  3. 1mhz hardware
1mhz hardware
27 Posts 8 Posters 9.7k Views 5 Watching
  • Y Yveaux
    @Jason-Brunk said:
    It does wake up, but not quite on the hour
    Can you be more explicit? How much time is there inbetween wakeups? The watchdog will always be a bit off, but it should only be a few %
    CrankyCoderC Offline
    CrankyCoder
    @Yveaux Ok. so it checked in at 3:17am this morning. it did not check in again until 1:58 this afternoon. :)
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • CrankyCoderC CrankyCoder
      @Jason-Brunk that's almost 10 hours. My guess is that the timer is 8x off (if the code expects 8Mhz but is running at 1Mhz). Try recompiling with 1MHz board settings or divide the time by 8 in the sketch)
      CrankyCoderC 1 Reply Last reply
        CrankyCoder
        @mfalkvidd Ill reflash it. Just wondering if there is something in the code I should change to tell it it's running at 1mhz or if that's something that is supposed to just work based on the clock timing
        www.CrankyCoder.net
        MySensors: 2.3
        mfalkviddM M 2 Replies Last reply
          @Jason-Brunk I think the Arduino IDE is supposed to handle all that if the correct board is selected. I know that timings are off if I select 16MHz pro mini in the IDE and then flash to a 8MHz Arduino. It is also easily noticeable on the serial monitor, which will require a setting of twice the baud rate set in Serial.begin. I have never built a 1MHz node though.
          • S Offline
            @Jason-Brunk why not falsh your node for internal 8mhz for instance, and then use 1Mhz in sketch ? On my side, I prefer this way..and it works for me at least.
            when the node is not sleeping, and radio is not sleeping in RX mode for instance, there is no big saving to do this, only atmel consumption is low, radio is not..but if your radio is sleeping, yep it's interesting but I don't really see advantage to start node at 1Mhz as the radio does not sleep at startup and does the protocol stuff.
              M Offline
              M Offline
              m26872
              Clock settings are determined by the"fuses". What's your tool for fuses and bootloader programming? Are you sure you programmed the fuses as in your "boards.txt" above?
              N 1 Reply Last reply
              • M m26872
                N Offline
                N Offline
                My understanding was that the "burn bootloader" function of the Arduino IDE will also write the fuses, no ?
                From Arduino website :
                "How does it work?
                The "Burn Bootloader" commands in the Arduino environment use an open-source tool, avrdude. There are four steps: unlocking the bootloader section of the chip, setting the the fuses on the chip, uploading the bootloader code to the chip, and locking the bootloader section of the chip"
                • N Nca78
                  "How does it work?
                  M Offline
                  M Offline
                  m26872
                  @Nca78 True. And I suppose you've also double checked the verbose output from that process.
                  Can't help you further. I would try soft 1MHz instead then, as @scalz suggested.
                  • CrankyCoderC Offline
                    CrankyCoder
                    Ok. So I got back in town and reflashed my bootloader. Claims it's running 1mhz now. No regulator, no leds. Even in sleep mode I am sitting at about 1.66ma. Which in deep sleep mode that seems really high. Considering the capacity of a coin cell i am looking at changing out about once every 2 weeks with no use.
                    Any thoughts? Recommendations? Just can't seem to get this running low power enough. Not sure if my hardware is junk or what. But i would take any recommendations or tests to see how to get this working since i have a small stack of these pro minis
                    www.CrankyCoder.net
                    MySensors: 2.3
                    • N Offline
                      N Offline
                      There's obviously a problem, I'm at about 1/1000 of that in sleep mode, you're sure your multimeter is not mistaking the unit ? ;)
                      I have cheap pro minis too, the < 2$ kind.
                      1mA+ in sleep mode sounds like a voltage regulator still connected, or the IC not sleeping, at least not in power down mode like when using the MySensors function. Are you sure you didn't leave a #define by mistake (like activating the repeater function with #define MY_REPEATER_FEATURE) that would prevent the atmega from sleeping ?
                        CrankyCoder
                        I checked, no REPEATER on.
                        Here is the code for my loop()
                        int whichbutton = 0;
                        whichbutton = sleep(digitalPinToInterrupt(2),LOW,digitalPinToInterrupt(3),LOW,86400000);
                        switch (whichbutton) {
                          case digitalPinToInterrupt(2):
                              {//off
                              send(msg_light.set(0),true);
                              wait(300);
                          case digitalPinToInterrupt(3):
                              {//on
                              send(msg_light.set(1),true);
                              wait(300);
                        sleep(250);
                        CheckBattery();
                        It's not running that over and over for sure. Otherwise I would see the battery value publishing regularly to the broker.
                        I broke the regulator off and the LEDs.
                        This is the one I have.
                        https://www.sparkfun.com/products/11114
                        I don't think the multimeter is misreading it. I can see the battery percentage dropping over the course of a day so it definitely seems like it's pulling more mA than it should sleeping.
                        www.CrankyCoder.net
                        MySensors: 2.3
                        • M m26872
                          N Offline
                          N Offline
                          In case someone doesn't believe the Arduino docs ;)
                          This is at the beginning of the bootloader writing process in Arduino IDE:
                          avrdude: verifying ...
                          avrdude: reading input file "0xde"
                          avrdude: verifying hfuse memory against 0xde:
                          avrdude: load data hfuse data from input file 0xde:
                          avrdude: input file 0xde contains 1 bytes
                          avrdude: reading input file "0x62"
                          avrdude: verifying lfuse memory against 0x62:
                          avrdude: load data lfuse data from input file 0x62:
                          avrdude: input file 0x62 contains 1 bytes
                          • N Nca78
                            M Offline
                            M Offline
                            m26872
                            @Nca78
                            The docs won't tell you if the process fails. The verbose output will. :wink:
                              CrankyCoder
                              hmmm. ok so I have verified I am writing the 1mhz boot loader.
