  3. [SOLVED] Can't get Nano to show up in Device Manager
5 Posts 2 Posters 1.5k Views 2 Watching
  • spectral_rangerS
    spectral_rangerS
    spectral_ranger
    Please bear with me, I'm brand spanking new at this. Following the tutorial to build a gateway. Got to the point where I plug it into the computer, nothing happens. Realize I got Nano boards with CH340 chipset, so tried installing drivers I found online for them. Still nothing when I plug it in (one solid and one blinking light on board, but computer doesn't recognize anything). Tried installing some drivers from codebender.cc that are supposed to take care of this issue, and it walks through a workflow. Driver install goes fine, but at step where it will test my board, I need to select the board (no problem) and select a port. But it says there are no valid ports found. In my Device Manager under Ports(COM & LPT), I have one device for some Android device I have on COM3, but nothing else. I seem to be stuck at the point where I can't get a COM port for my Nano. Any help whatsoever would be very much appreciated!
    TheoLT 1 Reply Last reply
    • spectral_rangerS spectral_ranger
      TheoLT
      TheoLT
      TheoL
      wrote on last edited by TheoL
      @spectral_ranger first of all welcome to mySensors
      Probably a stupid question. But did you try rebooting? I some times have to do that on my Mac book, because otherwise my laptop doesn't see the Arduino.
      • spectral_rangerS
        spectral_rangerS
        spectral_ranger
        Assuming it's something stupid is probably right! But not in this case... I did reboot, no change.
        • spectral_rangerS
          spectral_rangerS
          spectral_ranger
          So my problem was the cable. I grabbed a mini-usb cable from an old charger I had, not realizing that not all usb cables are meant for data transfer. Got some more cables specifically made for data transfer, and everything works fine now.
            TheoLT
            TheoLT
            TheoL
            @spectral_ranger glad to hear that you we're able to solve it
            12.5k
