  3. Domoticz
  4. Mysensors Ethernet GW w5100 problem
45 Posts 7 Posters 13.5k Views 7 Watching
  • tlpeterT tlpeter
    @mrc-core said:
    C:\Users\marco\Documents\Arduino\libraries\MySensors
    Did you put the sketch in this folder?
    mrc-coreM
    mrc-coreM
    mrc-core
    @tlpeter Yes i did, an d i have also put it on the test folder but i'm getting always the same error
      @mrc-core I have the same versions:
      Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
      Using library UIPEthernet at version 1.04 in folder: C:\Users\mfalkvidd\Documents\Arduino\libraries\UIPEthernet
      Using library MySensors at version 2.0.0 in folder: C:\Users\mfalkvidd\Documents\Arduino\libraries\MySensors
      mrc-coreM
      mrc-coreM
      mrc-core
      @mfalkvidd i don't understant this exit status 1 has i can see everithing is correct why do i get this error...
      • mrc-coreM mrc-core
        #33
        @mrc-core somewhere, MY_USE_UDP is defined. Since UDP is not supported on ENC28J60, the code can not be compiled.
        • mrc-coreM
          mrc-coreM
          mrc-core
          The error arduin IDE gives points to this line off code int Mysensors.h
          #elif defined(MY_GATEWAY_ENC28J60)
          		// GATEWAY - ENC28J60
          		#if defined(MY_USE_UDP)
          			#error UDP mode is not available for ENC28J60
          Ok going to see if i can found were the UDP is define. Thanks for the help.
            @mrc-core try adding
            #define MY_USE_UDP
            at the end of your sketch. You should then get an error saying it is being defined twice. The error message should also say which file and line it was defined on.
            mrc-coreM 1 Reply Last reply
              #define MY_USE_UDP
              mrc-coreM
              mrc-coreM
              mrc-core
              @mfalkvidd said:
              #define MY_USE_UDP
              Ok here's what happens:
              If i mark this line like this //#define MY_GATEWAY_ENC28J60 i can run the skecth with no error.
              If i un mark the line above the skecth gives the error.
              Inserting the line you have told in the end of the sketch i dont get any error if i have the //#define MY_GATEWAY_ENC28J60 marked, otherwise if i don't have this line with // the skecth gives the same error that we are triyng to fix.
              • tlpeterT
                tlpeterT
                tlpeter
                That is because UDP is enabled, if you uncomment the gateway stuff for the ENC28J60 then it compiles because UDP can be enabled now.
                So remove the comment lines and add #define MY_USE_UDP at the end like suggested.
                • mrc-coreM
                  mrc-coreM
                  mrc-core
                  Still having error :(
                  C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\marco\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\marco\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\marco\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10608 -build-path "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\marco\AppData\Local\Temp\arduino_modified_sketch_600804\gw.ino"
                  C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\marco\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\marco\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\marco\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10608 -build-path "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\marco\AppData\Local\Temp\arduino_modified_sketch_600804\gw.ino"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src\SPI.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\Dhcp.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\Dns.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\UIPClient.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\UIPEthernet.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\UIPServer.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\UIPUdp.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\Enc28J60Network.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\clock-arch.c" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\mempool.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\uip.c" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\uip_arp.c" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\uip_debug.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\uip_timer.c" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                  "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
                  In file included from C:\Users\marco\AppData\Local\Temp\arduino_modified_sketch_600804\gw.ino:50:0:
                  C:\Users\marco\Documents\Arduino\libraries\MySensors/MySensors.h:233:5: error: #error UDP mode is not available for ENC28J60
                  Using library SPI at version 1.0 in folder: C:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI
                  Using library UIPEthernet at version 1.04 in folder: C:\Users\marco\Documents\Arduino\libraries\UIPEthernet
                  Using library MySensors at version 2.0.0 in folder: C:\Users\marco\Documents\Arduino\libraries\MySensors
                  exit status 1
                  Error compiling for board Arduino/Genuino Uno.
                  • tlpeterT
                    tlpeterT
                    tlpeter
                    I see a lot off temp directory so your sketch is not saved in the correct library.