                              My multimeter says when it's sleeping i am still running at 1.5mah
                              I have my openhab system tracking the battery usage. IN 6 days I have lost 30% of the battery and it's been in sleep mode.
                              || *Time* || *Value* ||
                              || 2016-08-14 19:29:27 || 100 ||
                              || 2016-08-15 19:07:57 || 80 ||
                              || 2016-08-15 19:11:18 || 81 ||
                              || 2016-08-15 19:12:48 || 83 ||
                              || 2016-08-15 19:13:14 || 76 ||
                              || 2016-08-15 19:13:17 || 84 ||
                              || 2016-08-15 19:13:56 || 80 ||
                              || 2016-08-15 19:16:48 || 78 ||
                              || 2016-08-19 15:07:57 || 76 ||
                              || 2016-08-19 15:10:09 || 80 ||
                              || 2016-08-19 15:12:43 || 79 ||
                              || 2016-08-19 15:13:49 || 82 ||
                              || 2016-08-19 15:14:20 || 84 ||
                              || 2016-08-20 11:44:01 || 69 ||
                              || 2016-08-20 11:44:23 || 48 ||
                              || 2016-08-20 11:44:31 || 71 ||
                              Any thoughts? Any recommendations on maybe a replacement pro mini that will for sure run at <1mah?
                              www.CrankyCoder.net
                              MySensors: 2.3
                              • cimba007C Offline
                                cimba007C Offline
                                cimba007
                                wrote on last edited by cimba007
                                #21
                                remove the power led (1-2mA), remove the voltage regulator if possible (1mA)
                                • cimba007C cimba007
                                  CrankyCoder
                                  @cimba007 Led was already removed. :(
                                  www.CrankyCoder.net
                                  MySensors: 2.3
                                  • cimba007C Offline
                                    cimba007C Offline
                                    cimba007
                                    I would only imagine that the VoltageRegulator might be the culprit.
                                    As you said you use a "3v battery" so there is no need for the VoltageRegulator at all. Where do you apply the power? RAW or VCC? To power your Arduino with higher voltages you connect them to RAW which leads to the regulator.
                                    On most of my projects I use 2x AA Battery which are connected directly to VCC .. even with the VoltageRegulator intact I am at 66% for the last 7 days .. not loosing a single %.
                                    PS: Sry .. I missed that you have already removed the voltage regulator + the led.
                                    The library states to use RISING, FALLING, CHANGE as the interrupt mode but you use LOW .. I don't know to which of the 3 this mapps.
                                    But my guess is you are using FALLING .. thus waking your node up if you connect pin 2 or 3 to ground .. which means you have some kind of pull up don't you?
                                    Do you have anything connected to the Arduino ProMini? If so maybe try an empty sketch and remove all connected peripherals. Maybe even you can find some inspiration on this link: http://electronics.stackexchange.com/questions/49182/how-can-i-get-my-atmega328-to-run-for-a-year-on-batteries
                                    Another really good test on the powerdown current is here:
                                    http://www.rocketscream.com/blog/2011/07/04/lightweight-low-power-arduino-library/
                                    with this library (not compatible with mysensor so dont't use at the same time)
                                    https://github.com/rocketscream/Low-Power
                                      CrankyCoder
                                      @cimba007 thanks! will definitely test out some of this stuff. I am connecting power to vcc and the regulator has been removed.
                                      2 buttons connected to the interrupt pins, 1 for on 1 for off.
                                      here is my sleep statement
                                      Could my resistors connected to the buttons be causing the extra power?
                                      I would expect that to be the cause because even a door sensor or something would have to trigger the interrupt.
                                      A buddy of mine suggested I throw an additional multimeter in line so i am actually measuring with 2 and see if maybe my readings are just off or my multimeter is wonky reading it. He thinks maybe the fact i am measuring it is causing the extra current... (sounds like quantum entanglement stuff there, "It changed cause you measured it!!")
                                      www.CrankyCoder.net
                                      MySensors: 2.3
                                      • cimba007C Offline
                                        cimba007C Offline
                                        cimba007
                                        Putting a multimeter in series will most likeley only cause a voltage drop of up to 200mV (just a rough number). If your circuit draws very little current even routing this current trough the resistor (which is causing the voltage drop) would not result in additional consumption.
                                        Lets look at your switches .. if you are using a setup like this:
                                        http://www.starting-point-systems.com/images/pullup_example.gif
                                        http://www.microchip.com/forums/m341654.aspx states that there should be zero current consumption while the button is not pressed. Are u using this button setup? If not can u provide a drawing?
                                        I don't think that the multimeter is to blame. You reported a very weak batterylife even when you are not measuring the current I guess.
                                        https://en.wikipedia.org/wiki/Multimeter#Burden_voltage
                                        http://alternatezone.com/electronics/ucurrent/uCurrentArticle.pdf
                                        Long story short .. I would not suspect the burden Voltage to be the problem .. I can measure in the 200µA range with my cheapish Multimeter when the Atmega328p is in deep sleep mode .. so something must be drawing current in your setup.
                                        • cimba007C Offline
                                          cimba007C Offline
                                          cimba007
                                          #26
                                          To get the fastest results I would try to disconnect everything from your circuit .. hook up the Multimeter to measure current in lets say 200mA range (if available) and try the deep sleep example from https://github.com/rocketscream/Low-Power
                                          If the pro mini is in deep sleep mode you can switch from 200mA to 2mA or even 200µA range if available. (just don't let the pro mini wake up while you have the range set very low)
                                          Lower measure range = higher burden voltage = potential less power for your µC .. maybe even to the point it will go into brown out or start to behave strange
