  3. 1mhz hardware
1mhz hardware
27 Posts 8 Posters 9.7k Views 5 Watching
  • T Offline
    T Offline
    TimO
    Did you change the board definition within the Arduino IDE so that the code is compiled for 1 MHz? If not, the timing wont match. :)
    According battery:
    100 % = Vmax = 3.44 Volts
    0 % = 0 V
    CrankyCoderC 1 Reply Last reply
    • N Offline
      N Offline
      Hello, no idea with the wake up time, I didn't check it at 1MHz, but it should not vary as it's based on the watchdog timer which is always at 128KHz, and not related to the main clock frequency and multiplier.
      For the battery level do you use a divider ? That's useful if you have a booster, but for a CR2032 directly connected to Vcc the most simple way is to measure the supply voltage. Please note that my measurement is not exact as value should be adjusted to the exact voltage of the "1.1V" reference voltage of the atmega.
      #include <SystemStatus.h>
      // Parameters for VCC measurement
      const int VccMin        = 2000;  // Minimum expected Vcc level, in Volts. At 2V the cell should be dead
      const int VccMax        = 2900;  // Maximum expected Vcc level, in Volts.
      SystemStatus vcc();
      int LastBatteryPercent = 200; // so we are sure to send the battery level at first check
          int currentBatteryPercent = SystemStatus().getVCCPercent(VccMin, VccMax);
          if (currentBatteryPercent != LastBatteryPercent) {
              LastBatteryPercent = currentBatteryPercent;
              sendBatteryLevel(currentBatteryPercent);
      • T TimO
        According battery:
        0 % = 0 V
        CrankyCoderC Offline
        CrankyCoder
        @TimO Here is my definition in my boards.txt
        ## Arduino Pro or Pro Mini (1.8V, 1 MHz) w/ ATmega328
        pro.menu.cpu.1MHzatmega328=ATmega328 (1.8V, 1 MHz)
        pro.menu.cpu.1MHzatmega328.upload.maximum_size=30720
        pro.menu.cpu.1MHzatmega328.upload.maximum_data_size=2048
        pro.menu.cpu.1MHzatmega328.upload.speed=9600
        pro.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
        pro.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xD4
        pro.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
        pro.menu.cpu.1MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_1MHz.hex
        pro.menu.cpu.1MHzatmega328.build.mcu=atmega328p
        pro.menu.cpu.1MHzatmega328.build.f_cpu=1000000L
        Home Automation Tinkerer
        www.CrankyCoder.net
        Gateway: MQTTClientGateway
        MySensors: 2.3
        • N Nca78
          SystemStatus vcc();
          CrankyCoder
          @Nca78 yes currently using a voltage divider. if i go to measuring the supply voltage alone that will get rid of the extra components I may not be needing atleast for this node.
          I will try your example. Thanks!
          www.CrankyCoder.net
          MySensors: 2.3
          • Y Yveaux
            @Jason-Brunk said:
            It does wake up, but not quite on the hour
            Can you be more explicit? How much time is there inbetween wakeups? The watchdog will always be a bit off, but it should only be a few %
            CrankyCoder
            @Yveaux Ok. so it checked in at 3:17am this morning. it did not check in again until 1:58 this afternoon. :)
            www.CrankyCoder.net
            MySensors: 2.3
            • CrankyCoderC CrankyCoder
              @Jason-Brunk that's almost 10 hours. My guess is that the timer is 8x off (if the code expects 8Mhz but is running at 1Mhz). Try recompiling with 1MHz board settings or divide the time by 8 in the sketch)
                CrankyCoder
                @mfalkvidd Ill reflash it. Just wondering if there is something in the code I should change to tell it it's running at 1mhz or if that's something that is supposed to just work based on the clock timing
                www.CrankyCoder.net
                MySensors: 2.3
                mfalkviddM M 2 Replies Last reply
                  @Jason-Brunk I think the Arduino IDE is supposed to handle all that if the correct board is selected. I know that timings are off if I select 16MHz pro mini in the IDE and then flash to a 8MHz Arduino. It is also easily noticeable on the serial monitor, which will require a setting of twice the baud rate set in Serial.begin. I have never built a 1MHz node though.
                  • S Offline
                    @Jason-Brunk why not falsh your node for internal 8mhz for instance, and then use 1Mhz in sketch ? On my side, I prefer this way..and it works for me at least.
                    when the node is not sleeping, and radio is not sleeping in RX mode for instance, there is no big saving to do this, only atmel consumption is low, radio is not..but if your radio is sleeping, yep it's interesting but I don't really see advantage to start node at 1Mhz as the radio does not sleep at startup and does the protocol stuff.
                      M Offline
                      M Offline
                      m26872
                      Clock settings are determined by the"fuses". What's your tool for fuses and bootloader programming? Are you sure you programmed the fuses as in your "boards.txt" above?
                      N 1 Reply Last reply
                      • M m26872
                        N Offline
                        N Offline
                        My understanding was that the "burn bootloader" function of the Arduino IDE will also write the fuses, no ?
                        From Arduino website :
                        "How does it work?
                        The "Burn Bootloader" commands in the Arduino environment use an open-source tool, avrdude. There are four steps: unlocking the bootloader section of the chip, setting the the fuses on the chip, uploading the bootloader code to the chip, and locking the bootloader section of the chip"
                        • N Nca78
                          "How does it work?
