  3. Domoticz
  4. Mysensors Ethernet GW w5100 problem
45 Posts 7 Posters 13.5k Views 7 Watching
  • mrc-coreM mrc-core
    Hummm then the problem can be my libraries
    Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr\libraries\SPI
    Using library UIPEthernet at version 1.04 in folder: C:\Users\marco\Documents\Arduino\libraries\UIPEthernet
    Using library MySensors at version 2.0.0 in folder: C:\Users\marco\Documents\Arduino\libraries\MySensors
    exit status 1
    Error compiling for board Arduino/Genuino Uno.
    SPI librarie or UIPEthernet ??? has they aren't version 2.0.0
    @mrc-core I have the same versions:
    Using library UIPEthernet at version 1.04 in folder: C:\Users\mfalkvidd\Documents\Arduino\libraries\UIPEthernet
    Using library MySensors at version 2.0.0 in folder: C:\Users\mfalkvidd\Documents\Arduino\libraries\MySensors
    mrc-coreM 1 Reply Last reply
    • tlpeterT tlpeter
      Did you put the sketch in this folder?
      mrc-coreM
      mrc-coreM
      mrc-core
      @tlpeter Yes i did, an d i have also put it on the test folder but i'm getting always the same error
        mrc-coreM
        mrc-coreM
        mrc-core
        @mfalkvidd i don't understant this exit status 1 has i can see everithing is correct why do i get this error...
          #33
          @mrc-core somewhere, MY_USE_UDP is defined. Since UDP is not supported on ENC28J60, the code can not be compiled.
          • mrc-coreM
            mrc-coreM
            mrc-core
            The error arduin IDE gives points to this line off code int Mysensors.h
            #elif defined(MY_GATEWAY_ENC28J60)
            		// GATEWAY - ENC28J60
            		#if defined(MY_USE_UDP)
            			#error UDP mode is not available for ENC28J60
            Ok going to see if i can found were the UDP is define. Thanks for the help.
              @mrc-core try adding
              #define MY_USE_UDP
              at the end of your sketch. You should then get an error saying it is being defined twice. The error message should also say which file and line it was defined on.
                #define MY_USE_UDP
                mrc-coreM
                mrc-coreM
                mrc-core
                @mfalkvidd said:
                #define MY_USE_UDP
                Ok here's what happens:
                If i mark this line like this //#define MY_GATEWAY_ENC28J60 i can run the skecth with no error.
                If i un mark the line above the skecth gives the error.
                Inserting the line you have told in the end of the sketch i dont get any error if i have the //#define MY_GATEWAY_ENC28J60 marked, otherwise if i don't have this line with // the skecth gives the same error that we are triyng to fix.
                • tlpeterT
                  tlpeterT
                  tlpeter
                  That is because UDP is enabled, if you uncomment the gateway stuff for the ENC28J60 then it compiles because UDP can be enabled now.
                  So remove the comment lines and add #define MY_USE_UDP at the end like suggested.
                  • mrc-coreM
                    mrc-coreM
                    mrc-core
                    Still having error :(
                    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\marco\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\marco\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\marco\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10608 -build-path "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\marco\AppData\Local\Temp\arduino_modified_sketch_600804\gw.ino"
                    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\marco\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\marco\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\marco\Documents\Arduino\libraries" -fqbn=arduino:avr:uno -vid-pid=0X2341_0X0043 -ide-version=10608 -build-path "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\marco\AppData\Local\Temp\arduino_modified_sketch_600804\gw.ino"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src\SPI.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\Dhcp.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\Dns.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\UIPClient.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\UIPEthernet.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\UIPServer.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\UIPUdp.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\Enc28J60Network.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\clock-arch.c" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\mempool.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\uip.c" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\uip_arp.c" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\uip_debug.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "C:\Users\marco\Documents\Arduino\libraries\UIPEthernet\utility\uip_timer.c" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "nul"
                    "C:\Users\marco\AppData\Local\Arduino15\packages\arduino\tools\avr-gcc\4.9.2-atmel3.5.3-arduino2/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10608 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\cores\arduino" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\variants\standard" "-IC:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI\src" "-IC:\Users\marco\Documents\Arduino\libraries\UIPEthernet" "-IC:\Users\marco\Documents\Arduino\libraries\MySensors" "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\sketch\gw.ino.cpp" -o "C:\Users\marco\AppData\Local\Temp\build5e931445a472986892676631252e16b5.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
                    In file included from C:\Users\marco\AppData\Local\Temp\arduino_modified_sketch_600804\gw.ino:50:0:
                    C:\Users\marco\Documents\Arduino\libraries\MySensors/MySensors.h:233:5: error: #error UDP mode is not available for ENC28J60
                    Using library SPI at version 1.0 in folder: C:\Users\marco\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.13\libraries\SPI
                    exit status 1
                    • tlpeterT
                      tlpeterT
                      tlpeter
                      I see a lot off temp directory so your sketch is not saved in the correct library.
