  3. Hacking a Neato Robotics BotVac Connected
71 Posts 29 Posters 93.8k Views 25 Watching
  • B
    B
    Brutus
    Thats good news Kangguru. Nice job.
    So maybe a noob question but How can I use this in my domotica program Domoticz running on Windows.
    I can use LUA, Curl, Batch as far is a know.
    Thnx for helping.
    • kangguruK kangguru
      There's good news guys. I finally figured out how the HMAC signature is calculated and now i'm able to control the neato without the mobile application, which offers all kinds of new integration options.
      What can be found in com/neatorobotics/android/activities/robot/C0645j.java is just half of the truth and i was looking at this part for way to long, i'm not sure where this part is used. maybe this would be the part where one can communicate with the neato without making use of the cloudservice. who knows ;)
      The actual fun starts in com/neatorobotics/android/p040c/p042b/C0898b.java the code reveals that there are 3 ingredients making up the HMAC signature
      • the robot's serial number
      • the current date (as also found in the Date header)
      • the http body
      Together with the robot's secret key we're now able to properly sign the requests.
      I've packaged this in a small ruby library https://github.com/kangguru/botvac which is
      quite basic and just covers just a little more than i needed for my usecase
      but i'm happy to extend this over time.
      Especially the part to obtain the secret key for the robot just be done via
      trafic capturing, which is not the most convinent thing i can think of :)
      I hope this already helps some people to build new things around their robot. I've mixed the
      stuff with ifttt.com and now can plan the cleaning schedule via a google calendar, which
      makes it really convinent to skip single days in a given schedule, which ist kinda painful to
      solve with the mobile app.
      happy hacking
      UbiquitousU
      UbiquitousU
      Ubiquitous
      @kangguru
      I also figured it out some time ago. You get the robot secret key and serial number when you log in to beehive.neatocloud.com and request https://beehive.neatocloud.com/dashboard
      I've written a powershell module where I exposed the entire api (as implemented in the android and iphone app), complete with login. I've yet to upload it to github but I can send it to you if you're unsure about the beehive part.
      B 1 Reply Last reply
      • UbiquitousU
        UbiquitousU
        Ubiquitous
        As for replacing the cloud server, I don't think it's possible without rooting the robot. The first thing it does when it's connected to the internet is to start an HTTPS Comet session (long polling). The robot will kill the connection immediately if you try to MiTM it with a selfsigned certificate and there is no way to install new certificates on the robot. If anyone has opened the robot I'd be interested in pictures of the motherboard, especially of any pads labeled JTAG.
        RawLiquidR 1 Reply Last reply
        • UbiquitousU Ubiquitous
          @kangguru
          B
          B
          Brutus
          wrote on last edited by Brutus
          #41
          @Ubiquitous
          Also nice job! Hope to see a link soon to github so we can experiment with this to.
          Thanks for the work.
          • kangguruK
            kangguruK
            kangguru
            @Ubiquitous yea, i just was too lazy about the login stuff :) but i added the stuff over the weekend, to make it more "end"-user friendly.
              • the http body
              happy hacking
              d96mbeD
              d96mbeD
              d96mbe
              @kangguru I have not done any ruby before and I'm stuck trying to use the gem. I think I've managed to install Ruby, devkit and Git (and added git.exe to path which is needed to be able to 'bundle install'). I don't see any errors, but I am unable to find any binary named botvac to run. I've run "gem env" and none of the variables seems strange.
              Any suggestions? I'm on Windows 10 btw.
              BR / M
              • korttomaK
                korttomaK
                korttoma
                FYI, a friend of mine has created a PHP library for the Neato cloud service -> https://github.com/tomrosenback/botvac
                It is based on the work @kangguru has done.
                • Tomas
                d96mbeD 1 Reply Last reply
                • korttomaK korttoma
                  d96mbeD
                  d96mbeD
                  d96mbe
                  @korttoma Works like a charm. Used PHP CLI on Windows 10. You have to enable extensions; php_curl and php_openssl in php.ini.
                  • Jonathan8301J
                    Jonathan8301J
                    Jonathan8301
                    The PHP API Works great for me. I have two questions though.
