  3. [Solved] Node not resetting itself
8 Posts 2 Posters 1.9k Views
  • ? Offline
    ? Offline
    A Former User
    wrote on last edited by tekka
    I am using the RF69W radio and the latest development branch of MySensors. My problem is that the node doesn't reset itself if the connection between node and gateway failed for some reason.
    Here is the debug
    2490
    TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:2490
    TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:4041
    TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:5728
    !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=NACK:2615
    !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=1,st=NACK:5408
    !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=2,st=NACK:186
    !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=3,st=NACK:1681
    !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=4,st=NACK:1805
    !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=5,st=NACK:2490
    !TSM:READY:UPL FAIL,SNP
    TSM:FPAR
    TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=6,st=bc:
    754
    !TSF:SEND:TNR
    !TSF:SEND:TNR
    !TSF:SEND:TNR
    !TSF:SEND:TNR
    !TSF:SEND:TNR
    !TSF:SEND:TNR
    !TSF:SEND:TNR
    • ? A Former User
      Here is the debug
      2490
      TSM:FPAR
      754
      !TSF:SEND:TNR
      !TSF:SEND:TNR
      !TSF:SEND:TNR
      !TSF:SEND:TNR
      !TSF:SEND:TNR
      !TSF:SEND:TNR
      !TSF:SEND:TNR
      T Offline
      T Offline
      tekka
      @kenci Please post your sketch and the full debug log over an extended time period after the connection is lost.
      • ? Offline
        ? Offline
        A Former User
        wrote on last edited by A Former User
        @tekka
        MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.0.1-beta
        TSM:INIT
        TSM:INIT:TSP OK
        TSM:INIT:STATID,ID=254
        TSF:ASID:OK,ID=254
        TSM:FPAR
        TSF:MSG:SEND,254-254-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
        TSF:MSG:READ,0-0-254,s=255,c=3,t=8,pt=1,l=1,sg=0:0
        TSF:MSG:FPAR RES,ID=0,D=0
        TSF:MSG:FPAR OK,ID=0,D=1
        TSM:FPAR:OK
        TSM:ID
        TSM:ID:OK,ID=254
        TSM:UPL
        TSF:PING:SEND,TO=0
        TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
        TSF:MSG:READ,0-0-254,s=255,c=3,t=25,pt=1,l=1,sg=0:1
        TSF:MSG:PONG RECV,HP=1
        TSF:CHKUPL:OK
        TSM:UPL:OK
        TSM:READY
        TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
        !TSF:MSG:SEND,254-254-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=NACK:2.0.1-beta
        TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=1,st=OK:0
        TSF:MSG:READ,0-0-254,s=255,c=3,t=6,pt=0,l=1,sg=0:0
        TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=11,pt=0,l=12,sg=0,ft=0,st=OK:Light Sensor
        TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
        !TSF:MSG:SEND,254-254-0-0,s=0,c=0,t=16,pt=0,l=0,sg=0,ft=0,st=NACK:
        MCO:REG:REQ
        !TSF:MSG:SEND,254-254-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=1,st=NACK:2
        TSF:MSG:READ,0-0-254,s=255,c=3,t=0,pt=0,l=1,sg=0:0
        TSF:MSG:READ,0-0-254,s=255,c=3,t=27,pt=1,l=1,sg=0:1
        MCO:PIM:NODE REG=1
        MCO:BGN:INIT OK,ID=254,PAR=0,DIS=1,REG=1
        446
        TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=2,st=OK:446
        TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:3046
        TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:4524
        TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:3617
        TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:1859
        TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:4476
        TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:2735
        !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=NACK:4856
        !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=1,st=NACK:1434
        !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=2,st=NACK:561
        TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=3,st=OK:2498
        TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=OK:4060
        !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=0,st=NACK:5746
        !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=1,st=NACK:2627
        !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=2,st=NACK:5442
        !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=3,st=NACK:187
        !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=4,st=NACK:1694
        !TSF:MSG:SEND,254-254-0-0,s=0,c=1,t=23,pt=2,l=2,sg=0,ft=5,st=NACK:1819
        TSM:FPAR
        2537
        !TSF:SEND:TNR
        !TSF:SEND:TNR
        !TSF:SEND:TNR
        !TSF:SEND:TNR
        !TSF:SEND:TNR
        !TSF:SEND:TNR
        !TSF:SEND:TNR
        !TSF:SEND:TNR
        !TSF:SEND:TNR
        !TSF:SEND:TNR repeating itself for hours
        Sketch:
         * Version 1.0 - Henrik EKblad
         * Example sketch showing how to measue light level using a LM393 photo-resistor
         * http://www.mysensors.org/build/light
        #define MY_NODE_ID 254
        #define MY_BAUD_RATE 57600
        #define MY_RADIO_RFM69
        #define MY_RFM69_FREQUENCY RF69_868MHZ
        #define MY_RFM69_NETWORKID 100 // 0-127
        #define CHILD_ID_LIGHT 0
        unsigned long SLEEP_TIME = 5000; // Sleep time between reads (in milliseconds)
        int lastLightLevel;
        void presentation()  {
          sendSketchInfo("Light Sensor", "1.0");
          int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23*random(0,100);
          Serial.println(lightLevel);
          bool test =     send(msg.set(lightLevel));
          Serial.println(test);
          sleep(SLEEP_TIME);
        RFM69 connected to Arduino Pro mini 3v3 8Mhz as described on Mysensors Homepage
        • ? A Former User
          @tekka
          TSM:INIT
          TSM:INIT:TSP OK
          TSF:ASID:OK,ID=254
          TSM:FPAR
          TSM:FPAR:OK
          TSM:ID
          TSM:ID:OK,ID=254
          TSM:UPL
          TSF:PING:SEND,TO=0
          TSF:CHKUPL:OK
          TSM:UPL:OK
          TSM:READY
          MCO:REG:REQ
          MCO:PIM:NODE REG=1
          446
          TSM:FPAR
          2537
          !TSF:SEND:TNR
          !TSF:SEND:TNR
          !TSF:SEND:TNR
          !TSF:SEND:TNR
          !TSF:SEND:TNR
          !TSF:SEND:TNR
          !TSF:SEND:TNR
          !TSF:SEND:TNR
          !TSF:SEND:TNR
          Sketch:
          int lastLightLevel;
            sleep(SLEEP_TIME);
          T Offline
          T Offline
          tekka
          @kenci If you substitute sleep() to wait() it will re-initialize.
          Please find here an alternative approach:
          https://forum.mysensors.org/topic/4394/node-not-reconnecting/7
          ? 1 Reply Last reply
          • T tekka
            ? Offline
            ? Offline
            A Former User
            @tekka Is that a problem if i am using battery powered sensors?
            • ? A Former User
              T Offline
              T Offline
              tekka
              @kenci see the alternative solution mentioned above.
              • ? Offline
                ? Offline
                A Former User
                @tekka i just read that you have implemented that in the library and need to push a PR? Is this feature in the latest dev branch?
                • ? A Former User
                  T Offline
                  T Offline
                  tekka
                  @kenci Not yet :smile:
                  12.1k