                    Open the gateway from the my documents folder:
                    C:\Users\Marco\Documents\Arduino\libraries\MySensors-master\examples\GatewayENC28J60
                    That is the example i used.
                    • tlpeterT tlpeter
                      mrc-coreM
                      mrc-coreM
                      mrc-core
                      @tlpeter
                      Thanks no more errors on the sketch.
                      My new problem is the ENC28J60 i had not notice that i had buy the MINI ENC28J60 having the code uploaded to the arduino i can't ping the GW IP...
                      • mrc-coreM
                        mrc-coreM
                        mrc-core
                        This is my GW with the mini ENC28J60 runing.
                        0;255;3;0;9;TSM:INIT
                        0;255;3;0;9;TSM:RADIO:OK
                        0;255;3;0;9;TSM:GW MODE
                        0;255;3;0;9;TSM:READY
                        IP: 10.8.1.201
                        0;255;3;0;9;Eth: connect
                        0;255;3;0;9;Eth: 0;0;3;0;2;
                        0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
                        0;255;3;0;9;Eth: 0;0;3;0;18;PING
                        0;255;3;0;9;TSP:MSG:READ 5-5-0 s=9,c=1,t=14,pt=2,l=2,sg=0:55
                        • tlpeterT
                          tlpeterT
                          tlpeter
                          wrote on last edited by tlpeter
                          #42
                          In your previous example you use pin 14,15 and 16 next to 5 and 6.
                          This is what the example on the site says:
                          Arduino NRF24L01 Radio Ethernet module
                          GND GND GND
                          3.3V VCC VCC
                          13 SCK SCK
                          12 MISO MISO/SO
                          11 MOSI MOSI/SI
                          10 SS/CS
                          6 CSN
                          5 CE
                          Use the pinout on the gateway example page.
                          • tlpeterT tlpeter
                            GND GND GND
                            3.3V VCC VCC
                            13 SCK SCK
                            12 MISO MISO/SO
                            11 MOSI MOSI/SI
                            10 SS/CS
                            6 CSN
                            5 CE
                            mrc-coreM
                            mrc-coreM
                            mrc-core
                            @tlpeter
                            Ok it's fix i cant ping the gw ip but domoticz can see the new arduino gw.
                            Now at the gw i'm getting this message:
                            0;255;3;0;9;TSP:MSG:READ 192-1-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
                            0;255;3;0;9;!TSP:MSG:PVER mismatch
                            I don't undestand this mismatch
                            tlpeterT 1 Reply Last reply
                            • mrc-coreM
                              mrc-coreM
                              mrc-core
                              Has i can see this GW is not to stable...
                              here's my log over domoticz:
                              2016-08-18 14:48:17.667 MySensors: connected to: 10.8.1.201:5003
                              2016-08-18 14:48:18.669 MySensors: Node: 0, Sketch Name: Ethernet GW
                              2016-08-18 14:48:18.671 MySensors: Node: 0, Sketch Version: 1,0
                              2016-08-18 14:53:23.808 MySensors: Connection reset!
                              2016-08-18 14:53:23.808 TCP: Reconnecting in 30 seconds...
                              2016-08-18 14:53:53.814 TCP: Reconnecting...
                              2016-08-18 14:53:54.816 MySensors: connected to: 10.8.1.201:5003
                              2016-08-18 14:53:55.818 MySensors: Node: 0, Sketch Name: Ethernet GW
                              2016-08-18 14:53:55.820 MySensors: Node: 0, Sketch Version: 1,0
                              2016-08-18 14:54:36.836 MySensors: Node: 3, Sketch Name: TemperatureAndHumidity
                              2016-08-18 14:54:36.839 MySensors: Node: 3, Sketch Version: 1.1
                              Reconnecting isues ???
                                @tlpeter
                                tlpeterT
                                tlpeterT
                                tlpeter
                                @mrc-core said:
                                @tlpeter
                                I think VER is for version and maybe (a wild guess) the P for protocol???
                                Which version Domoticz are you running? try the latest beta.
                                Is/are your gateway(s) upgraded too?
