  3. 1mhz hardware
1mhz hardware
27 Posts 8 Posters 9.7k Views 5 Watching
  • T TimO
    Did you change the board definition within the Arduino IDE so that the code is compiled for 1 MHz? If not, the timing wont match. :)
    According battery:
    100 % = Vmax = 3.44 Volts
    0 % = 0 V
    CrankyCoderC Offline
    CrankyCoder
    @TimO Here is my definition in my boards.txt
    ## Arduino Pro or Pro Mini (1.8V, 1 MHz) w/ ATmega328
    pro.menu.cpu.1MHzatmega328=ATmega328 (1.8V, 1 MHz)
    pro.menu.cpu.1MHzatmega328.upload.maximum_size=30720
    pro.menu.cpu.1MHzatmega328.upload.maximum_data_size=2048
    pro.menu.cpu.1MHzatmega328.upload.speed=9600
    pro.menu.cpu.1MHzatmega328.bootloader.low_fuses=0x62
    pro.menu.cpu.1MHzatmega328.bootloader.high_fuses=0xD4
    pro.menu.cpu.1MHzatmega328.bootloader.extended_fuses=0x06
    pro.menu.cpu.1MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_1MHz.hex
    pro.menu.cpu.1MHzatmega328.build.mcu=atmega328p
    pro.menu.cpu.1MHzatmega328.build.f_cpu=1000000L
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
    • N Nca78
      Hello, no idea with the wake up time, I didn't check it at 1MHz, but it should not vary as it's based on the watchdog timer which is always at 128KHz, and not related to the main clock frequency and multiplier.
      For the battery level do you use a divider ? That's useful if you have a booster, but for a CR2032 directly connected to Vcc the most simple way is to measure the supply voltage. Please note that my measurement is not exact as value should be adjusted to the exact voltage of the "1.1V" reference voltage of the atmega.
      #include <SystemStatus.h>
      // Parameters for VCC measurement
      const int VccMin        = 2000;  // Minimum expected Vcc level, in Volts. At 2V the cell should be dead
      const int VccMax        = 2900;  // Maximum expected Vcc level, in Volts.
      SystemStatus vcc();
      int LastBatteryPercent = 200; // so we are sure to send the battery level at first check
          int currentBatteryPercent = SystemStatus().getVCCPercent(VccMin, VccMax);
          if (currentBatteryPercent != LastBatteryPercent) {
              LastBatteryPercent = currentBatteryPercent;
              sendBatteryLevel(currentBatteryPercent);
      CrankyCoder
      @Nca78 yes currently using a voltage divider. if i go to measuring the supply voltage alone that will get rid of the extra components I may not be needing atleast for this node.
      I will try your example. Thanks!
      www.CrankyCoder.net
      MySensors: 2.3
      • Y Yveaux
        @Jason-Brunk said:
        It does wake up, but not quite on the hour
        Can you be more explicit? How much time is there inbetween wakeups? The watchdog will always be a bit off, but it should only be a few %
        CrankyCoder
        @Yveaux Ok. so it checked in at 3:17am this morning. it did not check in again until 1:58 this afternoon. :)
        www.CrankyCoder.net
        MySensors: 2.3
        • CrankyCoderC CrankyCoder
          @Jason-Brunk that's almost 10 hours. My guess is that the timer is 8x off (if the code expects 8Mhz but is running at 1Mhz). Try recompiling with 1MHz board settings or divide the time by 8 in the sketch)
          CrankyCoderC 1 Reply Last reply
            CrankyCoder
            @mfalkvidd Ill reflash it. Just wondering if there is something in the code I should change to tell it it's running at 1mhz or if that's something that is supposed to just work based on the clock timing
            www.CrankyCoder.net
            MySensors: 2.3
            mfalkviddM M 2 Replies Last reply
              @Jason-Brunk I think the Arduino IDE is supposed to handle all that if the correct board is selected. I know that timings are off if I select 16MHz pro mini in the IDE and then flash to a 8MHz Arduino. It is also easily noticeable on the serial monitor, which will require a setting of twice the baud rate set in Serial.begin. I have never built a 1MHz node though.