                          M Offline
                          M Offline
                          m26872
                          @Nca78 True. And I suppose you've also double checked the verbose output from that process.
                          Can't help you further. I would try soft 1MHz instead then, as @scalz suggested.
                          • CrankyCoderC Offline
                            CrankyCoder
                            Ok. So I got back in town and reflashed my bootloader. Claims it's running 1mhz now. No regulator, no leds. Even in sleep mode I am sitting at about 1.66ma. Which in deep sleep mode that seems really high. Considering the capacity of a coin cell i am looking at changing out about once every 2 weeks with no use.
                            Any thoughts? Recommendations? Just can't seem to get this running low power enough. Not sure if my hardware is junk or what. But i would take any recommendations or tests to see how to get this working since i have a small stack of these pro minis
                            www.CrankyCoder.net
                            MySensors: 2.3
                            • N Offline
                              N Offline
                              There's obviously a problem, I'm at about 1/1000 of that in sleep mode, you're sure your multimeter is not mistaking the unit ? ;)
                              I have cheap pro minis too, the < 2$ kind.
                              1mA+ in sleep mode sounds like a voltage regulator still connected, or the IC not sleeping, at least not in power down mode like when using the MySensors function. Are you sure you didn't leave a #define by mistake (like activating the repeater function with #define MY_REPEATER_FEATURE) that would prevent the atmega from sleeping ?
                                CrankyCoder
                                I checked, no REPEATER on.
                                Here is the code for my loop()
                                int whichbutton = 0;
                                whichbutton = sleep(digitalPinToInterrupt(2),LOW,digitalPinToInterrupt(3),LOW,86400000);
                                switch (whichbutton) {
                                  case digitalPinToInterrupt(2):
                                      {//off
                                      send(msg_light.set(0),true);
                                      wait(300);
                                  case digitalPinToInterrupt(3):
                                      {//on
                                      send(msg_light.set(1),true);
                                      wait(300);
                                sleep(250);
                                CheckBattery();
                                It's not running that over and over for sure. Otherwise I would see the battery value publishing regularly to the broker.
                                I broke the regulator off and the LEDs.
                                This is the one I have.
                                https://www.sparkfun.com/products/11114
                                I don't think the multimeter is misreading it. I can see the battery percentage dropping over the course of a day so it definitely seems like it's pulling more mA than it should sleeping.
                                www.CrankyCoder.net
                                MySensors: 2.3
                                • M m26872
                                  N Offline
                                  N Offline
                                  In case someone doesn't believe the Arduino docs ;)
                                  This is at the beginning of the bootloader writing process in Arduino IDE:
                                  avrdude: verifying ...
                                  avrdude: reading input file "0xde"
                                  avrdude: verifying hfuse memory against 0xde:
                                  avrdude: load data hfuse data from input file 0xde:
                                  avrdude: input file 0xde contains 1 bytes
                                  avrdude: reading input file "0x62"
                                  avrdude: verifying lfuse memory against 0x62:
                                  avrdude: load data lfuse data from input file 0x62:
                                  avrdude: input file 0x62 contains 1 bytes
                                  • N Nca78
                                    M Offline
                                    M Offline
                                    m26872
                                    @Nca78
                                    The docs won't tell you if the process fails. The verbose output will. :wink:
                                      CrankyCoder
                                      hmmm. ok so I have verified I am writing the 1mhz boot loader.
                                      My multimeter says when it's sleeping i am still running at 1.5mah
                                      I have my openhab system tracking the battery usage. IN 6 days I have lost 30% of the battery and it's been in sleep mode.
                                      || *Time* || *Value* ||
                                      || 2016-08-14 19:29:27 || 100 ||
                                      || 2016-08-15 19:07:57 || 80 ||
                                      || 2016-08-15 19:11:18 || 81 ||
                                      || 2016-08-15 19:12:48 || 83 ||
                                      || 2016-08-15 19:13:14 || 76 ||
                                      || 2016-08-15 19:13:17 || 84 ||
                                      || 2016-08-15 19:13:56 || 80 ||
                                      || 2016-08-15 19:16:48 || 78 ||
                                      || 2016-08-19 15:07:57 || 76 ||
                                      || 2016-08-19 15:10:09 || 80 ||
                                      || 2016-08-19 15:12:43 || 79 ||
                                      || 2016-08-19 15:13:49 || 82 ||
                                      || 2016-08-19 15:14:20 || 84 ||
                                      || 2016-08-20 11:44:01 || 69 ||
                                      || 2016-08-20 11:44:23 || 48 ||
                                      || 2016-08-20 11:44:31 || 71 ||
                                      Any thoughts? Any recommendations on maybe a replacement pro mini that will for sure run at <1mah?
                                      www.CrankyCoder.net
                                      MySensors: 2.3
                                      • cimba007C Offline
                                        cimba007C Offline
                                        cimba007
                                        wrote on last edited by cimba007
                                        #21
                                        remove the power led (1-2mA), remove the voltage regulator if possible (1mA)
                                        • cimba007C cimba007
                                          CrankyCoder
                                          @cimba007 Led was already removed. :(
                                          www.CrankyCoder.net
                                          MySensors: 2.3