                      Open the gateway from the my documents folder:
                      C:\Users\Marco\Documents\Arduino\libraries\MySensors-master\examples\GatewayENC28J60
                      That is the example i used.
                      • tlpeterT tlpeter
                        mrc-coreM
                        mrc-coreM
                        mrc-core
                        @tlpeter
                        Thanks no more errors on the sketch.
                        My new problem is the ENC28J60 i had not notice that i had buy the MINI ENC28J60 having the code uploaded to the arduino i can't ping the GW IP...
                        • mrc-coreM
                          mrc-coreM
                          mrc-core
                          This is my GW with the mini ENC28J60 runing.
                          0;255;3;0;9;TSM:INIT
                          0;255;3;0;9;TSM:RADIO:OK
                          0;255;3;0;9;TSM:GW MODE
                          0;255;3;0;9;TSM:READY
                          IP: 10.8.1.201
                          0;255;3;0;9;Eth: connect
                          0;255;3;0;9;Eth: 0;0;3;0;2;
                          0;255;3;0;9;Eth: 0;0;3;0;2;Get Version
                          0;255;3;0;9;Eth: 0;0;3;0;18;PING
                          0;255;3;0;9;TSP:MSG:READ 5-5-0 s=9,c=1,t=14,pt=2,l=2,sg=0:55
                          • tlpeterT
                            tlpeterT
                            tlpeter
                            wrote on last edited by tlpeter
                            #42
                            In your previous example you use pin 14,15 and 16 next to 5 and 6.
                            This is what the example on the site says:
                            Arduino NRF24L01 Radio Ethernet module
                            GND GND GND
                            3.3V VCC VCC
                            13 SCK SCK
                            12 MISO MISO/SO
                            11 MOSI MOSI/SI
                            10 SS/CS
                            6 CSN
                            5 CE
                            Use the pinout on the gateway example page.
                            • tlpeterT tlpeter
                              GND GND GND
                              3.3V VCC VCC
                              13 SCK SCK
                              12 MISO MISO/SO
                              11 MOSI MOSI/SI
                              10 SS/CS
                              6 CSN
                              5 CE
                              mrc-coreM
                              mrc-coreM
                              mrc-core
                              @tlpeter
                              Ok it's fix i cant ping the gw ip but domoticz can see the new arduino gw.
                              Now at the gw i'm getting this message:
                              0;255;3;0;9;TSP:MSG:READ 192-1-0 s=0,c=0,t=0,pt=0,l=0,sg=0:
                              0;255;3;0;9;!TSP:MSG:PVER mismatch
                              I don't undestand this mismatch
                              tlpeterT 1 Reply Last reply
                              • mrc-coreM
                                mrc-coreM
                                mrc-core
                                Has i can see this GW is not to stable...
                                here's my log over domoticz:
                                2016-08-18 14:48:17.667 MySensors: connected to: 10.8.1.201:5003
                                2016-08-18 14:48:18.669 MySensors: Node: 0, Sketch Name: Ethernet GW
                                2016-08-18 14:48:18.671 MySensors: Node: 0, Sketch Version: 1,0
                                2016-08-18 14:53:23.808 MySensors: Connection reset!
                                2016-08-18 14:53:23.808 TCP: Reconnecting in 30 seconds...
                                2016-08-18 14:53:53.814 TCP: Reconnecting...
                                2016-08-18 14:53:54.816 MySensors: connected to: 10.8.1.201:5003
                                2016-08-18 14:53:55.818 MySensors: Node: 0, Sketch Name: Ethernet GW
                                2016-08-18 14:53:55.820 MySensors: Node: 0, Sketch Version: 1,0
                                2016-08-18 14:54:36.836 MySensors: Node: 3, Sketch Name: TemperatureAndHumidity
                                2016-08-18 14:54:36.839 MySensors: Node: 3, Sketch Version: 1.1
                                Reconnecting isues ???
                                  @tlpeter
                                  tlpeterT
                                  tlpeterT
                                  tlpeter
                                  @mrc-core said:
                                  @tlpeter
                                  I think VER is for version and maybe (a wild guess) the P for protocol???
                                  Which version Domoticz are you running? try the latest beta.
                                  Is/are your gateway(s) upgraded too?