              • S Offline
                @Jason-Brunk why not falsh your node for internal 8mhz for instance, and then use 1Mhz in sketch ? On my side, I prefer this way..and it works for me at least.
                when the node is not sleeping, and radio is not sleeping in RX mode for instance, there is no big saving to do this, only atmel consumption is low, radio is not..but if your radio is sleeping, yep it's interesting but I don't really see advantage to start node at 1Mhz as the radio does not sleep at startup and does the protocol stuff.
                  M Offline
                  M Offline
                  m26872
                  Clock settings are determined by the"fuses". What's your tool for fuses and bootloader programming? Are you sure you programmed the fuses as in your "boards.txt" above?
                  N 1 Reply Last reply
                  • M m26872
                    N Offline
                    N Offline
                    My understanding was that the "burn bootloader" function of the Arduino IDE will also write the fuses, no ?
                    From Arduino website :
                    "How does it work?
                    The "Burn Bootloader" commands in the Arduino environment use an open-source tool, avrdude. There are four steps: unlocking the bootloader section of the chip, setting the the fuses on the chip, uploading the bootloader code to the chip, and locking the bootloader section of the chip"
                    • N Nca78
                      "How does it work?
                      M Offline
                      M Offline
                      m26872
                      @Nca78 True. And I suppose you've also double checked the verbose output from that process.
                      Can't help you further. I would try soft 1MHz instead then, as @scalz suggested.
                      • CrankyCoderC Offline
                        CrankyCoder
                        Ok. So I got back in town and reflashed my bootloader. Claims it's running 1mhz now. No regulator, no leds. Even in sleep mode I am sitting at about 1.66ma. Which in deep sleep mode that seems really high. Considering the capacity of a coin cell i am looking at changing out about once every 2 weeks with no use.
                        Any thoughts? Recommendations? Just can't seem to get this running low power enough. Not sure if my hardware is junk or what. But i would take any recommendations or tests to see how to get this working since i have a small stack of these pro minis
                        www.CrankyCoder.net
                        MySensors: 2.3
                        • N Offline
                          N Offline
                          There's obviously a problem, I'm at about 1/1000 of that in sleep mode, you're sure your multimeter is not mistaking the unit ? ;)
                          I have cheap pro minis too, the < 2$ kind.
                          1mA+ in sleep mode sounds like a voltage regulator still connected, or the IC not sleeping, at least not in power down mode like when using the MySensors function. Are you sure you didn't leave a #define by mistake (like activating the repeater function with #define MY_REPEATER_FEATURE) that would prevent the atmega from sleeping ?
                            CrankyCoder
                            I checked, no REPEATER on.
                            Here is the code for my loop()
                            int whichbutton = 0;
                            whichbutton = sleep(digitalPinToInterrupt(2),LOW,digitalPinToInterrupt(3),LOW,86400000);
                            switch (whichbutton) {
                              case digitalPinToInterrupt(2):
                                  {//off
                                  send(msg_light.set(0),true);
                                  wait(300);
                              case digitalPinToInterrupt(3):
                                  {//on
                                  send(msg_light.set(1),true);
                                  wait(300);
                            sleep(250);
                            CheckBattery();
                            It's not running that over and over for sure. Otherwise I would see the battery value publishing regularly to the broker.
                            I broke the regulator off and the LEDs.
                            This is the one I have.
                            https://www.sparkfun.com/products/11114
                            I don't think the multimeter is misreading it. I can see the battery percentage dropping over the course of a day so it definitely seems like it's pulling more mA than it should sleeping.
                            www.CrankyCoder.net
                            MySensors: 2.3
                            • M m26872
                              N Offline
                              N Offline
                              In case someone doesn't believe the Arduino docs ;)
                              This is at the beginning of the bootloader writing process in Arduino IDE:
                              avrdude: verifying ...
                              avrdude: reading input file "0xde"
                              avrdude: verifying hfuse memory against 0xde:
                              avrdude: load data hfuse data from input file 0xde:
                              avrdude: input file 0xde contains 1 bytes
                              avrdude: reading input file "0x62"
                              avrdude: verifying lfuse memory against 0x62:
                              avrdude: load data lfuse data from input file 0x62:
                              avrdude: input file 0x62 contains 1 bytes
                              • N Nca78
                                M Offline
                                M Offline
                                m26872
                                @Nca78
                                The docs won't tell you if the process fails. The verbose output will. :wink:
                                  CrankyCoder
                                  hmmm. ok so I have verified I am writing the 1mhz boot loader.
