
          RawLiquidR
          RawLiquidR
          RawLiquid
          @Jonathan8301
          You know, I've had that happen once or twice before I even found this page, but when I just tried it out, my botvac did dock properly.
          I just wish there were some way to get at the lower level sensor readings through this, I'd love to be able to see the 'map' that it builds when it cleans....
          • UbiquitousU Ubiquitous
            As for replacing the cloud server, I don't think it's possible without rooting the robot. The first thing it does when it's connected to the internet is to start an HTTPS Comet session (long polling). The robot will kill the connection immediately if you try to MiTM it with a selfsigned certificate and there is no way to install new certificates on the robot. If anyone has opened the robot I'd be interested in pictures of the motherboard, especially of any pads labeled JTAG.
            RawLiquidR
            RawLiquidR
            RawLiquid
            @Ubiquitous
            I have plans to open up my D80 the day that the warrantee is up, not sure if that will or won't help you any...
            • Jonathan8301J
              Jonathan8301J
              Jonathan8301
              Hmm it almost sounds like the Botvac could go for a firmware update, unfortunately it looks like Neato's post launch product support is severely lacking
                RawLiquidR
                RawLiquidR
                RawLiquid
                @Jonathan8301
                Funny thing is, before the connected was launched, I remember being able to find an API document and programming info for interfacing with the lower models...NOW, I can't so much as even find any page that contains a link to anything resembling an update file or api documentation...
                • korttomaK
                  korttomaK
                  korttoma
                  @RawLiquid So you are looking for this -> https://www.neatorobotics.com/resources/programmersmanual_20140305.pdf
                  Or something else?
                  • Tomas
                    Or something else?
                    RawLiquidR
                    RawLiquidR
                    RawLiquid
                    @korttoma actually, I already had that very document, and that is the one I was referring to. I might suggest keeping mentions of the exact url fairly low, It's likely an oversight that it's available still and if so, likely to be removed if they notice it. maybe use bitly to reference it instead...
                    I don't know what exactly changed within the company to cause such a drastic shift, but it's obvious that something changed....
                    • jcolterJ
                      jcolterJ
                      jcolter
                      Did anyone ever get this working with the Vera?
                      • robertoR
                        robertoR
                        roberto
                        wrote on last edited by roberto
                        #54
                        Hello hackers!
                        Let me introduce myself, I am Roberto Ostinelli, Neato Robotics' Director of Cloud Services.
                        I'm impressed with the work that you've put into integrating with our robots! Great job!
                        Given the interest we've seen on this and other forums, we've listened and have just released the Neato Developer Network, which might hopefully be of interest for some of you here.
                        You can become a developer with just your Neato account from here:
                        https://developers.neatorobotics.com
                        You will find official documentation and SDKs for JavaScript, iOS and Android (for now, we plan on expanding to other languages too!).
                        Simply put, as a developer you can create your own OAuth apps that interacts with Neato robots.
                        A demo of what you can achieve with the JavaScript SDK can be seen here (just login with your Neato account when requested):
                        https://developers.neatorobotics.com/demo/sdk-js
                        Please note that all of this is in Beta, we're a small team but are doing our best!
                        Cheers,
                        r.
                        • korttomaK
                          korttomaK
                          korttoma
                          @roberto
                          Thanks for finally acknowledging the fact that some people want to integrate their robotic vacuum cleaner with the rest of their smart home functionality.
                          Is your Neato Developer Network investment only targeting the new Neato Connected series and future versions or is there a communication module in the pipeline for older models like my Neato botvac 85?
                          • Tomas
                          robertoR 1 Reply Last reply
                            @roberto
                            robertoR
                            robertoR
                            roberto
                            #56
                            @korttoma due to hardware and other considerations we are only targeting the connected series, that started with the BotVac Connected. There currently are also the D3/D5 available, and then the future products to come!
                              Welcome @roberto,
                              Thanks for making the Neato more hacker friendly. I'm sure it will boost your sales. The HA/DIY crowd and the early adopters buying robotic vacuum cleaners is coinciding.
                                Welcome @roberto,
                                robertoR
                                robertoR
                                roberto
                                #58
                                Thank you @hek!
                                Sales are very nice indeed, but I'm also very interested in seeing what can be built with the creativity of all of you hackers on top of the Neato platform!
                                • Michael van der HeijdenM
                                  This is good news. Thank you Neato.
                                  Is it possible to send commands with just an https url? These URL's I can implement in LUA scripts for my Domotica.
                                  • Michael van der HeijdenM Michael van der Heijden
                                    robertoR
                                    robertoR
                                    roberto
                                    #60
                                    @Michael-van-der-Heijden Yes, everything is just standard http requests. Just head to the API section of the docs to learn more. You can see implementation examples in the existing SDK, that may help you out too!
                                    UbiquitousU Seth DanielS 2 Replies Last reply
                                    • robertoR roberto
                                      UbiquitousU
                                      UbiquitousU
                                      Ubiquitous
                                      wrote on last edited by Ubiquitous
                                      #61
                                      @roberto Awesome to see you make the API public and official even though it seems that you're just making the endpoints "official" and pretty much identical to the API resulted from reverse engineering efforts. Any chance you (as in Neato) would consider allowing us to switch to our backend server, essentially replacing your cometa.io server (cometa.neatocloud.com)? And on a sidenote, to get access to the developers portal and API through your site, you have to accept to your new terms, yet you've made the libraries public on github. :)
                                      • StormwindS
                                        StormwindS
                                        Stormwind
                                        @roberto - Thanks for making the API public! @kangguru and others - thanks for reverse engineering it!
                                        @roberto - Any chance of making the local LAN, direct-to-robot API official and documenting it? Some people prefer the lower latency and non-cloud dependency of local LAN control.
                                        P.S. I started an OpenHAB thread about developing a OpenHAB binding for the Neato Connected series.
                                        • robertoR roberto
                                          Seth DanielS
                                          Seth DanielS
                                          Seth Daniel
                                          @roberto Thanks for the documentation! Are there any plans to integrate with IFTTT? That would make it much easier for people to use with other smarthome things such as SmartThings, Echo, and Google Home.
                                          doobarD 1 Reply Last reply
