  3. Skech using DHT11/LDR and SoilMoisture from itead. (Solved solution inside)
9 Posts 3 Posters 2.6k Views 3 Watching
  • Tagore.PDET Offline
    Tagore.PDET Offline
    Tagore.PDE
    wrote on last edited by Tagore.PDE
    This is good? i think is not, maybe someone can check?
    Regards.
    //Including nescessary libraries
    //Defining child ID's and sensor pins
    //#define MY_NODE_ID 2
    #define LIGHTLEVEL 0
    #define HUMIDITY 1
    #define TEMPERATURE 2
    #define SOILHUMDITY 3 //agregado soil
    #define LIGHT_SENSOR_ANALOG_PIN A0
    #define ANALOG_INPUT_SOIL_SENSOR A1 // agregado soil
    DHT dht;
    //Defining values to store sensor information
    int LightLevel = 0;
    int lastLightLevel;
    int lastSoilValue = -1; // agregado soil
    float lastTemp;
    float lastHum;
    boolean metric = true;
    //Defining sleep and wait times
    unsigned long SLEEP_TIME = 30000; // Sleep time between reads (in milliseconds)(30 seconds)
    #define MESSAGEWAIT 500
    MyMessage LightMsg(LIGHTLEVEL, V_LIGHT_LEVEL);
    MyMessage msgHum(HUMIDITY, V_HUM);
    MyMessage msgTemp(TEMPERATURE, V_TEMP);
    MyMessage sHum(SOILHUMDITY, V_HUM); //agregado soil
    void presentation()  {
      sendSketchInfo("Sensor Pot", "1.0");
      wait(MESSAGEWAIT);
      present(LIGHTLEVEL, S_LIGHT_LEVEL);
      wait(MESSAGEWAIT);
      present(HUMIDITY, S_HUM);
      wait(MESSAGEWAIT);
      present(TEMPERATURE, S_TEMP);
      wait(MESSAGEWAIT);
      present(SOILHUMDITY, S_HUM);
       pinMode(ANALOG_INPUT_SOIL_SENSOR, INPUT);
                if (isnan(temperature)) {
        lastTemp = temperature;
        Serial.print("T: ");
                                        if (isnan(humidity)) {
        lastHum = humidity;
        Serial.print("H: ");
        Serial.println(humidity);
                                                    int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                                                    Serial.println(lightLevel);
        send(LightMsg.set(lightLevel));
        lastLightLevel = lightLevel;
        // Read analog soil value
                                          int soilValue = analogRead(ANALOG_INPUT_SOIL_SENSOR);
                                          if (soilValue != lastSoilValue) {
                                           Serial.print("Soil Value: ");
                                           Serial.println(soilValue);
                                           send(sHum.set(soilValue));
                sleep(SLEEP_TIME);
    • Tagore.PDET Tagore.PDE
      Regards.
      #define HUMIDITY 1
      DHT dht;
      int LightLevel = 0;
      int lastLightLevel;
      float lastTemp;
      float lastHum;
        wait(MESSAGEWAIT);
        wait(MESSAGEWAIT);
        wait(MESSAGEWAIT);
        wait(MESSAGEWAIT);
        lastHum = humidity;
                  sleep(SLEEP_TIME);
      T Offline
      T Offline
      TheoL
      @Tagore.PDE I don't think it's appropriate to post a sketch and ask if it's a good sketch. Please be more specific. Like do you have errors? Does something not work?
        Tagore.PDET Offline
        Tagore.PDE
        Sorry about that, maybe the Controller ( Domoticz ) is not taking the soilmoisture correctly.
        I see that he send 3 digits number, like this:
        But domoticz show me like this:
        So maybe is confused? or ai m confused?
        Regards
          Regards
          T Offline
          T Offline
          TheoL
          @Tagore.PDE I had a quick peak at your sketch. You're presenting the soil moisture sensor as a humidity sensor. That way Domoticz treats it as a humidity temp sensor.
          If you want to be able to see the moisture level you could present it as a light level
          But maybe @mfalkvidd has a better solution. Not sure what he uses for his office plant monitoring.
          I just used the digitial output of the soil moisture sensor. Because I was only interested in the fact that my plants are thirsty.
          Hope this helps.
            Tagore.PDET Offline
            Tagore.PDE
            @TheoL thx for your feedback.
              Tagore.PDET Offline
              Tagore.PDE
              For the record, to send in %, next code:
                soilValue = constrain(soilValue, 420, 1023);
                soil = map(soilValue, 420, 1023, 100, 0);
                if (soil != lastSoilValue) {
                  send(msgHumSoil.set(soil)); // Send in percent
                  lastSoilValue = soil;```
              • tlpeterT Offline
                tlpeterT Offline
                tlpeter
                I use V_LEVEL and S_MOISTURE for a moisture sensor.
                The percentage part is something i am going to try for sure.
                  Tagore.PDET Offline
                  Tagore.PDE
                  Hi @tlpeter , cna share one example?
                  Regards.
                    Tagore.PDET Offline
                    Tagore.PDE
                    I think i get it, @tlpeter :
                    MyMessage msgHumSoil(SOILHUMDITY, V_LEVEL);
                      sendSketchInfo("Sensor POT", "1.1");
                      wait(MESSAGEWAIT);
                      present(SOILHUMDITY, S_MOISTURE);