                                  My multimeter says when it's sleeping i am still running at 1.5mah
                                  I have my openhab system tracking the battery usage. IN 6 days I have lost 30% of the battery and it's been in sleep mode.
                                  || *Time* || *Value* ||
                                  || 2016-08-14 19:29:27 || 100 ||
                                  || 2016-08-15 19:07:57 || 80 ||
                                  || 2016-08-15 19:11:18 || 81 ||
                                  || 2016-08-15 19:12:48 || 83 ||
                                  || 2016-08-15 19:13:14 || 76 ||
                                  || 2016-08-15 19:13:17 || 84 ||
                                  || 2016-08-15 19:13:56 || 80 ||
                                  || 2016-08-15 19:16:48 || 78 ||
                                  || 2016-08-19 15:07:57 || 76 ||
                                  || 2016-08-19 15:10:09 || 80 ||
                                  || 2016-08-19 15:12:43 || 79 ||
                                  || 2016-08-19 15:13:49 || 82 ||
                                  || 2016-08-19 15:14:20 || 84 ||
                                  || 2016-08-20 11:44:01 || 69 ||
                                  || 2016-08-20 11:44:23 || 48 ||
                                  || 2016-08-20 11:44:31 || 71 ||
                                  Any thoughts? Any recommendations on maybe a replacement pro mini that will for sure run at <1mah?
                                  www.CrankyCoder.net
                                  MySensors: 2.3
                                  • cimba007C Offline
                                    cimba007C Offline
                                    cimba007
                                    wrote on last edited by cimba007
                                    #21
                                    remove the power led (1-2mA), remove the voltage regulator if possible (1mA)
                                    • cimba007C cimba007
                                      CrankyCoder
                                      @cimba007 Led was already removed. :(
                                      www.CrankyCoder.net
                                      MySensors: 2.3
                                      • cimba007C Offline
                                        cimba007C Offline
                                        cimba007
                                        I would only imagine that the VoltageRegulator might be the culprit.
                                        As you said you use a "3v battery" so there is no need for the VoltageRegulator at all. Where do you apply the power? RAW or VCC? To power your Arduino with higher voltages you connect them to RAW which leads to the regulator.
                                        On most of my projects I use 2x AA Battery which are connected directly to VCC .. even with the VoltageRegulator intact I am at 66% for the last 7 days .. not loosing a single %.
                                        PS: Sry .. I missed that you have already removed the voltage regulator + the led.
                                        The library states to use RISING, FALLING, CHANGE as the interrupt mode but you use LOW .. I don't know to which of the 3 this mapps.
                                        But my guess is you are using FALLING .. thus waking your node up if you connect pin 2 or 3 to ground .. which means you have some kind of pull up don't you?
                                        Do you have anything connected to the Arduino ProMini? If so maybe try an empty sketch and remove all connected peripherals. Maybe even you can find some inspiration on this link: http://electronics.stackexchange.com/questions/49182/how-can-i-get-my-atmega328-to-run-for-a-year-on-batteries
                                        Another really good test on the powerdown current is here:
                                        http://www.rocketscream.com/blog/2011/07/04/lightweight-low-power-arduino-library/
                                        with this library (not compatible with mysensor so dont't use at the same time)
                                        https://github.com/rocketscream/Low-Power
                                          CrankyCoder
                                          @cimba007 thanks! will definitely test out some of this stuff. I am connecting power to vcc and the regulator has been removed.
                                          2 buttons connected to the interrupt pins, 1 for on 1 for off.
                                          here is my sleep statement
                                          Could my resistors connected to the buttons be causing the extra power?
                                          I would expect that to be the cause because even a door sensor or something would have to trigger the interrupt.
                                          A buddy of mine suggested I throw an additional multimeter in line so i am actually measuring with 2 and see if maybe my readings are just off or my multimeter is wonky reading it. He thinks maybe the fact i am measuring it is causing the extra current... (sounds like quantum entanglement stuff there, "It changed cause you measured it!!")
                                          www.CrankyCoder.net
                                          MySensors: 2.3