                    1. The [isCharging] value in the [details] array of the State JSON is always empty, even when it is clearly charging i.e. the [charge] value changes. Any Idea why?
                    2. Whenever I call the pause cleaning, and then return to base, the robot will go back to its base, but it will not dock with it, is there any particular reason for this? and is there a way to have it return to the dock, and actually dock and charge with out just letting run through the entire cleaning cycle?
                    • Jonathan8301J Jonathan8301
                      RawLiquidR
                      RawLiquidR
                      RawLiquid
                      @Jonathan8301
                      You know, I've had that happen once or twice before I even found this page, but when I just tried it out, my botvac did dock properly.
                      I just wish there were some way to get at the lower level sensor readings through this, I'd love to be able to see the 'map' that it builds when it cleans....
                        RawLiquidR
                        RawLiquidR
                        RawLiquid
                        @Ubiquitous
                        I have plans to open up my D80 the day that the warrantee is up, not sure if that will or won't help you any...
                        • Jonathan8301J
                          Jonathan8301J
                          Jonathan8301
                          Hmm it almost sounds like the Botvac could go for a firmware update, unfortunately it looks like Neato's post launch product support is severely lacking
                            RawLiquidR
                            RawLiquidR
                            RawLiquid
                            @Jonathan8301
                            Funny thing is, before the connected was launched, I remember being able to find an API document and programming info for interfacing with the lower models...NOW, I can't so much as even find any page that contains a link to anything resembling an update file or api documentation...
                            • korttomaK
                              korttomaK
                              korttoma
                              @RawLiquid So you are looking for this -> https://www.neatorobotics.com/resources/programmersmanual_20140305.pdf
                              Or something else?
                              • Tomas
                                Or something else?
                                RawLiquidR
                                RawLiquidR
                                RawLiquid
                                @korttoma actually, I already had that very document, and that is the one I was referring to. I might suggest keeping mentions of the exact url fairly low, It's likely an oversight that it's available still and if so, likely to be removed if they notice it. maybe use bitly to reference it instead...
                                I don't know what exactly changed within the company to cause such a drastic shift, but it's obvious that something changed....
                                • jcolterJ
                                  jcolterJ
                                  jcolter
                                  Did anyone ever get this working with the Vera?
                                  • robertoR
                                    robertoR
                                    roberto
                                    wrote on last edited by roberto
                                    #54
                                    Hello hackers!
                                    Let me introduce myself, I am Roberto Ostinelli, Neato Robotics' Director of Cloud Services.
                                    I'm impressed with the work that you've put into integrating with our robots! Great job!
                                    Given the interest we've seen on this and other forums, we've listened and have just released the Neato Developer Network, which might hopefully be of interest for some of you here.
                                    You can become a developer with just your Neato account from here:
                                    https://developers.neatorobotics.com
                                    You will find official documentation and SDKs for JavaScript, iOS and Android (for now, we plan on expanding to other languages too!).
                                    Simply put, as a developer you can create your own OAuth apps that interacts with Neato robots.
                                    A demo of what you can achieve with the JavaScript SDK can be seen here (just login with your Neato account when requested):
                                    https://developers.neatorobotics.com/demo/sdk-js
                                    Please note that all of this is in Beta, we're a small team but are doing our best!
                                    Cheers,
                                    r.
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      @roberto
                                      Thanks for finally acknowledging the fact that some people want to integrate their robotic vacuum cleaner with the rest of their smart home functionality.
                                      Is your Neato Developer Network investment only targeting the new Neato Connected series and future versions or is there a communication module in the pipeline for older models like my Neato botvac 85?
                                      • Tomas
                                      robertoR 1 Reply Last reply
                                        @roberto
                                        robertoR
                                        robertoR
                                        roberto
                                        #56
                                        @korttoma due to hardware and other considerations we are only targeting the connected series, that started with the BotVac Connected. There currently are also the D3/D5 available, and then the future products to come!
                                          Welcome @roberto,
                                          Thanks for making the Neato more hacker friendly. I'm sure it will boost your sales. The HA/DIY crowd and the early adopters buying robotic vacuum cleaners is coinciding.
