  3. Domoticz
  4. Mysensors Ethernet GW w5100 problem
45 Posts 7 Posters 13.5k Views 7 Watching
  • mrc-coreM mrc-core
    I'm getting this error on IDE
    :\Users\marco\Documents\Arduino\libraries\MySensors/MySensors.h:233:5: error: #error UDP mode is not available for ENC28J60
    @mrc-core I think the error is quite clear : you enabled UDP which is not supported in combination with ENC
      @mrc-core I found this comment in an old version of the code:
       #undef MY_USE_UDP // Will not fit (or compile) on ENC28J60
      So it seems the problem is what the message says, UDP doesn't work on ENC28J60.
      @hek might know more
        Yeah, had to reduce the ENC lib to a minimum to make it compile with MySensors. But it was a couple of years ago. Haven't got the bandwidth to test it now.
        • mrc-coreM
          mrc-coreM
          mrc-core
          How did tlpeter got it to work ?
          What can i do? Go back to the w5100? At this moment i dont have nothing working at home.
          • tlpeterT tlpeter
            Can you show the sketch?
            I succesfully connected a ENC28J60 gateway and connected fine.
            mrc-coreM
            mrc-coreM
            mrc-core
            @tlpeter can you upload your working sketch
            • tlpeterT
              tlpeterT
              tlpeter
              Sure i can:
               * Version 1.0 - Henrik EKblad
               * LED purposes:
              // When ENC28J60 is connected we have to move CE/CSN pins for NRF radio
              #define MY_RF24_CE_PIN 5
              #define MY_RF24_CS_PIN 6
              #define MY_GATEWAY_ENC28J60
              // Gateway IP address
              #define MY_IP_ADDRESS 10,0,0,25
              #define MY_PORT 5003
              // Flash leds on rx/tx/err
              // Set blinking period
              // Enable inclusion mode
              #define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
              #define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
              #define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
              #include <UIPEthernet.h>
                sendSketchInfo("Ethernet GW", "1,0");
              • mrc-coreM
                mrc-coreM
                mrc-core
                Got a problem....
                In file included from C:\Users\marco\Documents\Arduino\gw\gw.ino:93:0:
                C:\Users\marco\Documents\Arduino\libraries\MySensors/MySensors.h:233:5: error: #error UDP mode is not available for ENC28J60
                Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
                Using library UIPEthernet at version 1.04 in folder: C:\Users\marco\Documents\Arduino\libraries\UIPEthernet
                Using library MySensors at version 2.0.0 in folder: C:\Users\marco\Documents\Arduino\libraries\MySensors
                exit status 1
                Error compiling for board Arduino/Genuino Uno.
                • mfalkviddM
                  #27
                  I am able to compile tlpeter's sketch without problem:
                  Sketch uses 28,142 bytes (91%) of program storage space. Maximum is 30,720 bytes.
                  Global variables use 1,267 bytes (61%) of dynamic memory, leaving 781 bytes for local variables. Maximum is 2,048 bytes.
                  @mrc-core did you modify tlpeter's sketch in some way?
                  • mrc-coreM
                    mrc-coreM
                    mrc-core
                    wrote on last edited by mrc-core
                    #28
                    Hummm then the problem can be my libraries
                    exit status 1
                    SPI librarie or UIPEthernet ??? has they aren't version 2.0.0
                    • tlpeterT
                      tlpeterT
                      tlpeter
                      Did you put the sketch in this folder?
                      mrc-coreM 1 Reply Last reply
                        exit status 1
                        @mrc-core I have the same versions:
                        Using library UIPEthernet at version 1.04 in folder: C:\Users\mfalkvidd\Documents\Arduino\libraries\UIPEthernet
                        Using library MySensors at version 2.0.0 in folder: C:\Users\mfalkvidd\Documents\Arduino\libraries\MySensors
                        • tlpeterT tlpeter
                          mrc-coreM
                          mrc-coreM
                          mrc-core
                          @tlpeter Yes i did, an d i have also put it on the test folder but i'm getting always the same error
                            mrc-coreM
                            mrc-coreM
                            mrc-core
                            @mfalkvidd i don't understant this exit status 1 has i can see everithing is correct why do i get this error...
                              #33
                              @mrc-core somewhere, MY_USE_UDP is defined. Since UDP is not supported on ENC28J60, the code can not be compiled.
                              • mrc-coreM
                                mrc-coreM
                                mrc-core
                                The error arduin IDE gives points to this line off code int Mysensors.h
                                #elif defined(MY_GATEWAY_ENC28J60)
                                		// GATEWAY - ENC28J60
                                		#if defined(MY_USE_UDP)
                                Ok going to see if i can found were the UDP is define. Thanks for the help.
                                  @mrc-core try adding
                                  #define MY_USE_UDP
                                  at the end of your sketch. You should then get an error saying it is being defined twice. The error message should also say which file and line it was defined on.
                                    #define MY_USE_UDP
                                    mrc-coreM
                                    mrc-coreM
                                    mrc-core
                                    @mfalkvidd said:
                                    #define MY_USE_UDP
                                    Ok here's what happens:
                                    If i mark this line like this //#define MY_GATEWAY_ENC28J60 i can run the skecth with no error.
                                    If i un mark the line above the skecth gives the error.
                                    Inserting the line you have told in the end of the sketch i dont get any error if i have the //#define MY_GATEWAY_ENC28J60 marked, otherwise if i don't have this line with // the skecth gives the same error that we are triyng to fix.
                                    • tlpeterT
                                      tlpeterT
                                      tlpeter
                                      That is because UDP is enabled, if you uncomment the gateway stuff for the ENC28J60 then it compiles because UDP can be enabled now.
                                      So remove the comment lines and add #define MY_USE_UDP at the end like suggested.
                                      • mrc-coreM
                                        mrc-coreM
                                        mrc-core
                                        Still having error :(
                                        C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\marco\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\marco\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\marco\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10608 -build-path "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\marco\AppData\Local\Temp\arduino_modified_sketch_600804\gw.ino"
                                        C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\marco\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\marco\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\marco\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10608 -build-path "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\marco\AppData\Local\Temp\arduino_modified_sketch_600804\gw.ino"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src\SPI.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\Dhcp.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\Dns.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\UIPClient.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\UIPEthernet.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\UIPServer.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\UIPUdp.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\Enc28J60Network.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\clock-arch.c" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\mempool.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\uip.c" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\uip_arp.c" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\uip_debug.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\uip_timer.c" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                                        "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
                                        In file included from C:\Users\marco\AppData\Local\Temp\arduino_modified_sketch_600804\gw.ino:50:0:
                                        Using library SPI at version 1.0 in folder: C:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI
                                        exit status 1
                                        • tlpeterT
                                          tlpeterT
                                          tlpeter
                                          I see a lot off temp directory so your sketch is not saved in the correct library.
                                          Open the gateway from the my documents folder:
                                          C:\Users\Marco\Documents\Arduino\libraries\MySensors-master\examples\GatewayENC28J60
                                          That is the example i used.
