  3. Arduino & CC3000 Wifi & NRF24L01+ over SPI
arduinospi
8 Posts 6 Posters 6.3k Views 2 Watching
  • J Offline
    J Offline
    jesse
    Anyone know how to connect two SPI devices to an Arduino Uno?
    Separately, the CC3000 Wifi module and NRF24L01+ work normally.
    However, if I wire them in parallel, like for i2c, only the CC3000 works.
    Is there some type of input-output connection for one master and multiple slaves?
    • J Offline
      J Offline
      jesse
      I found the solution on this page: http://mathertel.blogspot.com/2013/04/using-spi-bus-with-ethernet-sd-card-and.html
      The key is setting the Chip Select (CS) line to be different for each module.
      For the CC3000...
      "#define ADAFRUIT_CC3000_CS 7"
      Pin 7 is being used exclusively to select the Wifi module.
      https://learn.adafruit.com/adafruit-cc3000-wifi/cc3000-breakout
      For the NRF24L01+...
      "RF24 radio(9,10);"
      Pin 9 is being used for Chip Enable (CE) and Pin 10 is Chip Select (CS).
      http://arduino-info.wikispaces.com/Nrf24L01-2.4GHz-HowTo
      http://maniacbug.github.io/RF24/classRF24.html
      The other SPI pins: CLK, MISO, MOSI, are shared by the two modules and get wired in parallel.
      E barduinoB F 3 Replies Last reply
      • greglG Offline
        greglG Offline
        gregl
        Goood stuff! What is it your making?
        Is it a spark core??
        T J 2 Replies Last reply
        • greglG gregl
          T Offline
          T Offline
          ToSa
          Code Contributor
          or a WLAN Gateway :)
          • J jesse
            For the CC3000...
            "RF24 radio(9,10);"
            E Offline
            E Offline
            epierre
            @jesse ;-) I did that on my Mega too ;-)
            z-wave - Vera -> Domoticz
            • greglG gregl
              J Offline
              J Offline
              jesse
              A Wifi bridge so I can use $1 NRF24L01+ modules to send data to my database or to the internet.
              • J jesse
                For the CC3000...
                "RF24 radio(9,10);"
                barduinoB Offline
                barduinoB Offline
                barduino
                @jesse
                I have a similar problem.
                I dont have the CC3000 breakboard I have the shield so changing pin address for this board is not going to work.
                Instead I've changed the NRF24l01+ to use pins CE 35, CS 34.
                I've also changed the init of the gateway to use pins 40,41,42 for the leds.
                (I'm using a mega btw)
                So just using the MySensors skecth it works fine.
                But as soon as I initialise the CC3000, the gw.begin() doesnt work anymore.
                Were you able to get this to work?
                Did you have to change any libraries?
                • J jesse
                  For the CC3000...
                  "RF24 radio(9,10);"
                  F Offline
                  F Offline
                  flopp
                  For the CC3000...
                  "RF24 radio(9,10);"
                  Hi do you still have a Gateway code when using CC3000 and arduino Mega or UNO(if it fits)?
